eax64905001 No Pfc Help ?
  • gurug
    • Mar 2015
    • 27
    • Slovenia
    #41
    Re: eax64905001 No Pfc Help ?
    Originally posted by gurug
    I disconnected mosfet q801, and i got 46V on led connector and no fluctuation... does that mean that q801 is bad?
    Tested q801 and it seems ok ... hm, I guess I'll just order new power supply
    • gurug
      • Mar 2015
      • 27
      • Slovenia
      #42
      Hm, order "new" power supply board, but no luck ... seems this board I got is broken too ... It has 0V on LED output ... but I'm wondering, it is same model of board EAX64905001, but original was REV2.0 and this one I bought via eBay is REV4.0... Is this relevant?
      Like I said before on old board when I disconnect MOSfet I got stable 46V on connector ... please advice me further where to look - mosfet seems ok ...
      • gurug
        • Mar 2015
        • 27
        • Slovenia
        #43
        Problem SOLVED!
        It was two LED's which were broken on backlight ... power supply does not output 70V if it detects problem with LED's ... So it was in protective mode. I replaced LED's and TV is working normally. Thanks for you help and ideas!
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          #44
          Nice work
          • jarda105
            • Aug 2016
            • Czech Republic
            #45
            Hi, I have similiar problem with EAX64905001. I have no output voltage on con P801 with unconnected LED panel. Is there any protective when there's not load on output ? Or should be there 80V ? Thank you.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #46
              It should at start up with the Leds out fire up to 80v then back to 24v if there are no Leds if not then the Leds are fine and Psu is at fault.
              • jarda105
                • Aug 2016
                • Czech Republic
                #47
                Thank you, I'll do some measurements.
                • jarda105
                  • Aug 2016
                  • Czech Republic
                  #48
                  Please for advice. Voltage on P801 - led output is between 0 - 0.6V (oscilating). TV is operating (with headlamp directed on LCD panel I can see MENU). Testpoints P802 (43-45V), P803 same. P203 11.9V, P202 23.3V, P204 23.3V
                  Q801 - DRAIN 44V source and gate 0V
                  Q802 - DRAIN 0.130V source and gate 0.020V
                  Main voltages are 3.45V, 23.4V, 12V, on con. to Mainboard PDIN 1.12V and DRVON is 3,0V
                  On IC801 pin 9 PWMO (to Q802) is 0,02V. Vcc is 12V and REF is 4,96V. But gate pin 3 is only 0,02V. Thank you for any advice. What voltage should be on IC801 on pin 9? On schematic is Q803 but I can't find it on board - probabaly it's different version.
                  • jarda105
                    • Aug 2016
                    • Czech Republic
                    #49
                    One more thing is after cca 10minutes of measuring is hard to touch heatsink on Q101 because of temp I think about 60°C.
                    • Guest
                      #50
                      Problem SOLVED!
                      Did you replaced the entire led stripe or just the single leds? in the second case can you tell me the led's identification code?
                      • CostasCostas
                        • Feb 2017
                        • 20
                        • Cyprus
                        #51
                        Hi guys, I have this PSU with a 3 to 4 year old 32" LG TV. A few days ago the good wife splashed water on the TV, near the IR sensor, and now we just have sound and no picture.
                        Trawling the internet suggests it might be a problem with the t-con board. I have checked the voltage readings on the psu and they seem to tie up with what's in this thread. I should just add that the LED's are coming on, just no picture.
                        For the t-con board I have checked against the published voltage points and they look ok. Can't find any details or check points on the main video board.
                        Do you think it will be the t-con that has failed or are there any basic tests I can do on the video board?
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          #52
                          Did you dry up all the moisture? Blow some hot air in the spill area with a blower for a couple minutes and retry a start-up.
                          • CostasCostas
                            • Feb 2017
                            • 20
                            • Cyprus
                            #53
                            We just left it switched off for a few days before stripping it down. No moisture inside.
                            • CostasCostas
                              • Feb 2017
                              • 20
                              • Cyprus
                              #54
                              Any thoughts on how I can check if it is the tcon board that is faulty, or the video board?
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #55
                                what is the tv model number im wondering if it has tab bonds on the bottom of the lcd screen
                                so the set has nothing on the screen no backlights flash when you first turn it on?
                                • CostasCostas
                                  • Feb 2017
                                  • 20
                                  • Cyprus
                                  #56
                                  It's an LG 32LN 540B. Backlights are fine and so is audio, just no video.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #57
                                    ok can you post a picture of the t con board theres a fuse on it so you will need to test voltage to BOTH sides of it usually 12vdc
                                    • CostasCostas
                                      • Feb 2017
                                      • 20
                                      • Cyprus
                                      #58
                                      I tested all the regular test points on the t-con board and they were fine. I checked the t-con fuse for continuity although I'm not sure if I actually checked for 12V.
                                      I can do a quick check and then upload a photo if you think it will help.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #59
                                        maybe best to start a new thread in the tv section with tv model number etc post what you have checked already and post some clear pictures of the tv include one showing how all the boards are connected
                                          So the VGH, VGL, etc. are all OK?
                                          Start new thread with good, clear, and well focused pictures will help.
                                          • Pipolups
                                            Corsair K70 LUX RGB dying LEDs
                                            by Pipolups
                                            Hi there !
                                            I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                            Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                            10-08-2024, 11:58 AM
                                          • THE GTC
                                            Insignia NS-37D20SNA14 intermittent LEDs
                                            by THE GTC
                                            So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                                            When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                                            11-03-2020, 02:40 AM
                                          • pni
                                            Backlight panel diffuser melt by backlight leds broken
                                            by pni
                                            Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                                            10-12-2025, 12:08 AM
                                          • VitalComputing
                                            Replacing Mode Indicator LEDs
                                            by VitalComputing
                                            I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
                                            I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
                                            I thought I could just put a resistor...
                                            09-17-2023, 04:43 PM
                                          • jimbofz
                                            just a quick question do all qled leds appear blue when fault finding ?
                                            by jimbofz
                                            i have replaced many leds strips that have changed blue when they are worn
                                            and the new replacements are perfect white
                                            but when fault finding do quantum leds always look blue?
                                            08-28-2024, 06:51 AM
