Philips 42PFL5332D/37 no backlight
  • RobII
    • Mar 2016
    • 34
    Hello TV repair guru's!! My Philips 42" TV has an issue. There is sound and you can see a picture on the screen with a flashlight but there is no backlight. The backlight does not come on at all. I found another post with a LG TV that had the exact same issue with an inverter board from ShopJimmy that was listed as compatible with my Philips. One problem is I did not see a part number or link for that inverter board.
    I did see this seems to be a common problem with LG/Philips inverter boards. Is there something I should be checking before I start replacing components?
    I haven't opened the case up yet but plan on doing that this weekend.
    Thanks in advance!!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Philips 42PFL5332D/37 no backlight
    What inverter does it use can you upload images ? If its the one im thinking of normally the caps for it fail which blows the controller Ic.
    • RobII
      • Mar 2016
      • 34
      I will do that tomorrow. Thank you!!
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        No worries, let us know
        • thoma
          • Sep 2012
          • 268
          http://www.ebay.de/itm/LG-Philips-In...-/141847603843
          http://www.forumazur.com/en/infos/te...philips-lcd-tv
          http://www.ohmsupplies.co.uk/epages/...Products/KIT63
          • RobII
            • Mar 2016
            • 34
            Removed the back cover. SSB looks good but a bit dusty. Removed the covers for the master and slave inverters and yeah, caps on both are popped.
            @thoma, I looked at the links you provided specifically the second one. I did not see any damage to any of the components other than the caps.
            @ReeceyBurger123, Pics are attached. At the very least I am going to replace the caps since they are cheap. What's the worst that could happen, I'm left with where I started?
            There is also a suspect cap on the SSB near the inverter outputs. Attached as well.
            Any other suggestions before I tear into it?
            Thanks again for the assistance!!!
            • RobII
              • Mar 2016
              • 34
              Another quick update. Fuse MF1 is open on the master inverter. I checked the MOSFETS and none are showing a short or open.
              Does anyone have a link to the schematics or the part number for fuse MF1?
                '10A' as printed on the body as sen on the pictures, made by LittleFuse.
                • RobII
                  • Mar 2016
                  • 34
                  These?
                  http://www.mouser.com/ProductDetail/...3lRveogD6i8%3d
                    It looks like it. But are you sure there is no short on the board? The two caps showing low ESR and capacitance?
                    • RobII
                      • Mar 2016
                      • 34
                      So far I have found no short. I checked the MOSFET's on both inverter boards (in circuit) and there is no shorts between gate and drain on any of them.
                      Edit: The two caps on both boards are shot. Domed and leaking.
                        Sam for Source and Drain too, no short?
                        Bad caps can cause the circuit to draws lots of current due to high ripple voltage and also cause switching frequency to run at the wrong frequency.
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          Change the bad caps and the fuse. I fixed one this way. Still going.................................
                          • RobII
                            • Mar 2016
                            • 34
                            Double checked and correct, no shorts.
                            Pics of components removed.
                            • RobII
                              • Mar 2016
                              • 34
                              Another quick update and question. I removed a couple of suspect caps from the power supply board. One looks like it exploded out the bottom.
                              My question, right next to the suspect caps are L203 and L204. I can't quite figure out what they are. Both tested short but since I have no idea what they are.... Any clue? Pic's attached
                              • thoma
                                • Sep 2012
                                • 268
                                https://cdn.badcaps-static.com/pdfs/...39dfa5950e.pdf
                                WAIT UNTIL GET MANUAL APPEARS!!!!!!
                                regards thoma!
                                • RobII
                                  • Mar 2016
                                  • 34
                                  After talking to one of the techs where I work, they informed me that the mystery components are inductors.
                                  I have placed a Mouser order so now the waiting game.
                                  Thanks for all the help so far. I'll update when I get the parts.
                                    https://www.badcaps.net/forum/attach...7&d=1459694689
                                    The cap under the heatsink should be replaced also, you can see bare aluminum, looks like it got hot too.
                                    • RobII
                                      • Mar 2016
                                      • 34
                                      I was debating on whether to replace it or not. Visually it looked ok but I should have checked it a little more thoroughly.
                                      Thank you sir!!
                                        That caps under the heatsink look to be part of the PI filter to work in conjunction with those two small caps that have blown bottom, so more likely that the small caps had to do all the works due to bad caps under that heatsink..
                                        • chestercc
                                          Philips TV Backlight Repair
                                          by chestercc
                                          So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
                                          My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
                                          The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
                                          11-18-2022, 01:15 PM
                                        • ohren
                                          Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
                                          by ohren
                                          I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
                                          The setup is basically:
                                          Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
                                          Transistor is switching the 3.5 V supply on the power board....
                                          12-05-2024, 11:10 AM
                                        • ovrax
                                          Philips 55PUS6804/12 turn on & off (probably backlight issue)
                                          by ovrax
                                          First of all, please excuse me as I'm quite new to this field.
                                          I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                                          I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                                          The Ambilight works perfectly and stays on.
                                          No sounds.
                                          Thanks in advance.
                                          08-25-2024, 04:33 AM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • DoOm86
                                          philips 55pft5500/12 Backlight issue. What am I doing wrong?
                                          by DoOm86
                                          TV philips 55'' no backlight (image ok).
                                          I tested the backlight with my led tester from the unplugged connector cable and it lights up. I had voltages at the motherboard connector, but anyway I order a new psu. Same problem, same voltages. Disassembled the TV and checked every strip with my led tester, they all light up, same voltage for every pair of strip (they go two by two).
                                          What am I missing?
                                          And something else I don't understand. I checked and I have 3v Leds, 10 per strips. Why every pair of strip (so 20 Led) take about 32v when powered up with my led tester 🤔
                                          04-16-2024, 03:47 PM
