LE40M86BD switching off/on
    Re: LE40M86BD switching off/on
    Thanks, I put that info here also:
    https://www.badcaps.net/forum/showth...182#post634182
    • Dodgexander
      • Feb 2016
      • 34
      #42
      So I cleaned the motherboard and baked it for 10 mins. After testing it again it now turns off and stays off rather than turning back on. The motherboard also exhibited more discolouration too, see in this picture:
      Looks like its gonna have to be a new board after all. Running out of things to do with this one and if anything with it not turning back on the problems got worse!
      • Dodgexander
        • Feb 2016
        • 34
        #43
        Just thought I would update to say I fixed the issue by buying a replacement motherboard.
        It was a different board number from mine but was for the exact same model and size tv. All I had to do was plug it in and the TV has been working great since.
        Thanks everyone for their help getting this sorted.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #44
          Thanks for the update and glad your sets now working and another saved from the landfill can you remember what mainboard you installed as may help other members too if its easier too source.
          • Dodgexander
            • Feb 2016
            • 34
            #45
            Thanks Vince. I linked the board I bought from ebay above, but in case the link doesn't work too well in the future here is the details of the item:
            Samsung LE40M86BD ( BN41-00813B-MP1.0) AV Board
            The original board in the TV was: BN94-01264b
            As Alastair said in his post earlier the board is actually quite common and even if its from a different size tv, you can alter the size in the service menu.
            For clarity it was the motherboard/logic board I replaced, not the power board.
            • steviewonder
              • Dec 2013
              • 183
              • england
              #46
              This is becoming a extremely common problem-the issue is caused by the freeview dtv decoder ic needing a reball-and oddly enough it's the only IC under the tin that doesn't get very hot either.A wedge behind the board,near the top,can usually provide a few weeks of happy viewing,until the inevitable happens again.
              • Dodgexander
                • Feb 2016
                • 34
                #47
                Which IC under the heatsink plate is the freeview dtv decoder?
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #48
                  Sorry totally missed the link thanks for the details
                  • steviewonder
                    • Dec 2013
                    • 183
                    • england
                    #49
                    it's IC 3101, stI5105a
                    • noledud
                      • Dec 2013
                      • 413
                      • united kingdom
                      #50
                      To follow on from this there is a setting in the service menu that turns off the freeview which is a bit of bummer but it does stop the TV turning on / off
                      • Anj
                        • Jun 2018
                        • Scotland
                        #51
                        Just came across this thread when searching for a fix for this exact problem. Would like to try this option of turning off the freeview in the service menu first before opening it up. We don't use the freeview on the TV anyway, so worth a try!
                        I have managed to get into the service menu, but which option do I need to go into to turn it off?
                        • mlr
                          • Aug 2020
                          Just for posterity: If the caps in your le40m86 are okay but it still turns off out of the blue, your DVB-T chip might be overheating. This happened to me even while I haven't used DTV for years. To disable the chip and keep it cool, enter the service menu
                          Power off -> Info -> Menu -> Mute -> Power on
                          For navigation use only up and down!
                          Left/right changes the values or activates an entry (reset, calibration, don't go there unless you know what you're doing).
                          The DVB-T chip is disabled in sub menu 'Option Table(Service)'. The first option 'Ready' has to be 'ON'.
                          Exit the service menu with power off. After this TV/DTV should show 'Not Available' and the TV should stay on. Not very intuitive but it worked for me. All the details can be found in a thread on avforums
                          https://www.avforums.com/threads/sam...search.601553/
                          • marius19897
                            • May 2021
                            Solved: LE40M86BD switching off/on
                            Thank you x1000. This solved the 2nd issue with my Samsung LE40M86BDX TV. The modularity of this TV amazes me.
                            To be more specific, I had the issue with the capacitors, had them replaced but the TV still clicked after approx. 40 minutes and made a 2nd click approx. 20 seconds after that. Now it works fine.
                              03-31-2024, 02:12 PM
                              07-01-2024, 06:34 AM
                            • glovecaps
                              by glovecaps
                              11-25-2024, 04:23 PM
                            • Docus
                              Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                              by Docus
                              Hi everyone 😀,
                              I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                              To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                              Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                              1. I already own the exact same model, but its plastic chassis is badly damaged.
                              06-10-2025, 04:24 PM
                            • Archimedes
                              HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                              by Archimedes
                              Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                              Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                              Fans are spinning. Blindly could install windows11 and got the device manager...
                              07-30-2024, 05:14 PM
