Rca led50b45rq
+ More Options
Posts
  • x_orange90_x
    • May 2015
    • 727
    Re: Rca led50b45rq
    Originally posted by budm
    Good, you have to open the panel next.
    No that's not good 😞 I've seen a couple videos of LED replacement in other tvs, but they had Edge lighting.. Is it more or less difficult with rear-lit panels?
    • Measuray
      • Feb 2012
      • 5
      Post 71:
      "Just finished checking. I've got 171.8v on EC1 and 171.4v on EC1A. D4 diode reads 000 one direction and 461 in the other. I did the flashlight test and CAN see the menu on screen, so I'm pretty certain now its one or more bad LED backlights."
      Post 148:
      "Also decided to check EC1 and EC1A voltages without LEDs.. 397v on both. "
      So after all these times I try to find out why we do not have Boosted Voltage after D4 was replaced.
      At the beginning of the project we know that the PFC is not working so it has to be fixed first before moving on to other section if the TV is still not working after we get the boosted Voltage to run other circuit. So I spent times tracing the board to see if we have the VCC to run the SMPS IC and the PFC IC or not, But in fact the PFC does work after D4 was replaced but something else caused the VCC to the SMPS and the PFC IC to drop out so now we will need to find out if the SMPS for the LED driver, LED wiring (shorts wiring to the chassis?), or LED are causing the shutdown or not since now the SMPS does have the Boosted Voltage to run. If I would have known that we do have Boosted Voltage after D4 was replaced then I would have check other section of the circuit to find out what causes the shutdown to occur.
      But I have to take a break from this threads for now since lately I have been given wrong DATAs from so many threads and caused me to go the wrong direction and it is getting very tiring for me. I am very patient person when trying to help people but right now I am very tired.
      I hear you Budm - I had to pop 3 Prozac pills trying to follow this lead. Hope y'all figure it out.
      • Measuray
        • Feb 2012
        • 5
        Orange90 - Did you figure the problem out? Personally, when I encounter a bad led, you can tell when it flashes a horizontal lines in the middle of the screen for a spit second. Then I open up the panel (best to find a large cardboard so you can slide under the glass to prevent breaking) and turn it on or test with a LED tester or my multimeter. You can also take a volt 9 battery and connect to pins to the opposite ends of the + and - ends to see if LED lights up.
        • FDray
          • Sep 2013
          • 3
          Re: Rca led50b45rq
          This is an old post, but I have found the fault of the RCA LED50B45RQ The fault is, if just one LED is shorted it will send a shorted shutdown signal to the main board to power down. I have never seen an led TV shutdown with just a 3.8 volt drop, I believe it is the amp rise that causes the fault. To find the ( maybe just one) LED, swap the known good strips (left or right side) that light even just a second before power shutdown, with the side that is unlit. when you move the bad strip to the side that lights it will fault. To find the bad LED use a 3 volt dc supply with pin probes ( this can be 2 AA battery's or one 3 volt button cell) and test starting from the connector end from + to - all the LED's down the strip. There are test points on both sides of each LED ( positive side is always to the connector end). There are video's online that show how to remove and replace smd LED's with a heat gun. The led's I use as replacement on most LED tv's are LED LUXEON NEU WHITE 4000K 2SMD from DIGI-KEY. Hope this helps someone to find this crazy shutdown fault in this LED TV.
          • FDray
            • Sep 2013
            • 3
            Re: Rca led50b45rq
            I forgot to add, this is the easiest LED TV to work on I have ever seen. Just remove the screws on the outside back all the way around. Then remove the screws from the T-Con/LCD connectors lift the back. The LCD panel is in the front case.
            • FDray
              • Sep 2013
              • 3
              Re: Rca led50b45rq
              I hope my reply wasn't too late, this is a great TV to be lost to a landfill. It's an easy fix with a 50 cent or less SMD LED. The whole LED strip on Ebay is around $15.00. Like everyone else here I always look for dim or dead LED's on the strip, This is not the case on this TV, the slightest amp rise on just a single LED cause's the main board to shut down. The way the LED strips are connected, if one led goes bad on a strip, the whole bank on that side shuts down. This makes it a "swap and try" method just to find the bad LED.
              • x_orange90_x
                • May 2015
                • 727
                Re: Rca led50b45rq
                Very very long delay I know, now that I've just gotten around to this one again. I pulled apart the panel and checked each strip of LEDs (which are all independent it appears). Only one wouldn't light. I removed it and after further testing found that only one single led is bad. I found a replacement on eBay, but I really don't know how important panel numbers and .1v really is.
                The strip I have in my tv is 3.6-3.8v 76-781m and my panel number is V500HJ1-P01-12v.
                The strip I found on eBay is 3.5-3.7v 74-761m and panel number is V500HJ1-PE8-12v.
                Both mine and the eBay strip have the exact same model number of IC-A-KJAB50D354.
                https://rover.ebay.com/rover/0/0/0?m...2F183749332905
                Would this be a compatible replacement?
                  • 12269
                  • U.S.
                  #168
                  Re: Rca led50b45rq
                  Should work, the model number you describe starting with IC-A is what to match up.
                  IC-A-KJAB50D507 will also work.
                  • x_orange90_x
                    • May 2015
                    • 727
                    Re: Rca led50b45rq
                    Just a quick update on this..I replaced the strip with the bad LED and its working great! Unfortunately this TV doesn't have a dedicated backlight setting so I can't turn it down... But I did set it to Power Save which reduced the backlights.
                    However, it's now working and that's great news since it's been sitting in my basement for about 3 years
                    Edit:
                    In reply to the previous comments about not knowing which strips contain bad LEDs...I took two 9v batteries and connected them together (staggered, as in + to - looking like a Tetris piece), then connected a positive and negative lead to the opposite ends and touched them to the appropriate pins on the LED connector. The LEDs in a single half-strip amount to about 21v and two 9v batteries is 18v and is enough to light up the strip. Each strip in this TV independent, so this method works for every individual strip.
                    • neilc6
                      • Nov 2015
                      • 1550
                      Re: Rca led50b45rq
                      You should be able to turn down the backlight in the service menu under Panel Settings.
                      With tv on, try menu-1-1-4-7 or source-2-5-8-0
                      I would set to 55 and check every input. You are guaranteed repeat failure with the backlights running at 100%.
                      • x_orange90_x
                        • May 2015
                        • 727
                        Re: Rca led50b45rq
                        Thanks for the tip! Menu 1-1-4-7 did it. It had 3 different backlight setting, one was just Backlight and was set at 50, the second was Normal Backlight and was set at 10, the 3rd was Power Save Backlight and was set at 50. 100 is actually least backlight and 0 is Max. So that means Normal was at 90%!!! I set all three settings to 45 which would be 55%, and it's plenty bright.
                        • ChristianBr01
                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                          by ChristianBr01
                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                          04-23-2025, 01:48 AM
                        • brithepi2k
                          Sony KD-65XE8596 no standby light
                          by brithepi2k
                          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                          cheers...
                          09-06-2025, 02:22 PM
                        • AleMonti
                          LG 55EG910V - no power and no standby light
                          by AleMonti
                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                          After checking the basics I did the following:
                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                          11-04-2024, 05:02 PM
                        • Kaar3l
                          Samsung QLED QE65Q7FNAT only standby light
                          by Kaar3l
                          TV: Samsung QLED QE65Q7FNAT
                          PSU: BN4400940A
                          MB: BN94-12832K
                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                          09-24-2024, 01:35 PM
                        • jasonbay13
                          Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                          by jasonbay13
                          picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                          am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                          12-01-2023, 09:55 PM
