Panasonic TCP-50G10 3 Blink error
+ More Options
Posts
  • Morts
    • Jan 2014
    • 6
    I am trying to figure out my issues on my 2009 model G10. The TV has been broken for some time now. I really liked this TV and would love to get it working again. I have replaced the A board which the manual says the the only cause of a 3 blink error is the A board. I am possibly thinking it could be the P board. When I test pin 5 and 6 on P25 I do not get close to 5V. If I am reading correctly from my research the 3 blink error is no 3.3V correct? So is there any other things I can check to make sure my P board is bad and is the culprit? Thanks for any help.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TCP-50G10 3 Blink error
    disconnect, SC2,SS11, P35, 3 white ribbons at the A-board.
    Turn it on and see if it still 3 blinks. Turn it off once you have the result. Don't reconnect anything for a good 5 mins or so especially p35, sc2, ss11 . Measure for residual voltages if in doubt. When running SC2, ss11 ~200V, p35 ~60v. Arcing P35 can destroy the panel on reconnection.
    If there is no 3 blink then I'd be suspect of the SC board which may have a shorted 15V line and shorted transistors etc.
    • Morts
      • Jan 2014
      • 6
      I disonnected SC2 SS11 and P35, also the A board ribbons, when i powered it on i got no blink error codes. Thanks tw is there any other tests to verify bad SC board? Thanks for the tips but why no 5v at pin 6 on P board?
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Locate and test Q661 on SC board. If short--there'll be a whole load more short in there too....
        TELEFIX
        • Morts
          • Jan 2014
          • 6
          How do I test it?? Thanks
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
            After all of...
            07-13-2024, 08:14 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
          • tiku
            Panasonic TH-L32C30D P-Board (1 Blink-Backlight_SOS)
            by tiku
            Hello Friends, i am having this model Panasonic TH-L32C30D, suddenly when i switch on, it went on One Blink, after looking at the service manual it says Backlight_SOS, I can see the menu on the tv screen for few seconds in the dark with the help of flashlight Before it goes into blinking cycle.
            I was having a backup P-Board which i replaced it and now its working fine, but i need to repair my faulty P-Board, as now its getting dificult to find any type of spares of this model, so can any friend who is master in Panasonic Repair, be kind enough to guide me or tell me which component should...
            09-05-2021, 05:02 AM
