NEC TurboExpress On/Off Power Switch Replacement Help
  • grimacelord
    • Jan 2017
    • 380
    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need. I initially searched for "NEC TurboExpress power switch" and didn't come up with anything, so then I started looking for a generic replacement from Mouser or DigiKey, but the options are so vast and there are tons of different types like SPST, DPST, etc.
    This switch only has an ON or OFF position. The switch uses 10 pins total, with the 6 "middle" pins being the ON/OFF and the leftover 4 on each "corner" are just ground for the shield that goes around it. Through-hole and right-angled.
    Here are some photos of what I am working with. I'm hoping someone can help me figure out which replacement switch I can use to get this thing turning on/off again. If you need any additional info or need me to measure something, I will be glad to do so.
    Thanks.
  • petehall347
    • Jan 2015
    • 4439
    • United Kingdom
    Re: NEC TurboExpress On/Off Power Switch Replacement Help
    search for slide switch right angle 2 position and find one same size
    • grimacelord
      • Jan 2017
      • 380
      I have, but what is confusing me is the circuit type DPST, SPST, etc. Not sure which one I'm supposed to be using
      • petehall347
        • Jan 2015
        • 4439
        • United Kingdom
        kooks to be on on .. centre pins being common .
        • grimacelord
          • Jan 2017
          • 380
          Just wanted to come back and update this. I purchased the following switch from eBay: https://www.ebay.com/itm/275901936717 and it worked. I did have to modify the pins a bit to get it to fit, but it works. Just updated for anyone else who might read this in the future. Thanks!
            Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
            This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-06-2024, 05:30 AM
          • shovenose
            Netgear JGS516PE Switch Fan Replacement
            by shovenose
            I got a free Netgear JGS516PE PoE switch and it works fine but the fan makes a grinding sound.
            It uses a 12V 3 pin fan with a non standard pin out. So I took a Noctua fan and moved the wires around in the connector to make it work.
            Unfortunately, the fan spins for just a couple seconds before it turns off and the Fan Fault LED comes on.
            I think it's stupid they designed it to stop powering the fan when it detects a fault but I guess that's what they chose to do.
            Instead of spending $30 on the correct replacement fan, does anyone have a clean...
            12-12-2024, 03:24 PM
          • Tomylee
            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
            by Tomylee
            Sorry for the person who’s going to read all this !
            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
            07-11-2025, 11:52 AM
          • Travis Thomas
            Replacement LED switch for Powercolor Hellhound
            by Travis Thomas
            Hey all,
            So I bought a second hand Powercolor Hellhound Spectral white 6700 XT a while back. The only problem with it is that the LED switch on the PCB is broken. Anyone have a PN I can use to solder in a a replacement? Also, a Boardview or schematic would be good too. Thanks
            05-11-2024, 09:38 AM
          • Natob82
            Micro Momentary Push Switch?
            by Natob82
            Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
            12-21-2022, 05:22 AM
