Insignia 39d400na14
  • james28909
    • May 2012
    • 53
    • someplace
    Insignia 39d400na14
    I have this insignia 39d400na14 that has a shorted ic. Its clearly burnt but i am having a hard time finding that part. It reads:
    AUO
    m106-11
    fg823
    And i can clearly see a small pinhole and scorching where it shorted out. Can anyone help me find this small ic?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Insignia 39d400na14
    Did you even check google ? Lol here is some links:
    http://www.aliexpress.com/store/prod...890354676.html
    google.com/auo m106-11 Second link messed up but paste into google.
      Can we see the picture of this board and the burnt parts?
      It is AUOPTO. Is it on the main or the T-CON board?
      • james28909
        • May 2012
        • 53
        • someplace
        Yes i checked google sir, the numbers didnt match perfectly so i were unsure.
        @budm it is on the tcon board but the tcon is soldered to the panel sadly. I will try to get some high res pics and post. Its clearly burnt though
        • james28909
          • May 2012
          • 53
          • someplace
          here are some pics. i could not get good lighting to get the part number for some reason. but here you go..
          the linked ic has different numbers after part number.
          mine reads:
          AUO
          m106-11
          fg823
          linked part reads:
          AUO
          m106-11
          EEE3S i think
          will that part work?
          heres another on ebay: http://goo.gl/7tFQgi
          • james28909
            • May 2012
            • 53
            • someplace
            can anyone confirm that ic from ali express will work? thanks
            EDIT: i see here that the third number on my chip is either a serial number or a production batch number so i think the part linked above might work, but i would still appreciate if someone a little more knowledgeable would chime in with some good ole confirmation
            • CapLeaker
              Leaking Member
              • 8215
              What you have to lose? 2 bucks?
              • reessi
                Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                by reessi
                Hello:
                I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                I started on the ACER:
                Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                10-29-2024, 11:31 AM
              • Yanleb
                Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                by Yanleb
                Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                D608, good
                D618 RF101L4S, good (See warning 1 below)
                D619 RF101L4S, good (See warning 1 below)
                D865 RF101L4S, shorted (See warning 1 below)
                IC464 Inverter HA MC74HC1G14, shorted...
                03-09-2020, 12:00 AM
              • modtool
                HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                by modtool
                Hi to all,
                the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                04-01-2025, 08:22 AM
              • BalkanBoy
                Dead Razer Blade 14 2022, shorted CPU?
                by BalkanBoy
                today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                I removed coil and injected 0.7V, it draw around...
                09-27-2024, 12:44 PM
              • barry101
                Apple 820-3662 VCore shorted to ground.
                by barry101
                Hi, Would appreciate some help.
                I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                Get charger light but no fan spin or chime. No liquid damage.
                Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                06-24-2025, 07:34 AM
