Asus FX705DT eDP and HDMI output issue
  • sebulica
    Beginner
    • Mar 2014
    • 50
    Hi
    I have an Asus FX705DT that had waterdamage....a lot
    I have managed to make the motherboard look like working but i stil have some issues and maybe someone can point me in the right direction.
    The laptop has a destroyed keyboard and the display is dead but i have managed to make the board start up and work "normal"...i have no short,power rails are looking good,hdd/ssd activity and so on.
    The problem is that there is no HDMI output,only sometimes makes the tv/monitor go black screen for a brief moment,and on the internal eDP no signal to any display i have tested so far.I don't have a similar 17.3 60hz display but i have tested a bunch of 15.6 and 13.3 slim and normal HD and FHD....no signal or at least backlight.I have power on the display connector tho.
    As i have read on other forums and here aswel,the internal eDP is connected to the CPU and the HDMI is connected to the dedicated GPU.When i start the laptop it show image only on the internal display and after drivers are installed it starts the external one.
    Is there any way to edit the expected EDID data in bios or the mod it in such a way that it outputs image on the HDMI from the begining ?!I want to use the board with an external display for the rest of it's life...
    Or fi anyone tested,is there any way that an eDP to DisplayPort adaptor will work in this case ? I was thinking about rerouting the eDP to hdmi port as it only requires a few wires and removing a few components
  • sebulica
    Beginner
    • Mar 2014
    • 50
    Re: Asus FX705DT eDP and HDMI output issue
    ok,i tried to reroute the signal but still no image.I have managed to put an ssd with windows on it and acces to internet and after a while it automaticaly installed the video driver and got an image on hdmi.tested out the laptop and everything seems ok except the iGPU that states it can't start.i suppose that happens because it can't "detect" any internal display.
    if anyone managed ever to convince the iGPU to accept a different display than the one installed from the factory,point me to an explanation so i could figure a way to make a fix on this one...
    thanks
    • JaroTech
      • Mar 2015
      • 351
      Hi, you can try to simulate the lid closed, this way it will redirect the signal to the HDMI.
      • sebulica
        Beginner
        • Mar 2014
        • 50
        Tried that...won't start.Probably the algorithm for power on includes lid checking.Also tried to put a magnet on the hall sensor after powering on but still same result.Keeping the magnet on tha sensor,after uefi boot will trigger the sleep function....
        I want to turn this board in a "mini pc" as it's not worth it to replace all the external defective parts...keyboard,display,case,trackpad and battery...
        I think this is the first time i find a laptop that will not accept a lower size of display iven tho it has similar characteristics or iven better.
        • JaroTech
          • Mar 2015
          • 351
          You need to change the action for "Lid close action". Go to Power Options, Advanced settings, Power buttons and lid, Lid close action, Plugged in: and select Do nothing.
          • sebulica
            Beginner
            • Mar 2014
            • 50
            Found the culprit after buying a new display and still not working....
            Apparently a mosfet was acting bad and was lowering the output voltage for the display power supply.It seemed odd that on lower size displays sometimes i would get some lines and dots without backlight but the LED power supply was ok.The problem was on the LCD_VCC as it was varrying around 2.8-2.95 and was just beneath the treshold for working.I found out that it needed at least 3v to power on and 3v3 to work normaly.I did not think that such a small difference would make the case of not working at all.
            The LCD_VCC circuit has a "power switch" made with an ic that enables,disables and prevents shortcircuits from propagating on the 3v3 rail in case a bad display is connected.The ic itself contains a mosfet that apparently sometimes goes bad.
            Good to check for others in case they encounter situations like this.
            Cheers everyone!
            • bajdik
              Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
              by bajdik
              I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
              Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
              I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
              Unfortunately, I don’t have access to the schematic.
              It seems to me that when I bend the board, something changes.
              Could this...
              08-13-2025, 07:26 AM
            • aliougm
              Marantz SR4003 AVR HDMI board issue, seeking for help
              by aliougm
              I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
              Connection as below:
              Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
              If I bypassed AVR then HDTV screen color be good.
              I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
              3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
              I replaced all...
              04-30-2022, 12:21 PM
            • MakNCheese
              ASUS Zephyrus GA401I Severe Lag, Suspect Motherboard/Power Issue - Need Help Diagnosing
              by MakNCheese
              I'm having a serious issue with my ASUS Zephyrus GA401I (4 years old, worked perfectly until recently). The system is lagging heavily, even in the BIOS, and is charging extremely slowly (a few percent in hours), making it nearly unusable. I suspect a motherboard or power delivery issue.
              Symptoms:
              • Severe lag across the system, including BIOS navigation.
              • Slow boot times and unresponsive performance in Windows.
              • Battery charges very slowly (e.g., ~5% in 2–3 hours).
              • No error messages or BSODs, just extreme sluggishness.
              What I've Tried:
              • Replaced
              06-04-2025, 12:48 AM
            • lukkihapsi
              Asus Vivobook X515JA Weird Boot Issue
              by lukkihapsi
              Asus Vivobook X515JA Laptop
              Issue :
              Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
              Tried :
              Cleaned inside for dust, applied fresh thermal paste. No Change!
              Removed keyboard, Trackpad, fingerprint sensor. No Change!
              Removed Internal SSD. No Change!
              Updated BIOS to latest version. No Change!
              Removed battery and pressing power button for 1 minute. No Change!
              Weird Part :
              Upon turning laptop ON, screen lights up - stays black,
              I...
              07-07-2025, 12:07 PM
            • ZixuTech
              Asus F1502Z BIOS issue? CPU gets hot but no other response. No blinking light
              by ZixuTech
              Hey guys, I got this model which stays black screen but CPU heats up. All voltages on board seems oK.
              Perhaps BIOS issue?
              Brand: Asus
              Model: F1502Z
              SN: R4N0CV11S622169
              Board: X1403ZA 2.2
              I have flashed this BIOS for test purposes and it lights up the ASUS but blank SN. https://www.badcaps.net/forum/troubl...21#post3593121
              Can you clean and enter SN for me please....
              03-31-2025, 05:04 PM
