Lg 42LE4500-ZA no backlight
  • comptek
    • Aug 2013
    • 606
    • uk
    #41
    Re: Lg 42LE4500-ZA no backlight
    Originally posted by Gimi
    I appreciate it but way to far for me. 2.30 hours drive. Very muxh appreciated though
    hey no worries but there here if you want them posted
    • Gimi
      • Aug 2015
      • 75
      The thing I can not understand is that I have tested them all in one then 3,then swapping them around and still the same. I am not sure now if is the led's really. Checked Visualy one strip and looks OK. How much you want including postage for them? Thanks
        https://www.badcaps.net/forum/showth...067#post644067
        Your also has the LED return low Voltage B (2).
        • comptek
          • Aug 2013
          • 606
          • uk
          #44
          Hi can you confirm that the model and screen numbers and make are the same please I will send pics of working strip in due course
          Regards
          Gary
          • Gimi
            • Aug 2015
            • 75
            Regards
            Gary
            That is exact tv set here. Anyway one more question for you or anyone on here
            Tested led's on diode mode everyone of them and there is no problem showing. Any way I can jumper the power supply pins to turn tv on without motherboard connected. One last test without mainboard. Thanks
              You can try just not having the cable between the main board and the power supply board connected then plug the TV into the outlet to see if the backlights will come on and stay on IF this power supply board has built-in pull-up resistors to allow self test of the power supply/LED driver board.
              • Gimi
                • Aug 2015
                • 75
                Does not come un without cable connected to mainboard, already tried it. Thanks
                • comptek
                  • Aug 2013
                  • 606
                  • uk
                  #48
                  my power supply board is different but mine when i got it had a dark patch bank of leds not lighting, i proceeded and took the screen apart thing for sure it was the led strip and just like your it work when stripped down i later found a bad connection on one of the fets touched it they all came on and let go they went off, that was when i put the screen back on and knacked it lolol
                  check yours out
                  • Gimi
                    • Aug 2015
                    • 75
                    check yours out
                    Thanks. All the psu leds board are very clean and they do power on for a bit with or without screen atached to it.
                    Just need to try without the main board connection on if it was any way.
                    • Gimi
                      • Aug 2015
                      • 75
                      Regards
                      Gary
                      As I said the TV here is exactly same as on ur pictures. I am not convinced is leds but I think is worth trying before putting screen back together. Let us know price plz and thank you very much. Kinda had enough of TV now lol.
                      • comptek
                        • Aug 2013
                        • 606
                        • uk
                        #51
                        Just to confirm are these the same as yours
                        • Gimi
                          • Aug 2015
                          • 75
                          Yes mate. 100% same. Thanks
                          • comptek
                            • Aug 2013
                            • 606
                            • uk
                            #53
                            pmd you Gimi
                            • Gimi
                              • Aug 2015
                              • 75
                              Update. Bought another faulty screen 42le4900 replaced screen from my mates tv and all up and running. Also tested power supply on that tv and is all good. So the leds where faulty. Thanks everyone for ur help
                              • Gimi
                                • Aug 2015
                                • 75
                                Meaning another tv not screen. It was £40 on eBay. Very lucky lol.
                                  Thanks for the follow-up on the repair.
                                    BTW, you have indicated that you test all the LED in diode mode and no bad one found, what did it show on your meter when testing in both directions? The LEDs actually light up with the meter?
                                    More likely it was showing the Vf of the protection diode.
                                    • Gimi
                                      • Aug 2015
                                      • 75
                                      Well I did tested and every one light it up. Only way why I said must be leds is cause tested all rest of parts on the other TV I bought off eBay and they do work. so I dont know if leds show up ok while testing but may fail once warmed up as mentioned before. So I can't see any proper way of led test. Cheers
                                      • Fleckers tv
                                        Fleckers TV
                                        • Nov 2015
                                        • 89
                                        • uk
                                        #59
                                        I repaired one of these at the weekend, same issue, it Had 5 leds out, one was Burnt to a crisp, the others just failed, then replaced the burnt one and the leds came back to life minus the 4... still working ok, I am awaiting new strips rather than solder them all
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Spoonicks
                                          ASUS VH238T blank screen with backlight
                                          by Spoonicks
                                          I am having a problem with a ASUS VH238T.
                                          The monitor started by just going blank, but the integrated speakers, and the backlight worked. The OSD didn't pop up, neither did the messages of DVI No Signal, nor the Asus logo.
                                          Turning off the monitor, and turning it back on made no difference. But leaving the monitor off for a few hours returned the monitor back to normal. The problem will eventually return after a couple of hours.
                                          Today, it started exhibiting another symptom: the display started showing a white image, that didn't take the whole screen....
                                          07-04-2023, 01:29 PM
                                        • DanPoka
                                          by DanPoka
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
