TV Sony NSX-40GT1 (Power Supply)
  • torcuato
    • Dec 2013
    • 5
    Hi every, I have a problem with a Sony TV LED, Model: NSX-40GT1 and if anyone has the Schematic power supply, the power supply information is this: APS-277; 1-474-246-11; 1-882-772-11, Chassis GE7. Thanks.
  • martyparish
    • Dec 2012
    • 313
    Re: TV Sony NSX-40GT1 (Power Supply)
    Service Manual:
    • torcuato
      • Dec 2013
      • 5
      Thanks for the link martyparish, and I have that information, but DOES NOT HAVE the Schematic. Please anyone has the schematic ? Thanks.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Have you checked google ?
          http://www.shopjimmy.com/sony-1-474-...-nsx-40gt1.htm
          http://www.ebay.com/itm/Sony-NSX40GT...-/201114121449
          http://www.ebay.com/itm/SONY-Power-B...-/131524631148
          What is it not doing?
          • torcuato
            • Dec 2013
            • 5
            Thanks for the link (Telford Television) ReeceyBurger123; there were nothing that power supply. Also thanks to budm by links to shopjimmy and ebay, TV has not damaged the resistance "R6536" as mentioned in ebay to buy the repair kit. Thank You for Your help. If anyone has the schematic of the power supply they are grateful.
            • Hardfacer2
              • Sep 2016
              • Usa
              I have potentially the same problem with Sony NSX-40GT1, 4.5 yrs. old looking for repair manual ( service manual available not needed to troubleshoot) which seems not to be available on any sites. Issue with tv was it went black & no sound, two blinking red lites ( 5 sec pause) where normally green. Checked power supply output @ 13 pin connector, only standby pin had correct 3v. No output voltage on other pins ( some are grounds), caps look good without testing, could transistors be failed or possible a voltage regulator? I can not find schematics for this tv. I do not think the tcon board is bad, main board not sure if ok either.
              • jdaproduca
                • Dec 2006
                • 8
                Sony GE4A Schematic is very close to this power supply.
                • nuala
                  • Aug 2013
                  • 37
                  dead and 2 blinks.....REPLACED SHORTED FETS Q6101 & Q6102 (2SK4084) WITH (2SK3563) AND REPL OPEN RESISTER R6536 WITH .47 1/2 WATT SONY PN 1-220-926-21.. SAVED NEEDING TO REPLACE THE SMPS
                  • jfcurran
                    • Sep 2018
                    • 9
                    Thank you! I had the same blink pattern and this worked great for me. I ended up using TK5A50D MOSFETs as they were the recommended replacement for 2SK3563. I could not source the Panasonic part and used a 1/2 watt fusible resistor (Vishay NFR25H0004707JA500)
                    Thanks again!
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
                    • CMCM
                      Russound CA4 Power Supply Repair
                      by CMCM
                      Hello Everybody,
                      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                      The outputs marked 12v and 20v are all measuring only 1v.
                      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                      The capacitors physically look clean (no bludgesor leaks) and...
                      07-03-2025, 01:12 PM
