Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
    • Jul 2011
    • 6055
    Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
    ( needs more cam circuits for the machine to work correctly again )
    https://www.ebay.com/itm/275321870186
    To
    3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
    ( not 4 positions but the right amount of cams circuits )
    https://www.ebay.com/itm/274660439950
    I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around and I might have to reset the cams for the right configuration like the original selector switch was
    Here is the video that shows how it comes apart
    https://www.youtube.com/watch?v=QCU6gZwtqVU
    I am working on a very old shear machine that the cam selector switch went bad
    ( no longer available anywhere )
    The original switch is not repairable unfortunately because someone tried to repair it and some of the spring were lost for the contact to the cam
    I watched a video that showed how this switch comes apart and I see no reason why it should not be able to modify it so I have enough circuits for the controller
    This is the second machine that I have to modify the controller hook up parts in some way because the parts no longer available same manufacturer different model number ( the other machine was bad relays on secondary controller board went bad the part no longer available either ) got machine working again with modified board
    Has anyone else tried to do this if so how did it turn out did the device work after it was modified
    In either case they did not want to buy another new machine to replace the non working machine wanted to be repaired if possible with the understanding that it might not exactly work the way that it did originally but it is controllable and safe to use with this understanding in both cases it is a very small machine shop or metal working shop
    • Jul 2011
    • 6055
    Re: Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more c
    Things are not going very well finding a switch configuration that is even close to what I need and trying to configurative one is even more challenging than you would think it would be
    But there might be hope if this eBay seller that had a customized service can come through then I might be able to fix this machine with out having to resort to relay logic which I am trying to stay away from
      • Jul 2011
      • 6055
      Well the cam selector switches finally came in the right configuration from the eBay customize cam selector switch services but the first set was wrong but the seller did finally send me the correct configuration the second set
      I was able to keep both sets and I was not charged for the second set but I did have to get ebay involved to a certain extent about the refund return request because at first the seller wanted me to pay for it again this is the part that ebay helped me with
      The cam switch that they sent me originally I have a use for it in my new shed because it is rated for 600 volts at 63 amps because this switch configuration is meant for phase reversal but not configured like most of the ones that I have seen before it actually has a set of contacts for each phase not like most of them where you only switch two sets of wires and you have the reverse function on a motor and it has “1” “0” “2”
      I am going to use this to have two separate 120 volt circuits or 240 volts so I can use only one set of breakers for this setup instead of two sets of breakers
      This cam selector switch has eight cams with a total of 32 terminals connections some of the connections are not going to be used the reason for this was because there is standard configuration for 32 terminals connection but the configuration was not exactly what I needed so because they come in a eight cam selector switch I just had them changed a couple of cam to make what I needed
      I thought I would update this post
      So now I have to put this cam selector switch in the machine but I will have to silently modify the wiring to accommodate this type of cam selector switch which is not like the original one so I might be at for a little while I just have to make a bunch of jumper wires to accommodate the way this switch is
      Position “0” = no connections
      Position “1” = 2 cam = 8 terminals on the machine only use one set of contacts
      Position “2” = 3 cams = 12 terminals on the machine uses 3 sets of contacts
      Position “3” = 3 cams = 12 terminals on the use the same 3 sets of contacts as above and one that is different from the above one and because of the one that is different I have to isolate it from the other ones above
      This might be a little bit confusing but really it is once you follow the wiring diagram then you understand why it was done this way
      Standard cam switch configuration is or position “1” “2” “3” “4” but uses the same configuration as below
      Position “0” = 2 cams = 8 terminals
      Position “1” = 2 cams = 8 terminals
      Position “2” = 2 cams = 8 terminals
      Position “3” = 2 cams = 8 terminals
      There is another configuration for a 32 terminal cam selector switch but this seller does not post the switch configuration so who knows what configuration it has
      If I can remember to take pictures of the switch when it is wired up correctly I will show you what I am talking about it was difficult to find the right configuration cam switch for this machine
        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
        09-06-2024, 05:30 AM
      • DrDos
        Alps vintage wafer switch 2 pole 12 position
        by DrDos
        I have the schematic of the kenwood I am working on. It shows the wafer switch which is the on/off - A speakers - B speakers - A + B speaker switch. I don't trust the wiring
        because it doesn't seem to add up for me. If I can identfy at least one of the pins I should be able to rewire it correctly or at least make sure it currently wired correctly but I don't know how to find this out. Pictures are in my thread "trying to refurbish and repair my kenwood kr-6030. I would appreciate the help.
        08-31-2025, 05:03 PM
      • jm1234
        microwave rotary switch contacts go bad requently
        by jm1234
        Hi, I have a 11 year old microwave Siemens and the main function selector switch is a rotary type. It goes bad every few months, there are carbon (?) pads and the metal contacts that drive on them create concentric circle tracks from the residue.
        I clean the tracks and the metal contacts with IPA and it works few months again. Here you can see the contacts:
        Once I tried this contact cleaner: Kontakt 60 https://www.tme.eu/Document/3f58feb2...TAKT60.DTE.PDF, but it only lasted few weeks, so probably not a good choice.
        Is there any...
        05-04-2025, 10:45 AM
      • CdDvdFlash
        Help to Choose Rotary Switch for Audio Switch Box
        by CdDvdFlash
        I have a project that is an audio switch box I have used an old PC parallel switch box which is 3 inputs with 1 output, I have stereo RCA jacks for the 3 inputs and 1 output and its working well using the original rotary switch but now I need to add another rotary switch for another 3 audio inputs and 1 output but I dont know what type of rotary switch to get. It needs to have the ability to select 1 of 3 positions for the three audio devices and then have 1 output and be able to handle left/right/ground for the stereo RCA....
        08-03-2020, 05:37 AM
      • Natob82
        Micro Momentary Push Switch?
        by Natob82
        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
        12-21-2022, 05:22 AM
