LG 50PS8000 Horizontal lines
  • DDTech
    • Mar 2016
    • 9
    • Denmark
    My LG 50PS8000 Plasma are missing every second line on the lower 2/3 of the screen.
    All inputs and menu are affected
    The upper 1/3 of the screen is perfect, but he lower 2/3 are missing half the lines. One line good, next line black
    Va and Vs is ok
    Sound ok, menu ok, all input does work
    Tried to disconnect and reconnect all flex cables - did not help.
    Ysus? Ydriver? Or Control board?
  • DDTech
    • Mar 2016
    • 9
    • Denmark
    Re: LG 50PS8000 Horizontal lines
    As far as I have found out, the boards are the same on a LG 50PS3000 Plasma
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Have you ran the test patterns ?
        Looks like a bad scan driver (buffer board), if one output of a buffer IC fails you could get this pattern. I would suggest replacing the upper buffer.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Wait there Tom ! Have you seen Ali E's post about one of these ? If not the Ysus was causing the issue something about a bad buffer ram Ic which tells the Ysus what to load on the panel. Also I had the PS3000 with lines like this running the TP the image was fine and the mobo was the cause in the end.
          • DDTech
            • Mar 2016
            • 9
            • Denmark
            How do I run test patterns?
            Service menu?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              I don't know if this will help.
              https://www.badcaps.net/forum/showthread.php?t=26790
              • vinceroger69
                • Mar 2012
                • 6714
                service manual
                https://cdn.badcaps-static.com/pdfs/...705de3757e.pdf
                • DDTech
                  • Mar 2016
                  • 9
                  • Denmark
                  I found spare parts in the UK and repalced the upper buffer board, as Tom66 recommended.
                  Now the LG 50PS8000 is running again
                  Thank you Tom66
                  • DDTech
                    • Mar 2016
                    • 9
                    • Denmark
                    UPDATE - Okt 2017
                    After replacement of the upper buffer the screen worked fine until yesterday
                    This time the lower 1/3 of the screen had the same failure
                    To my luck I got both the upper and lower buffer boards as spare parts last time
                    After replacement of the lower buffer it's now working again
                    Next time I guess it's a new set (as I'm out of spares)
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      After so many months, it is good to get an update.....Good job....Yes if it was me also....I'll get a new TV next time.....Keep going.
                      • Ihandyrepair
                        Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                        by Ihandyrepair
                        Hi guys
                        I just started fixing 4k TV few months ago. so I am still learning a lot
                        I got this tv from friend complaint is ghosting or horizontal lines on image.
                        never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                        then it started to show the ghosting white image.
                        I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                        it has 3 thin small boards at the bottom of the...
                        12-05-2022, 04:18 PM
                      • Syseng
                        Lenovo P14s Gen 5 SVP unlock
                        by Syseng
                        This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
                        The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
                        06-22-2025, 07:44 AM
                      • cubytus
                        Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                        by cubytus
                        Hi to all,
                        I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                        I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                        Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                        01-10-2024, 01:26 AM
                      • x_orange90_x
                        Samsung UN46C8000XFXZA Horizontal lines
                        by x_orange90_x
                        I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                        I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                        07-15-2023, 05:06 AM
                      • Rubenlily
                        Samsung QE50Q67TAU - horizontal lines
                        by Rubenlily
                        First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                        I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                        I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                        I'm no expert but I've done the tape...
                        08-16-2023, 01:12 PM
