Panasonic Plasma TX-P50GT30B - 7 blinks
  • d261116l
    • Apr 2016
    • 5
    My Panasonic Plasma has stopped working. On power on the green flashes fast for a few seconds then the red flashes 7 times. From reading online this is likely to be the SC board. Though it could also be SD / SU boards. Is this correct?
    Is there anyway to definitely prove it is the SC board? There are repair services for the board that cost between £70 to £100 and I don't want to waste money on it if it is not that board.
    The board part number is TNPA5335 BG. I've seen a TNPA5335 AG board on ebay that came from a TX-P50GT30B. Are the BG and AG boards compatible?
    thanks
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Panasonic Plasma TX-P50GT30B - 7 blinks
    You need a DMM, have you got one with diode tester mode ?
    • d261116l
      • Apr 2016
      • 5
      Yes I have a DMM with a diode tester mode.
      • d261116l
        • Apr 2016
        • 5
        After following the troubleshooting flowchart for 7 blinks on page 51 in the attached guide.
        I have a short circuit on Vsus. After plugging P2 and P11 on the P board. The short is only on pin1 on SC2 on SC board. And not on P or SS board.
        After removing the SC board from the plasma and testing across SC2 there is a short there. So the SC board is definitely damaged. I'm going to send the SC board away to get repaired as the soldering is beyond my skill level.
        Going by the flowchart it only points to the SC board being damaged. Is this correct? Or can the SD /SU boards be damaged aswell. Because if they caused the SC board to go, when I put back in the repaired SC board, could the SU / SD blow the SC board again?
        Is there anyway to test the SU /SD boards? And is there a certain way I power up the plasma when I replace the SC board?
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          Most likely, SU or SD caused the damage to SC. Perform the test that you can find on this forum..See slide 56 in your manual.
          • d261116l
            • Apr 2016
            • 5
            What is the test? Is it going across each output pin from the SD / SU board and to VFG using diode test mode on DMM? I don't get any short circuits, so does this mean the SU and SD boards are good?
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • stecos
              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
              by stecos
              Hi everyone!
              I happened several times, in the search for help from the web, to consult this very interesting forum.
              So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
              Having said that I come to the gist of my post on the forum as the title suggests.
              For my passion for technology I'm now collecting several...
              11-28-2022, 11:39 AM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • Biruslapio
              Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
              by Biruslapio
              Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
              It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
              It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
              02-16-2021, 09:44 PM
              After all of...
              07-13-2024, 08:14 PM
