Philips TV Backlight Repair
  • chestercc
    • Jul 2017
    • 12
    So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
    My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
    The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
    I have one original backlight strip which just had two bad LED's on it and I replaced these two bad LED's with the 6V ones and it worked for a little bit then the new 6V LED's started to smoke and they burned as well. The original LEDs on this backlight strip are still good.
    The backlight strips are LB43003 which I could get a whole set of but for £60 it simply isn't worth it for the value of the TV.
    I'm presuming that the original LED's are higher current and the backlight driver is working in constant current mode and is driving the new led's too hard. I would appreciate some advice on what I need to modify on the backlight driver board to reduce the current output.
  • nomoresonys
    • 12370
    • U.S.
    Re: Philips TV Backlight Repair
    Usually done with a resistor mod, maybe checkout TomTechTod on youtube, maybe leave a comment on one of his videos telling him what model you have, he may be able to walk you thru it.
    • Rajnhl
      • Oct 2018
      • 94
      • India
      • electronics, `gym
      check mosfet connected to cathode of lamps (Q802) for short . there are few resistors connected to source of this mosfet connected to ground. they are 1.1 ohms never bypass them. source of mosfet is also connected to current sense pin 9 of oz9902 through 1k resister. check this resister also for open.
      • nomoresonys
        • 12370
        • U.S.
        the topic concerns bringing down the current, done with resistor mod, has nothing to do with bypassing anything.
        • pni
          Backlight panel diffuser melt by backlight leds broken
          by pni
          Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
          10-12-2025, 12:08 AM
        • TR103
          Samsung 8K TV (2018) model QE65Q900RAL, boot loop
          by TR103
          I have a Samsung 8K TV (2018), model QE65Q900RAL. The TV does not power on and there is no backlight. The standby LED is on normally. After pressing the power button, the LED turns off, but after approximately 10 seconds it flashes an error code: 1 blink, which indicates a mainboard issue. After that, the TV enters a boot loop: the relay inside the One Connect Box clicks and the cycle repeats.
          I checked the mainboard and both backlight driver boards. All voltages appear normal, there are no shorts, and there is no visible damage.
          The backlight is controlled via a flat...
          05-16-2026, 03:25 AM
        • ohren
          Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
          by ohren
          I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
          The setup is basically:
          Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
          Transistor is switching the 3.5 V supply on the power board....
          12-05-2024, 11:10 AM
        • domix
          Philips 58PUS7555/12 backlight only
          by domix
          Hello, after a storm i notice tv is not working. Only backlight when i turn it on. If i press button on the back fot menu, backlight change. So tv menu and fuctionality is working i guess.
          what to check?...
          08-02-2026, 05:00 AM
        • Patrick501
          Philips 55PUS6704 no picture, backlight ok
          by Patrick501
          I'd like to repair a Philips 55PUS6704.
          It turns on and you can see the backlight, hear the sound but no picture.
          When I disconnect one of the T-con cables, half of the screen turns white.
          right cable disconnected= right side white
          left cable disconnected= left side white
          When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
          There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
          Also you can notice one single...
          11-12-2025, 08:46 AM
