Dead Razer Blade 14 2022, shorted CPU?
  • BalkanBoy
    • Feb 2017
    • 69
    • Croatia
    today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
    Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
    I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
    Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
    I removed coil and injected 0.7V, it draw around 12A but still CPU wasn't getting very hot, maybe around 35 C. That's really strange if you ask me.
    As I don't have experience with Ryzen CPUs I just wanted to check with you guys is this CPU dead for good or I'm missing something? Is this coil used for something else or it's normal CPU phase? If it's normal CPU phase, why whole CPU isn't shorted?
    Photo attached.
    Thanks!
  • istvanszasz99
    Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
    by istvanszasz99
    Product ID: RZ09-0421
    Motherboard: CH580
    Bios File Size: 32,768 KB
    Dear Forum Readers!
    !!! MY RAZER BLADE...
    11-24-2025, 05:52 PM
  • theplop
    Razer blade 2022, 14" PI480 wont boot to OS, freezes
    by theplop
    Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
    I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
    I've run memtest quite a few times, and more often then not...
    03-20-2025, 06:42 PM
  • 0xx
    2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
    by 0xx
    Hi folks,
    My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
    What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
    I assumed that Windows Update was interrupted due to closing...
    09-14-2025, 03:46 PM
  • Heitor - AWS Informática
    Razer Blade 2020 RZ09 03519E11 - BIOS Request
    by Heitor - AWS Informática
    Hi, everyone!
    I've a Razer Blade 2020 on my bench today, all stand-by tensions are OK, but we've no action when I press the power button.
    Here's some informations about the laptop and the original file backup:
    Laptop Model: Razer Blade 2020
    MB Model: ol510mb v1.0
    P/N: RZ09 03519E11
    S/N: 622048M10000619
    Many thank's in advance! And if I broke any rule, sorry, I'm a rookie here, just tell me how can I fix that ...
    12-01-2025, 08:05 AM
  • Rangry
    Razer Blade 15 2022, No internal display, Error Code 43
    by Rangry
    Hi! I have a Razer Blade 15 2022, with a RTX 3060.
    One day, while using Linux, the internal display suddenly stopped working.
    On Windows, it says that the internal GPU has stopped working (with error code 43).
    I have tried removing the coin cell and the battery, and replacing the RAM, with no success on fixing anything.
    I'm looking for directions to fix this problem, and, first of all, I would like to be able to access the BIOS and change some settings (which is currently impossible as it is always shown on the internal display). There is a setting...
    05-29-2025, 07:01 AM
