Frustration With elactronics and Its tools!!!
  • Dhamlin
    • Aug 2013
    • 26
    I know I am cryin a bit here......
    I am a total noob to the electronics world. I got in to fixin tvs about 2 years ago. I have been reading like crazy.
    So here is my gripe:
    CAPACITORS!!! I got an ESR meter after getting burned a couple times with caps that had good capacitance but still didnt work.....OK so I now have this ESR meter that should tidy up all the other Hiding BAD caps....Not so much. Just recently I tested a capacitor that was clearly bulging, good capacitance and good ESR. So Next Cap: I replaced a voltage regulator down stream and fired the welder up. BANG this cap literally blew up and sent its guts all over everything! replaced it with another cap and now the welder(inverter) works...WTF
    I wish when troubleshooting you had tools to actually TEST components!
    How do u real techs deal with this? Did I stumble upon some rare caps or is this common?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Frustration With elactronics and Its tools!!!
    There are tools to test the parts lol example:
    Multimeter
    Esr meter
    Lcr meter
    Os scope
    Variac
    What are you trying to fix ?
      When cap blew up, it sounds like wrong polarity Voltage was applied or over Voltage applied.
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Multimeter
        Esr meter
        Lcr meter
        Os scope
        Variac
        Add to list-- Isolating Transformer, Insulation-Tester (Good for blowing up stuff!), PAT Tester.
        I have all the above, but rarely use more than 35 year old Beckman multimeter!
        Any suspicions about a cap--Easier and quicker just to change it!
        TELEFIX
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Yep. Wire an electrolytic capacitor in backwards and scrape the debris off the ceiling. Test equipment won't stop human error, I know I've done it myself once or twice.
          • adgor
            • Feb 2015
            • 16
            I remember doing that ..... it's kind of like putting a raw egg (uncovered) in a microwave and cooking it to fast. It's not pretty
              12-31-2023, 06:04 AM
            • rcanpolat
              M1 MacBook Pro 2021 A2485 - No backlight display
              by rcanpolat
              I recently got my hands on an M1 MacBook Pro (2021, A2485) that I suspect suffered some liquid damage. I have a hot air station and the basic tools to work on the board, but I’m new to SMD repair and would love some guidance before diving in.
              Here’s what I’ve observed so far:
              • When I power it on, I hear the MacBook chime and, with a flashlight, I can see the Apple logo on the screen. However, it never completes the boot and eventually powers off. My plan is to try to get the display fully working first, then tackle the boot issue.
              • I did some basic resistor
              08-24-2025, 02:16 PM
            • jorpec
              by jorpec
              Hi
              Thnaks
              01-23-2023, 10:37 AM
              Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
              12-14-2023, 07:45 PM
            • chth96
              by chth96
              03-09-2024, 10:03 PM
