Pioneer PDP-LX508D Won't turn on, 3 flashes from PSU
  • niblettr
    • Jun 2015
    • 98
    Bought this in the hope of fixing would like some pointers.
    When i plug in mains chord I get 2 clicks from the relay. (sounds about right to me) When i try an get the tv out of standby, a relay clicks the i get 3 flashes from red led on PSU.
    |v'e done a visual inspection and can't find anything suspicious.
    There are some pen markings on some of the Ybuffer ICS??
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Pioneer PDP-LX508D Won't turn on, 3 flashes from PSU
    Hello these are great Tv's deffo worth repairing. Does the standby light on the front of the Tv give any flashes ? If so are they red or blue and how many does it give ?
    • niblettr
      • Jun 2015
      • 98
      red and orange when in stanbye,
      red and blue with fault then contiuous 2 red flashes
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        2 red is a Ydrive failure which causes the Vs rail to be dragged down on the Psu therefore locking out the Psu. If you unplug the Y and Xdrive what happens does the Tv flash another fault code ?
        • niblettr
          • Jun 2015
          • 98
          No change, same flash codes.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Ok now time to start checking the voltage rails from what they are stated as on the connectors.
            • niblettr
              • Jun 2015
              • 98
              Ok, got no VSUS even when isolated. PSU fault?
                Seems likely
                • niblettr
                  • Jun 2015
                  • 98
                  ok, found 2x K3314 FETS that are shorted on the middle heatsink on the PSU.
                  I've whipped them out and double checked and there are shorted. Ordered some new one.
                  Bit worried that something further upstream may be bust.
                  I checked some sot23 transitors that looks like may be driving these fets and they checked out ok but 2 diodes measured a bit odd. I got 0.6v drop in both directions....
                    You should replace the driver chip (connected to the FETs) and the fuse as well.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Probably just the fets quite common on Plasma supplies due to the way they are loaded at start up. Also replace the fuse and should be fine
                        You should know now that it is a bad idea to just replace the FETs! Also the startup loading isn't a big deal (just charging the caps, but there is a current limit for a reason.)
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Alot of the time in my case the driver has almost never ever been damaged at all Tom. Normally if the Vcc and other input pins have no shorts or low resistance across them or to ground it will be ok. I personally have only had to replace 1in 10 drivers for the repairs like this.
                          It might come back and bit me on the ass but I will sort it.
                          • niblettr
                            • Jun 2015
                            • 98
                            thanks for all the input so far.
                            What fuse?
                            • niblettr
                              • Jun 2015
                              • 98
                              note I also removed the transformer so that I could get to the screws holding the fets to the heatsink.
                                For me it's much higher - around 1 in 3 have shown suspect readings - although it does depend on the topology of the supply. Flyback and half bridge is more likely to damage the driver. Flyback due to high peak drain voltages, half bridge due to floating source node
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Thats true, I have been lucky so far but I always check them any way Tom I know what too look out for. I guess there is the cases of the controller becoming intermittent as I have had before but thats rare for SMPS tbh.
                                  • niblettr
                                    • Jun 2015
                                    • 98
                                    Sorry guys, what fuse? Do you mean the sub ohms ceramic resistors?
                                    • niblettr
                                      • Jun 2015
                                      • 98
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Normally for the Vs fets its in between the filter caps or behind the fets. It might be a ceramic style can fuse.
                                        • odie34
                                          Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                          by odie34
                                          I am a hobbyist (not a professional) so please be gentle...
                                          I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                          I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                          02-18-2024, 09:11 AM
                                        • JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                          by JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                          Please help. Thanks in advance!
                                          Yesterday, 11:45 AM
                                        • matpod16
                                          Pioneer VSX-D1011 - turn on problem
                                          by matpod16
                                          Hi all! I have a problem with Pioneer VSX-D1011 – it don't turn on when the amplifier is disconnected from the socket for a few minutes. Standby LED doesn't light up. I'm a beginner in electronics, so I'm not very good at reading schematics. I tried to find the visual damages of components but I didn't see anything wrong. All of the fuses are ok, both of the switches the same. Have you any idea where should I start looking for? Once on every 100 tries I am able to turn it on, but what can it depend on?
                                          09-07-2023, 01:43 PM
                                        • Egidio85
                                          Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                                          by Egidio85
                                          Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                                          the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                                          the fan does not start.
                                          I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                                          any advice on what to check?
                                          06-10-2025, 05:00 AM
                                        • Noah Glasse
                                          LG 50PK590 - three clicks and steady red light, won't turn on.
                                          by Noah Glasse
                                          I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                                          I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                                          02-24-2025, 07:23 AM
