Philips 32PFL6606H/12 problem
  • tempro
    • Dec 2015
    • 15
    • bulgaria
    First of all, happy new year guys!
    So the model of my TV is Philips 32PFL6606H/12. When i turn the TV ON, it has no picture but the sound is ok. When i flash the screen with a flishlight i can see some silhouettes.If i let it work for 3 or more hours the picture appears and it works fine until i shut it down again.I haven't opened the TV or did anything to it at all yet.I red alot for problems like this but i can't seem to find anythink so i want to ask u guys.
    Thanks in advance!
    Cheers
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Philips 32PFL6606H/12 problem
    Checks inverter voltages ?
    • tempro
      • Dec 2015
      • 15
      • bulgaria
      So i checked the voltages here(as i shown on the picture).FIrst pin should be 3.3V , fifth and sixth 12v and 13th pin 24V. When I turn the TV on all the voltages are good,but after 1min all except the first(3.3V) give me 0V.Maybe there is a problem with the power supply board ?
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        I think its a powersupply problem , well at least the inverter in the PS. Can you give us a close up of the PS?
        • tempro
          • Dec 2015
          • 15
          • bulgaria
          supply
          • tempro
            • Dec 2015
            • 15
            • bulgaria
            Sorry,my mistake. The TV was on stand by when i checed the voltages. When I turned it ON from the remote, all the voltages were fine! So I guess that is not the problem.What else can I check?
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              You need to search for the service manual. If you can find it then i will search for it tomorrow
              You don't have any backlight , so either the lamps are dead or your missing the bl_turn on signal.
              • tempro
                • Dec 2015
                • 15
                • bulgaria
                I found the service manual and I am reading it now, but i don't think the lamps are the problem because after 3 hours the TV starts working fine. How can i check if i am missing the bl_turn on signal? Should i try running the TV in SMD mode so I can check the errors?
                • tempro
                  • Dec 2015
                  • 15
                  • bulgaria
                  So the TV was set on a stand that was screwed to the wall.When I removed the stand and set the TV on the original holder that was not on the wall it started working fine for 2-3 days and after that it started to requere 20-30 min and more to start working.It was a black screen (u can see silhouettes with a flash light) and after 20-30 min when i shut it down and on again it worked fine.And now it needs 2-3 hours untill you can see any picture and the picture is on the screen for 20 min and the TV shuts down automatically.
                  • Nwanko
                    • Sep 2019
                    • Slovenia
                    Hello, i have the same TV, simular issue, when i turn on the tv it shows the phillips sight for a second then the backlight turns off. I still see the picture is i shine a flashlight in the screen, alson when i turn it on and the backlight shows i hear a squicking sound and as soon as the backlight turns off the squicking is gone. What could be the problem here?! Please help!
                    • janos6662000
                      Philips 47PFS7509/12 LCD TV problem
                      by janos6662000
                      Hi
                      I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                      When i applied cable signal to check image, i had normal picture, but TV was restarting.
                      I downloaded original firmware and applied the update, but the problem remained.
                      From a colleague i received a "factory package software" which is a lot bigger.
                      I made another firmware update, but still did not solve the problem.
                      Somewhere on the way the error got worse, because at the moment the...
                      08-12-2025, 12:54 PM
                    • courtcircuit
                      Philips HTS8000 home cinema noise problem
                      by courtcircuit
                      Hello
                      I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                      Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                      Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                      I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                      Removed each of tyhe boards
                      02-08-2025, 08:22 AM
                    • theone111
                      by theone111
                      3. Problem: TV shuts down
                      07-22-2024, 10:36 AM
                    • bohaboha
                      PHILIPS 32pfl3403d Flat-panel TV Upgrade Assistant problem
                      by bohaboha
                      Hi trying to update my Philips cause in retail mode not possible to get out from it i get this message in update site : Error message: no data exception. Your reference: Request ID (server_1930105)
                      how to fix it thanks
                      02-05-2025, 09:23 PM
                    • atkallu
                      Philips 58PUS8545 t-con problem or something else ?
                      by atkallu
                      Hello
                      I have a Philips 58PUS8545 which have a vertical moving lines on screen and it is flashing white vertical lines like a every 3-4 seconds.
                      See the attached image.
                      I removed left side flex-cable from the t-con and then there was half screen sharp and correct image and other half was white.
                      But when I removed the right side flex-cable then half of the screen was white but other half was white and above the white there was vertical lines on half of the screen.
                      T-con two flex-cables have been changed to cross but nothing changed, so it is not due those...
                      01-13-2025, 11:23 AM
