LG50LN5400 Backlight Issue
  • sgabrie8544
    • Feb 2016
    • 10
    Greetings!
    I seem to have the "rare" (LOL) issue of the LED backlight being out also. TV powers on, Audio there, flashes quick and no pic. I can see it somewhat if i look on an angle and use a flashlight.
    I removed the back cover and disconnected the connector from the Power/LED power PCB to the LED strips and I still read NO DC voltage at the 2 outputs of that connector.
    Should I replace the Power/LED PCB or could it still be a LED strip?
    THX
    Steve
  • sordids999
    • May 2013
    • 2149
    Re: LG50LN5400 Backlight Issue
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      If you have no Dc at the Led connector with and with out Leds connected the Psu is at fault lol
      On Lg's backlight WONT fire with out mainboard present.
      • sgabrie8544
        • Feb 2016
        • 10
        Output to the LED strips is the small white connector I removed and measured for voltage to the LEDs.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          So have you got a voltage then ?
          • sgabrie8544
            • Feb 2016
            • 10
            No, I measured at the 2 test points right under the connector with respect to their individual gnds, with the connector removed. I got nothing.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Use chassis ground to measure the Led output.
              • johnboy1313
                • Nov 2012
                • 1959
                You've almost certainly got one or more failed LEDs inside the panel. You're going to have to open the panel to see which ones are out.
                  You have two sets of LED drivers on that board so you need to measure the DCV at the LED connector as requested.
                  • sgabrie8544
                    • Feb 2016
                    • 10
                    Power on, Led strip connector out, chassis gnd to both those LED DC test points = no voltage! How common can that be, I dont get it.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      The ground on the Led goes through a return line so best to use chassis ground and we needed to know. Now you need to get us a close image of the Psu.
                        Closed up pictures of the power supply-LED driver board? I cannot read the P/N on the barcode sticker and on the board? LG EAY62810801 (EAX64905501(2.0)) Power Supply / LED Board?
                        How about the readings on all 4 pins of the LED connector?
                        Are these boards used in your TV?
                        http://www.shopjimmy.com/lg/50ln5400-ua
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4951
                          • New Zealand
                          You say the screen flashes briefly at power on though?
                          I think you may need a dummy load for the PSU to test? It may not run normally with the LEDs unplugged either, as it may detect that as a fault condition.
                          -David VanHorn
                            'Power on, Led strip connector out, chassis gnd to both those LED DC test points = no voltage! How common can that be, I dont get it.'
                            Those two test points are the Cathode return side of the LED strings so youi not going to get any readings with the connector removed or if both LED strings have open circuit.
                            We need the DCV reading of the Anode side of the LED string which are fed by the boosted power supplies that is why we need the readings on all 4 pins (L+, L-, L+, L-) for easier determination the condition of the Voltage sources.
                            You will have to turn the TV on and off 4 times with the meter probe attached to one of the four pin at at time to catch the DCV when TV is first turned on and then after a few seconds later to see if the Voltage jumps up an drops down.
                            • sgabrie8544
                              • Feb 2016
                              • 10
                              Bought the TV new 18 months ago.
                              TE16A628108011322 (3.1)
                                LG EAY62810801
                                http://www.shopjimmy.com/lg-eay62810...pply-unit.htm#
                                Pictures provided by shopjimmy.
                                • sgabrie8544
                                  • Feb 2016
                                  • 10
                                  Power on, connector re-connected, measured from chassis gnd to both pins on connector marked LED +, each one read 90V when powered on, then trickled down to 0. Shorts in the LED strip?
                                    How about on the L- before the Voltage trickle down?
                                    BTW, what is the Voltage rating printed on the C257?
                                    It looks like the Boost converter circuits are working.
                                    • sgabrie8544
                                      • Feb 2016
                                      • 10
                                      Same thing, i held the probe on Led -, plugged in the cord, it shot to 98v then dropped slowly, other side jumped to 45v then dropped. thx for the help!
                                        So the readings of both L- are not the same if I read your reply correctly?
                                        If that is the case then you have LED problem.
                                        • Cornito
                                          Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                                          by Cornito
                                          Hello Team,
                                          I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                                          Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                                          Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                                          08-08-2024, 08:09 AM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
                                        • shellybelly
                                          Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                                          by shellybelly
                                          Back Story
                                          I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                                          So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                                          08-27-2023, 10:40 PM
                                        • Riananyaina
                                          MacBook A1708 820-00840-A backlight issue
                                          by Riananyaina
                                          Hello Everyone ,
                                          today I'm coming to you regarding my issue which is no Backlight .
                                          I have image on my screen but no light .
                                          The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
                                          First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
                                          Please find below few informations which can help for the analysis...
                                          04-24-2023, 05:03 AM
