Pioneer VSX-D1011 - turn on problem
  • matpod16
    • Sep 2023
    • poland
    Hi all! I have a problem with Pioneer VSX-D1011 – it don't turn on when the amplifier is disconnected from the socket for a few minutes. Standby LED doesn't light up. I'm a beginner in electronics, so I'm not very good at reading schematics. I tried to find the visual damages of components but I didn't see anything wrong. All of the fuses are ok, both of the switches the same. Have you any idea where should I start looking for? Once on every 100 tries I am able to turn it on, but what can it depend on?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8344
    Re: Pioneer VSX-D1011 - turn on problem
    I think you may get more luck with folks reading this thread better, if you upload some high resolution pictures, maybe a service manual etc.
    Not seeing the patient X, I am guessing your problem is capacitor related to the STBY start circuit on your unit. Probably if you heat the PSU up with a hair dryer for a bit so the caps get warm, the STBY is starting right away and stays that way until you unplug it and let the capacitors cool off (or freeze them with a can of air upside down).
    Anyway... look in your service manual page 61, find where and how the STBY is created in the PSU check the components and change the related capacitors and or regulator out if you have to.
    Good luck!
    • masoksian
      Dell latitude e7470 not turn on .power buton on off and Run Power problem
      by masoksian
      I am dealing with the problem of turning on and off my Dell e7470 notebook.
      The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
      The system does not turn on, there is no post.
      I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
      The problem continues in the same way.
      I tried to turn on the Fn key, nothing came to the screen....
      02-15-2025, 12:08 PM
    • PacoGT
      HELP!! Dell E6440 laptop with problem does not turn off and turn itself on help
      by PacoGT
      A few days ago my laptop gave me problems, when I wanted to turn it on to my surprise without charging so I did not put much importance on it, after that I turned it on with a charger, it turned on and charged the laptop, the problem with the laptop is that when it is turned off it turns to turn on after seconds, sometimes at 2 or sometimes at 8, other than that it works normally, I already checked many things, I changed a mosfet at the charge input to a pnp but it remained the same, after that I checked and I did not find anything outside Normally, before that, it had a failure where I changed...
      07-11-2023, 09:31 PM
    • pajdek
      Lenovo Y700-17ISK turn on and off
      by pajdek
      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
      09-20-2023, 02:49 AM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • burntonnerings
      Pioneer VSX-1021 MCACC flashing, can't find problem
      by burntonnerings
      Have a Pioneer VSX-1021 that goes to MCACC flashing as soon as it is plugged in.
      If I enter release mode, it powers on, the screen display is correct, but then it shuts down and goes back to MCACC after a few seconds. I can shut it down to standby (w/o flashing MCACC if I hit the power button as soon as release mode finishes the boot sequence).
      Entering reset mode and executing a reset doesn't change this.
      I am unable to enter service mode to see the error counts - Enter + Power button doesn't do anything, whether from normal standby or from MCACC flashing....
      12-09-2023, 10:11 PM
