Pioneer PDP-LX508D Won't turn on, 3 flashes from PSU
+ More Options
Posts
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    #41
    Re: Pioneer PDP-LX508D Won't turn on, 3 flashes from PSU
    Nooooo ! I will buy it !
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      #42
      Do not trash it i will buy it !
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        #43
        Send me a pm !
        • niblettr
          • Jun 2015
          • 98
          Jumped the gun there a bit. Tv won't fit in the bin and Mrs has stopped nagging every 5 minutes..
          Does seem a shame to get rid and really hope this is not a panel problem. Reason I say this is that all the voltages check out.
          As the fault (8 flashes) points to ADRS fault) I checked the voltages onto 8 address boards, 4 on the top of the panel, 4 on
          the bottom of the panel and they seem fine. The ribbons cables going to them seem fine.
          Also, got to check if the x sustain (with the possibly incorrect silk screen) was put in by previos owner an may be wrong model board?
          Its model number is ANP2195-A
          Other than checking around where I have repaired already (check that the fets are being driven etc) I don't know where else
          to check.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            #45
            The faulty, fets might have burnt up a couple of their resistors etc. Have you checked their related smd components ?
            • niblettr
              • Jun 2015
              • 98
              Yes, I checked the gate resistors. The driver ics (sot23-6) we're checked for shorts to GND so far. I need to check with a scope to see if gates of Fets are being driven by drivers to test drivers properly.
              I am suspecting bust panel because when I power up and screen comes on I get a faint buzz and then a power down 8 flash fault. Then if I unplug the top right and bottom right address board the buzz does not happen and I don't get an 8 flash error.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #47
                The screen would only be bust if its cracked though they really cant fail in any other way, is it cracked at all ?
                • niblettr
                  • Jun 2015
                  • 98
                  However I do get another fault but not a flashing red one (must be a blue one) will investigate more later.
                  • niblettr
                    • Jun 2015
                    • 98
                    No cracks that I can tell
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #50
                      Cant be the panel then, sounds like your control board isnt telling the Y drive to sustain properly. I had this with a Samsung guessing the shorted Ymain damaged the Control board and it was causing some weird things on the screen. Tom will be able to help you if you get a scope though.
                        unlikely, I don't see a Y-main easily damaging the control board.
                        Could be shorted address lines, will be failed panel usually if it gives 8 red flashes after brief image.
                        • niblettr
                          • Jun 2015
                          • 98
                          Is there an easy way to confirm this?
                          • niblettr
                            • Jun 2015
                            • 98
                            Just seems strange that TV had 2 faults at the same time that seem unrelated.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #54
                              I dont personally think its the screen as if it was the Tv would not have worked in the first place but then the Y drive failed something else could have failed when the fets did.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                #55
                                Also you can actually see the shorted address lines inside the screen when its off, you will be able to see one of the wires in the scree shorting out to the one behind it. But the VERY VERY RARELY happens.
                                • niblettr
                                  • Jun 2015
                                  • 98
                                  Bloody ribbon bonded on the screen was torn! FFS.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #57
                                    Nooooooo
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #58
                                      Got an image of it possibly might be fixable ?
                                        Sadly it probably isn't if it's the address lines. These are nice TVs, but good luck reattaching the cables with 4000+ drive lines (for just a 720p TV! a 1080p one has nearly 6000!)#
                                        8G and 9G Kuros do occasionally have panel failures, but it's one of the more rare failure modes.
                                        • ReeceyBurger123
                                          Never Give Up !
                                          • May 2014
                                          • 7325
                                          • Britain
                                          #60
                                          Thats real crap Ohh well good effort Niblettr always worth a try buddy
                                          • odie34
                                            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                            by odie34
                                            I am a hobbyist (not a professional) so please be gentle...
                                            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                            02-18-2024, 09:11 AM
                                          • matpod16
                                            Pioneer VSX-D1011 - turn on problem
                                            by matpod16
                                            Hi all! I have a problem with Pioneer VSX-D1011 – it don't turn on when the amplifier is disconnected from the socket for a few minutes. Standby LED doesn't light up. I'm a beginner in electronics, so I'm not very good at reading schematics. I tried to find the visual damages of components but I didn't see anything wrong. All of the fuses are ok, both of the switches the same. Have you any idea where should I start looking for? Once on every 100 tries I am able to turn it on, but what can it depend on?
                                            09-07-2023, 01:43 PM
                                          • Egidio85
                                            Samsung NP750QFG-KA3DE does not turn on , Blue LED flashes 3 times
                                            by Egidio85
                                            Hi everyone, I have a Samsung NP750QFG-KA3DE , MainBoard VESTA3-15 BA92-24515A
                                            the battery is charged. pressing the power button the blue LED flashes 3 times and then stays blue. then the sequence repeats.
                                            the fan does not start.
                                            I noticed that I have no power on the processor and it does not heat up. could it depend on the bios?​
                                            any advice on what to check?
                                            06-10-2025, 05:00 AM
                                          • Noah Glasse
                                            LG 50PK590 - three clicks and steady red light, won't turn on.
                                            by Noah Glasse
                                            I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                                            I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                                            02-24-2025, 07:23 AM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
