I know the answer is here!
  • iownme
    • Dec 2015
    • 7
    Because a year ago i stumbled upon it here but didnt need that info then.
    What i need to do is fool a flatscreen into thinking its receiving an input so that
    The auto turn off is disabled.
    I make tables out of flatscreens with the lcd screen removed.
    I want the tv to stay on and illuminated.
    I read here once that somehow connecting 2 of the various inputs together would acomplish this, but i cannot remember how or find that thread.. Grr
    Obviously as there is no lcd screen i cannot access any menus on the tv.
    I hope i made this clear (as its an odd concept/question) let me know if you require any more info.
    Currently the tv shuts down after about 10 mins of no signal
    • 31196
    Re: I know the answer is here!
    on the invertor or psu/invertor board is a signal pin that turns the backlight on, you just need to link that to one of the power pins - usually 3.3v or 5v
    if you want a better answer you need to post pcb foto's or atleast the make & model of tv you started with.
    • mariushm
      • May 2011
      • 3799
      You can buy univeral CCFL inverters from eBay or other online stores, to go around all the electronics in the monitor.
      Here's an example: http://www.ebay.com/itm/1pc-4-Lamp-B...cAAOSw7PBToAJa
      The one in the eBay link above is what I actually have in front of me, 3 of them.
      It has a very simple pinout...
      pins 1 and 2 are voltage which can be anything between 10v and 30v but anything higher than 20v is not needed, ideally one would use 12-15v
      pin 3 is on/off as in if you send anything between 2v and 5v on this pin, it turns on
      pin 4 is adjust brightness as in put a potentiometer between ground and 5v and the wiper on that pin and you'll have a way to adjust brightness. connect to 5v directly for max brightness
      pin 5 and 6 are ground
      The IC used is DF6109a and the datasheet is available on the net (though in chinese) : https://cdn.badcaps-static.com/pdfs/...36aad6f023.pdf
      So you basically need some voltage, let's say 12v, and 5v which you can get from 12v using a 7805 linear regulator or a separate 5v power supply.
      If you want to make a desk using several lcd panels, you could repurpose an old computer power supply which would give you both 12v and 5v, or reuse a 12v laptop power adapter.
      For LED backlight based panels, I guess you would have figure out which wire is the "enable" or "on/off" wire, you would see 0v when the backlight is off and something like 3.3v or 5v all the time when the backlight is on. With a multimeter, it only takes a few seconds.
      You can then remove the control from the display board by cutting that wire and connecting the wire directly to 5v or 3.3v or whatever voltage it used to be on that input pin/wire.
      • iownme
        • Dec 2015
        • 7
        So far... Complicated!
        Lol
        The tv is a working tv, it just does not have the lcd screen, i use stained glass on top of the white plastic "diffuser/screen" which illuminates nicely as a table top when turned on.
        The only issue is that the tv (like all tvs) turns off after 10 mins or so without any input.
        A poster on this forum a while back needed to do something similar (he was a lot more knowledgable than i) and the thread involved suggested connecting something like the rf input to an rca style video in input or output. i don't remember which input to output connection was suggested, there also may have been a resistor or diode involved inline.
        Im not an engineer, but im smart and can follow instructions.
        Does this sound doable or just a myth?
        It involved just hacking an rca cable and rf cable together, no need to go inside the tv at all and would work with any tv
        • iownme
          • Dec 2015
          • 7
          here is what it looks like turned on
          • iownme
            • Dec 2015
            • 7
            Turned off
              • 31196
              you dont need the tv board inside,
              just the power supply and the lamp driver - if it's not built into the power supply.
              • iownme
                • Dec 2015
                • 7
                Other than losing a some weight there is no need to remove anything inside.
                I make these tables by repurposing working flatscreen tvs with broken screens.
                As i keep all the internals it is still possible to use the remote control for power and can still hook up an mp3 player and use the tvs amp and speakers and remote for volume.
                So a way to trick tv into thinking it has video input would resolve having to turn it back on every 10 mins
                • iownme
                  • Dec 2015
                  • 7
                  The idea is... Instead of having a lamp on a table.. The table IS the lamp ;@)
                  • budwich
                    • Jul 2015
                    • 3097
                    you can probably just switch the input on the tv to ANT / OTA and it will be basically on with "weak signal" message if you had a "panel".... I don't think the tv would be able to tell that there is no signal. At worse, just add a "strand" on coax for an "antenna".
                    • wnlewis
                      New wire for my RDE3340 Whirlpool electric range
                      by wnlewis
                      OK. I got the rocker switch figured out thanks to the good advice on this forum.
                      Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                      This is a Whirlpool RDE3340 electric range.
                      The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                      Where may I find parts...
                      01-08-2025, 11:21 PM
                    • emeskay
                      Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                      by emeskay
                      We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                      08-06-2024, 07:13 AM
                    • technicalspecialist
                      Vintage fan repair, copper wire question
                      by technicalspecialist
                      I currently have a customer's vintage fan on the work bench to repair.
                      It uses an induction motor with 4 poles. One of the poles is open.
                      I couldn't find the break so i cut off the original wire.
                      I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                      I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                      The enamelled copper...
                      03-16-2023, 12:54 PM
                      Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                      by sam_sam_sam
                      I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                      I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                      12-16-2023, 08:39 PM
                    • kalemaroni
                      Dell DC Brown wire
                      by kalemaroni
                      There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
                      08-26-2025, 10:10 AM
