LG 55UF6450 Static on screen but has sound and on screen menus work.
  • mattpd
    • Oct 2012
    • 302
    Turn this one on and it shows the LG logo with no problem, but then quickly shows static on screen. Sound still works and all on screen menus looks perfect. Tested on both over the air coaxial and HDMI.
    I assume something on the main board that is supposed to process the input signal is bunk. I would love to repair whatever component is bad on the main board rather than replace the board. Any idea what could go bad that would still allow the on screen menus to display properly?
    Main board # EBT64048902
  • CapLeaker
    Leaking Member
    • 8326
    Re: LG 55UF6450 Static on screen but has sound and on screen menus work.
    Why would you? Isn't there any warranty left on it?
    • Agent24
      I see dead caps
      • Oct 2007
      • 5036
      • New Zealand
      It would probably be pretty hard to narrow down the fault unless you find it's just a dead regulator or something. Aside from that I wouldn't be sure where to start.
      What I find odd is that on a digital input like HDMI, I don't think you should even see static if there is no input.
      You'd need a schematic, some good troubleshooting knowledge... and it might turn out to be bad soldering on BGA.
      Even if it's out of warranty, you are probably better off getting a new board.
      -David VanHorn
      • CapLeaker
        Leaking Member
        • 8326
        Maybe defective input switch ic
        • tkempjr
          • Nov 2016
          • usa
          mattpd did you ever get your problem corrected. I have the same tv with the same problem.
          • snoopybp
            • Mar 2017
            • usa
            I have the same problem also. I find some videos and it seems to be an often problem after the first year. LG has 1 year warranty,very interesting. did any one find out the problem yet. thank you
            • musadik
              • Jan 2015
              The problem is the main board video processing chip , I replaced the main board for few LG 4k TVs and that solved the problem , not sure if it is possible to fix the board without replacing it
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4459
                • Italy - Milan
                What means: "but then quickly shows static on screen"? I'm not english...
                • sushi1
                  • Aug 2017
                  • 32
                  • Egypt
                  What about the tv apps? like youtube or netflix? same static screen?
                  • JunkmanJimbo
                    • Mar 2017
                    • 194
                    I have one this model doing the same thing. I've seen where people put these boards in the oven to fix them, temporarily of course. So I removed the heatsinks from the chips and heated both chips with a heat gun but it did not help, nothing changed.
                    My question here is, is it possible the EEPROM could be bad and causing this problem, and if so has anyone replaced it with positive results? These boards are way overpriced, if you can even find one. I'm attempting to fix this tv to sell so I don't want to put a lot of money in it. Thanks in advance for anyone that can help.
                    • JunkmanJimbo
                      • Mar 2017
                      • 194
                      Is there anybody that can help me with this?
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5036
                        • New Zealand
                        Heating the chips with a heat gun is a stab in the dark. If you actually want to reflow the solder correctly you need to at least monitor the temperature to be sure you get the chip hot enough but not overheat it. You should probably also bake the board for a few hours at 40-50 Celsius first to remove any moisture so you do not 'popcorn' anything.
                        -David VanHorn
                        • Hamie
                          • Apr 2014
                          • 1383
                          Baking the board isn't going to fix it.
                          You need to replace the xd engine under the silver heat sink. reballing it won't work either. It needs to be replaced.
                          • JunkmanJimbo
                            • Mar 2017
                            • 194
                            Thanks Agent24 and Hamie. Hamie, do you know of a place I can get that XD engine? And, is there any special equipment needed to replace it, other than a hot air station, soldering iron, etc.? I have never replaced one of these before. Thanks again.
                            • rgeisler
                              • Jun 2018
                              • 3
                              Were you able to repair this board? I have the same problem with my 55uf6450 tv and I have attempted the heat gun method with no success. No replacement boards are currently available on Ebay for a decent price.
                              • Wilderone
                                • May 2018
                                • 76
                                Have just been through this with a 65UF680T, it's a common fault to do with the XDA engine BGA chip, I did try reflow with no success.
                                I replaced the board with an LG revised board which had a different part number.
                                You will need to quote the old number to your supplier & they should give you the number of the revised version.
                                As these particular boards have an issue with this fault I decided it was better to go with the revised board.
                                New board fixed fault.
                                • JunkmanJimbo
                                  • Mar 2017
                                  • 194
                                  I actually sold this tv to a tv technician that said he has seen this problem before with this model and it is the XD engine chips. He actually replaces those chips and he gets them from China. But, it is not an easy or quick job to replace these chips, especially without the proper equipment. I have seen repair services on Ebay for these boards for around $180 and a 1 year warranty.
                                  • rgeisler
                                    • Jun 2018
                                    • 3
                                    Appreciate the info. Does anyone know if there is a revised number for my board. It's an EBT64048902. I have seen the EBT64048903 listed as compatible for this model tv. Are these two boards interchangeable?
                                    • JunkmanJimbo
                                      • Mar 2017
                                      • 194
                                      The EBT64048902 board works in televisions with SVC code: 55UF6450-UA.AUSYLJR (printed on sticker on back of TV).
                                      The EBT64048903 board works in televisions with SVC code: 55UF6450-UA.BUSYLJR (printed on sticker on back of TV).
                                      Possible substitute boards for the EBT64048903: CRB35036401, CRB35036501, EBT64048902, EBU63478202. So, according to these substitute boards the EBT64048903 should work for you. I hope this helps.
                                      • rgeisler
                                        • Jun 2018
                                        • 3
                                        Thank you Jimbo
                                        • Kiberge
                                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                                          by Kiberge
                                          HI guys!
                                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                          04-22-2024, 11:28 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • Rozp
                                          70LE660U dark cloud or black screen with sound.
                                          by Rozp
                                          Hello Everyone,
                                          This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                          I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                          08-29-2023, 05:25 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • Audeze
                                          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                          by Audeze
                                          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                          Does...
                                          10-06-2024, 08:54 PM
