Westinghouse LD-3265
  • jstiene
    • Feb 2013
    • 148
    Hello. I picked up a Westinghouse LD-3265 this week and it looks like the issue with it is that the HDMI ports don't work. I tried the standard coax input and that seems ok. Is there a known problem with this model and the HDMI ports? I see that the eeprom replacement doesnt mention issues with the HDMI ports. I was wondering if anyone else has run into this issue with this model...any help is appreciated...
    Thanks!
  • CapLeaker
    Leaking Member
    • 8326
    Re: Westinghouse LD-3265
    maybe lightning took the HDMI out. Unless you are properly equipped, I suggest you replace the main board.
    • aliougm
      Marantz SR4003 AVR HDMI board issue, seeking for help
      by aliougm
      I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
      Connection as below:
      Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
      If I bypassed AVR then HDTV screen color be good.
      I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
      3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
      I replaced all...
      04-30-2022, 12:21 PM
    • ratdude747
      Intel HDMI Windows 10 issue
      by ratdude747
      Got my butt kicked by windows 10 and intel last week.
      I have an HDMI switch and splitter setup for an AV rig (church) that I was trying to use the windows 10 half of my Lenovo T440s with. However, the audio will not work; HDMI (displayport) audio doesn't show in device manager and Intel's Control Center shows the external display as not supporting audio. Direct connect it to things and (if memory serves) it does work.
      Compounding the issue is that I'm forced to use Lenovo's drivers... as the generic intel ones refuse to install as they detect it's a lenovo system...
      12-04-2022, 07:34 AM
    • sebulica
      Asus FX705DT eDP and HDMI output issue
      by sebulica
      Hi
      I have an Asus FX705DT that had waterdamage....a lot
      I have managed to make the motherboard look like working but i stil have some issues and maybe someone can point me in the right direction.
      The laptop has a destroyed keyboard and the display is dead but i have managed to make the board start up and work "normal"...i have no short,power rails are looking good,hdd/ssd activity and so on.
      The problem is that there is no HDMI output,only sometimes makes the tv/monitor go black screen for a brief moment,and on the internal...
      04-06-2023, 04:44 AM
    • Ado02
      Dell Latitude 5510 USB-c Hdmi Issue
      by Ado02
      I am working on a Dell Latitude 5510 - the USB-c port has not HDMI output. The port works for data transfer and charging but not for HDMI.
      I check the USB-c port but can't see any damage.
      Has anyone experienced this problem and found a solution?
      04-05-2023, 02:55 AM
    • japlytic
      Certain DisplayPort-HDMI cables can disable HDMI CEC communication
      by japlytic
      With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
      An examination of the HDMI CEC wiring...
      07-10-2022, 09:48 PM
