MP 42HC56 SINOTEC 42 lcd
  • battlecat
    • Mar 2010
    • 18
    • South Africa
    Good evening all.
    Anyone came across this this PSU board ?
    No bad caps (wow) but dead.
    all switch mode transistors test 100%
    had 1 dogey cap .
    and it is not powering up , not even the separate psu on the board that from tracing seem to be the standby psu which in turn switch on the rest of the main board.
    i have my suspicions on ic :n501 (Q110 wich is a FPS chip from fairchild semi)
    ordered and waiting from RS components..
    BUT would like some thoughts around it..
    School fees paid as everyday is a learning curve.
    Re: MP 42HC56 SINOTEC 42 lcd
    What DCV do you get between the two legs of the main filter cap in the primary side?
    BTW, so no DCV on any one of the connector in the secondary side of the circuit at all?
    • battlecat
      • Mar 2010
      • 18
      • South Africa
      Hi
      320v dc it's actualy have 2 filter caps,
      one for the 24v supply and a 2nd for the standby..
      i have attached a bottom pcb view..
      I highly suspect that fps ic
      • CapLeaker
        Leaking Member
        • 8325
        Sounds like your PFC isn't working
          Originally posted by battlecat
          Hi
          Only one filter cap C533 220uf 450vdc.
          VPFC is used for running the 24V and the standby power supply, when in standby mode, the standby power supply will run on 330VDC (no boosted Voltage yet until PS-ON is present from the main board).
          What DCV do you have on IC N501 VCC pin 2 and GND pin 1? C513 is the startup/running cap for the IC N501.
          The PFC and the 24V will not function until the STANDBY power supply section works first.
          • CapLeaker
            Leaking Member
            • 8325
            Sorry... I thought PSon is there, but 320V on the filter caps (240V rectified) = no PFC
            • battlecat
              • Mar 2010
              • 18
              • South Africa
              OK so here is a bummer the FSQ110 from Fairchild is discontinued ...grrrrr...
              Had a look at their datasheets ""with my extremely slow internet connection""
              Followed the ""rabbit "" and pointed me to the FSL206MR which I ordered via RS-Online... and seem there is a couple of light mods needed to get this chap working in there...
              Seem I don't get any voltage on pin 1 and 2 like BUDM mentioned .. not even with the FSL206 in place ...pin 5 is the point to which the cap at pin 2 and 1 get charged up to switch on the Ic N501.. ( maybe some experimenting with the resistor values at pin 5)
              Would it be possible if someone could maybe check up on the FSQ110 versus the FSL206 if I made the right choice there?
              Thanks for the advice and replies thus far
              • battlecat
                • Mar 2010
                • 18
                • South Africa
                HERE is the really bad news .....
                No idea how did manufacturers still went ahead and use these devices if this was happening
                • SonOfAnarchy ZA
                  • Dec 2016
                  • 22
                  • South Africa
                  Hi guys. Sorry to revive this old thread I''ve also got the same supply and it died as well. blown fuse and D506 was dead short everything else seems to measure correctly I cant seem to find that specific diode but put in a fast recovery diode with similar specifications but the supply is still stone dead I suspect N507 (l6563) to be faulty but not sure was the problem ever resolved on this fault?
                  • SonOfAnarchy ZA
                    • Dec 2016
                    • 22
                    • South Africa
                    I have 7vDC on N105
                    • SonOfAnarchy ZA
                      • Dec 2016
                      • 22
                      • South Africa
                      and 280vDC across the two filter caps
                      • battlecat
                        • Mar 2010
                        • 18
                        • South Africa
                        Hi , check the small electrolyitic cap next to the N105... sit close to pin 1
                        DON"t even check it just replace it.. with exactly the same value.. anything higher or lower messed me around..
                        That will switch on the chip.
                        Also watch out for the HT boards on this tv Master & Slave...
                        FSL206MR that I bought was actually totally wrong
                        • SonOfAnarchy ZA
                          • Dec 2016
                          • 22
                          • South Africa
                          I replaced that cap with no luck. i found a 16v zener diode in short (D502) replaced it but no luck is it possible N501 is faulty?
                          • battlecat
                            • Mar 2010
                            • 18
                            • South Africa
                            Is this Power supply the exact same one as posted in the picture of my thread?
                            Having blown zeners sounds more that this TV had a direct lightning strike.
                            I have been unsuccessful to source the correct chip located at N501 and only found similar ones that works but not in the way intended , hence my discovery of the cap that caused it to not switch on..
                            My last resort was to build a power supply, to supply power the other 2 that this 1 starts up..
                            FSQ110 versus the( FSL206 this particular chip works in a pulse mode effect) RS is closer to you as you are in JHB.. order this and try it in the old N501's place.. At least it would give you a good idea what to look for.....as it does work without any mods.
                            Otherwise suppliers they still have stock of this TV's PSU and CFL driver boards checked 2 months ago..
                            • SonOfAnarchy ZA
                              • Dec 2016
                              • 22
                              • South Africa
                              Yes it is the exact power supply. i Have ordered that specific chip from China will let you know if it works out
                              • SonOfAnarchy ZA
                                • Dec 2016
                                • 22
                                • South Africa
                                which supplier did you contact? i have received the correct parts with no luck still dead as a door knob
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  check r597 r598.
                                  thats your startup source.
                                  what voltage do you have pin 2 and 5 of n501?
                                  • SonOfAnarchy ZA
                                    • Dec 2016
                                    • 22
                                    • South Africa
                                    Originally posted by kc8adu
                                    check r597 r598.
                                    Pin 2 Has 10VDC
                                    Pin 5 Has 184VDC
                                    R597 and R598 measure 68kOhm according to the circuit diagram they should be 47KOhm
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      If D502 had gone short then the Opto N506 may also have been damaged. I would certainly check it.
                                      What DC voltage do you have on D505.
                                      • SonOfAnarchy ZA
                                        • Dec 2016
                                        • 22
                                        • South Africa
                                        2vDC anode
                                        0v cathode
                                        n506 has been replaced
                                          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 05:30 AM
                                        • Natob82
                                          Micro Momentary Push Switch?
                                          by Natob82
                                          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                          12-21-2022, 05:22 AM
                                        • grimacelord
                                          NEC TurboExpress On/Off Power Switch Replacement Help
                                          by grimacelord
                                          I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                                          I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                                          I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                                          11-09-2023, 09:49 AM
                                        • SluggerB
                                          Help making a switch work the opposite way with a relay
                                          by SluggerB
                                          I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                          I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                          It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                          02-07-2025, 07:57 PM
                                          Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                                          by sam_sam_sam
                                          Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                                          ( needs more cam circuits for the machine to work correctly again )
                                          https://www.ebay.com/itm/275321870186
                                          To
                                          3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                                          ( not 4 positions but the right amount of cams circuits )
                                          https://www.ebay.com/itm/274660439950
                                          I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                                          03-18-2023, 05:12 PM
