Vizio TV E3D420VX, No picture, power led on+blink 1time+V logo shown=>turn off
  • djju
    • Dec 2015
    • 40
    • 미국
    https://youtu.be/T482qH4Nmj8
    https://youtu.be/RfyKGEeoy0k
    Hi, I have a Vizio TV E3D420VX and it has symptom as below:
    1. When I press power button, backlight on, power white light on and Vizio V logo is on the screen
    2. Logo goes off, power white light blink one time.
    3. Power goes off by itself and doesn't come up
    4. Same symptom in every time when I press power button.
    Is it an exactly same symptom as you?
    Can it be solved by replacing the power board?
    Or, do I have to replace the main board??
  • sordids999
    • May 2013
    • 2158
    Re: Vizio TV E3D420VX, No picture, power led on+blink 1time+V logo shown=>turn off
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • djju
      • Dec 2015
      • 40
      • 미국
      Thank you for your comment. I have uploaded video link of symptoms.
      The noise in 1st video clip isn't from TV, just come from my wife...maybe...
        DELTA DPS-198BP (Vizio 0500-0407-1030)
        We need the dcv reading on the connector CN201 AFTER the lights go out.
        Make sure to put down pin names of each pin follow by the DCV reading.
        http://www.shopjimmy.com/vizio-0500-...pply-unit.htm#
        Pictures provided by shopjimmy.
        • djju
          • Dec 2015
          • 40
          • 미국
          The check result is updated as picture file. (please refer the attached file)
          It has CN201 voltage check, LDO test result, STEPDOWN, and Power MOSFET result. (lt looks fine)
          I did visual inspection after taking these board off.
          I didn't see any faulty part on power supply & main board both. (leak, swallowed CAP or burn part)
            OK, I can see that the PS-ON is gone when the backlighs and the Power LED go out.
            'P11 PSON 67.1mV 2.84V -> 67.1mV'
            So some how the main board just stops sending out the command signal (the BL-ON (ON/OFF) and DIM are also gone). So it is main board problem or something sends the signal to tell the main board for the TV to turn off.
            You may want to try disconnecting all other boards that are connected to the main board one at a time to see if the PS-ON will stay present. I wonder the control panel switch is doing this or the IR board. It acts like some one turn off the TV
            BTW, so the TV never stays on long enough for you to see the Video or sound?
            History of this TV?
            • djju
              • Dec 2015
              • 40
              • 미국
              History of this TV?
              Hi, Bud
              I understand what you said. Mainboard won't turn on the BL-ON or something make the mainboard send a command to cut the power for protection.
              But I can't understand the which part makes this symptom.
              At first, I think an impedance of some part might be almost short to GND, so PMIC sends to command to cut the power source. But no fault part on the main board by visual inspection.
              I already did it. Test with disconnection (1) IRDA board, (2) Speaker wire, (3) WIFI daughter board. The symptom was same.
              Yes, the TV never stays on long enough for me to see the video or sound after it has gotten a problem.
              Almost 1 month ago.
              • djju
                • Dec 2015
                • 40
                • 미국
                Originally posted by djju
                Hi, Bud
                Almost 1 month ago.
                And I check the fuse.
                Mainboard F1, F2 is good. It gives 5V and 12V
                Power Supply F1 is good. It shows 0 ohm.
                • djju
                  • Dec 2015
                  • 40
                  • 미국
                  Hi Bud,
                  Do you kmow which part is PMIC on the main board?
                  Or, do you how overload protection logic works on this TV?
                    The over load protection circuits are on the power supply board, the power supply board may send the error signal to the main board telling there is problem then the main board goes into shutdown.
                    One pin I do not really know what it is really for is pin 13 'LAMP' I do not know if it should stay HIGH >2V for normal, or HIGH = abnormal, or LOW (<1V) = Normal or not normal.
                    You can pull just pull that wire that goes to the power supply board and connect that wire to GND so the main board will see LOW signal feeding it, see what happen when you turn on the TV. If it does not change then you can pull that wire HIGH using 1K resistor between that wire and the STBY 5V and see what happen.
                    • djju
                      • Dec 2015
                      • 40
                      • 미국
                      Re: Vizio TV E3D420VX, No picture, power led on+blink 1time+V logo shown=&gt;turn off
                      Thanks Bud,
                      You mean, lamp signal is the indicator that let the main baord know something wrong on the power supply board?
                      probably, power supply might have the problem and it makes main board cut the power? Power supply board may have to be changed?
                        So sorry, i forget that you have power supply inverter combo board, so you need to do the experiment on that 'LAMP pin.
                          BTW, we still need to see the whole back side of the board so we can see how all the boards are connected together.
                          • djju
                            • Dec 2015
                            • 40
                            • 미국
                            Thanks Bud,
                            Is it okay that 5v to LAMP instead of 3.3v? Is Logic voltage level okay?
                              That is why you have to use 1K resistor, never hook up directly without the resistor. 1K will limit the current to only 5mA.
                              • djju
                                • Dec 2015
                                • 40
                                • 미국
                                Hi Bud, Thank for your kind feedback.
                                My question is not current, but voltage.
                                You mean, LAMP might be an input signal to the main board. Is it right?
                                Then, the logic input level of main board should be 3V because when the backlight is on for a while, its level is 3.19V. After that, it goes to GND after backlight off and power led blinking 1 time.
                                As I understand, you said, LAMP signal changing should tell to the main board there is something wrong.
                                Then, LAMP should be input to the mainboard and we have to keep signal compatibility (3.3V, not 5V)
                                Just only connection from 5V----1K----LAMP is the 5V pull-up. (even though its current is very small)
                                Is it input to the main board or the power supply?
                                  In put to the main board,
                                  Just only connection from 5V----1K----LAMP is the 5V pull-up. (even though its current is very small). That is correct, you must remove the lamp wire that goes to the power supply board first then use the resistor between that end of the wire and 5V. We are feeding the main board.
                                  Or you can use 3V battery if you want.
                                  Or you can try without having the wire connected to anything, it may have pull-up resistor on the main board already, you can verify that by keeping the meter on that wire you remove.
                                  • djju
                                    • Dec 2015
                                    • 40
                                    • 미국
                                    Hi Bud
                                    This picture is back side of tv. Nothing wrong of connection.
                                    • djju
                                      • Dec 2015
                                      • 40
                                      • 미국
                                      Thank you, Bud. You mean,
                                      1. Cut wire between (main)LAMP------:scissor:-------(power)LAMP
                                      2. Test 1.
                                      (Because (main)LAMP may be 3V pulled up), 3V-----??ohm----(main)LAMP inside main board
                                      3. Test2.
                                      Wire (main)LAMP-----(+(1.5V+1.5V battery)-)------(main)GND
                                      4. Test3.
                                      Wire (main)LAMP-----------1117 3.3V STBY out
                                      Is it correct?
                                      However, I can't still understand your feedback that you must remove the lamp wire that goes to the power supply board first then use the resistor between that end of the wire and 5V. We are feeding the main board.. It is still 5V pull up. It could cause voltage compatibility problem.
                                        Lets make it easier, disconnect the cable between the power supply board and the main board, then use 1K resistor between the PS-ON pin and the 5VSTBY pin of the power supply board, then use another 1K between BL-0N and 5VSTBY.
                                        Power up the board to see if the backlights will stay on, if not use another 1K between DIM and 5VSTBY, if the backlights do not stay on then you have problem with power supply/inverter board.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
