Panasonic BluRay DMP-BD871 Freezes on hello display
  • Steelhack
    • May 2012
    • 24
    I was given this unit to tinker with. When you first turn it on it appears to start fine...the display will say hello. You can eject the tray insert a disc and the tray will return. Then thats it. No functionality. Tray will no longer respond. Just one eject and return....Display never changes from "Hello"
    Any ideas where to start checking?
  • martyparish
    • Dec 2012
    • 313
    Re: Panasonic BluRay DMP-BD871 Freezes on hello display
    Can you hear the disc spin up?
    Maybe a firmware update will solve it:
    http://shop.panasonic.com/support-only/DMP-BD87.html
    • Steelhack
      • May 2012
      • 24
      the disc does spin...I have the case apart and can actually watch it spin.
      • Neelix
        • Oct 2013
        • 145
        • South Africa
        Is anything being displayed on the TV or monitor that you have the player connected to?
        • Steelhack
          • May 2012
          • 24
          nothing is being displayed
          • Diah
            • Feb 2013
            • 6574
            need some test. insert USB at the front panel then plug it on at AC, keep eyes on the led indicator of the usb will light on / blinking or not.
            use normal CD audio track and insert it, Hello will change to show track No or not.
            • Steelhack
              • May 2012
              • 24
              With USB plugged in...Light comes on and stays steady NO BLINK
              With music CD in...disc continues to spin....HELLO still on display
              • Diah
                • Feb 2013
                • 6574
                its locked. need firmware to play on.
                • Steelhack
                  • May 2012
                  • 24
                  Attempting firmware update now. 5 minutes into what it says could be a 12 minute update.
                  Not sure its going to do anything....Does not seem to be much activity outside of the disc spin....although I do here a rapid tick tick tick tick repeating that I did not hear when a movie or music CD was spinning.
                  Will edit post in about 15 minutes
                  EDIT 1 - I am doing the CD fw update opbviosly since I have no signal being sent to a screen
                  • Diah
                    • Feb 2013
                    • 6574
                    tick tick tick tick repeating its laser lens positioned to relocated data on cd.
                    its sign of life
                    • Steelhack
                      • May 2012
                      • 24
                      Been about 20 minutes...no change. Hello never left the screen and is still present. Im going to let it go a bit longer and then attempt the basic RESET I read about while letting this run.
                      I have an 88A and when I tested the Caps they all seemed ok
                      • Steelhack
                        • May 2012
                        • 24
                        no go on firmware update...no go on reset.
                        System becomes unresponsive almost immediately after boot. I get 1 open from the open lose button...and then I have to push back to close manually.
                        • Diah
                          • Feb 2013
                          • 6574
                          the sadness o service manual available from Panasonic, is it the main board the small one ? could you upload photo of it.
                          • Steelhack
                            • May 2012
                            • 24
                            Here are pics of both boards. If you need more or better ones I can get them
                            • Diah
                              • Feb 2013
                              • 6574
                              on photo No2, the caps look funny, and the area around like some one try to repair AV section. take close look on them.
                              try to download this update again and write it on new CD-R not other one like CD-RW. and the eeprom with label on the Photo, heat it while you play the CD,
                              http://av.jpn.support.panasonic.com/...7/bd77_na.html
                              • soccersci
                                • May 2018
                                Steelhack, Were you ever ale to resolve the "Hello" issue? I have the exact same problem.
                                • BigPete
                                  Panasonic Heatpump Dryer Repair
                                  by BigPete
                                  I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                  The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                  In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                  Unfortunately the whole machine has to come apart to fix it.
                                  I have...
                                  11-01-2025, 06:40 PM
                                • Andre Gilbert
                                  by Andre Gilbert
                                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                  11-20-2024, 08:52 PM
                                • N3Star
                                  ASUS ROG G15 G513QY random freezes
                                  by N3Star
                                  My laptop recently started freezing randomly - it usually freezes after a few minutes, sometimes after 2, other times 10 minutes.
                                  So far I kind of ruled out software problems, as the problem persists on live booted Linux, installed Windows and also while installing Windows. My first thought was that it was overheating, so I checked the temps and they are fine, as You can see on the screenshot, never the less I opened it up and reapplied LM on both cores, also using some more thermal putty on the VRM, obviously didn't help.
                                  While live booting Linux it usually freezes...
                                  11-16-2025, 02:48 PM
                                • AquaMan Ua
                                  by AquaMan Ua
                                  05-17-2025, 09:40 AM
                                • grosseader
                                  MSI B450 Gaming Plus Max - freezes randomly
                                  by grosseader
                                  Hello everyone, i got this mobo for long time, now i decided to rearrange some hardware and build a office pc, but 1 week so far, this motherboard drives me crazy.
                                  What is the issue:
                                  PC freezes randomly. While loading win, while installing win, while in windows , and just once did it while in bios.
                                  Hardware:
                                  MSI B450 Gaming Plus Max , MSI A320m A-pro
                                  BIOS : 7B86vHG - latest
                                  CPU: Ryzen 3 1200, 3200G , Ryzen 5 3500x, Ryzen 5 5500
                                  GPU: Vega 7 in 3200g and MSI 1060 6GB
                                  RAM: 2x8 ADATA spectrix 3000 , 2x8 SiliconePower 3200
                                  01-30-2023, 03:24 PM
