Help making a switch work the opposite way with a relay
  • SluggerB
    • Aug 2020
    • 747
    • US
    I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
    I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
    It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats, switch goes open, pump turns off.
    Would I use some sort of external relay or something? The wires will be outside the water of course. This is all just a few volts DC. If someone could link me to an appropriate relay and how to wire it up it would be appreciated
    • Jul 2011
    • 6070
    Why not use something like this float switch
    https://www.amazon.com/dp/B07DZ11BWB...f8c74978&psc=1
    Then you would have a set of contacts for the low level and a set of contacts for high level and use the appropriate contacts for what you want to do of course you will still need a control relay for your pump
    If you have to use the float switch that have linked to there is going be an issue and that is if you do not have a maximum limit switch you could have an overflow condition
    Or
    You could use a timer with your float switch if you know how long it takes to reach the maximum level limit and do it this way
    How you would use this is setup is you use the float switch to activate the timer and once the timer times out it should be at the maximum level that you are after
    What I do not like about this company is that they do not tell you if the switch contacts are normally open or normally closed so it is very difficult to know which type you are getting
    • SluggerB
      • Aug 2020
      • 747
      • US
      Or
      The problem with those is they are to big. This is for a CPAP machine so I am working in a very small area. Finding a tiny, reliable float switch is really a challenge. It's distilled water to so I can't use any conductive sensor
      I actually managed to get the right angle float in upside down, so it works as I want it to. I had it all rigged up, and it worked fine, until about 10 minutes in, the float switch failed closed. So if this was in use, it would have ran the pump until the water bottle feeding the tank was dry and dumped a gallon of water all over my carpet. So I need to figure something out someway to prevent overflows.
      The timer idea sounds interesting, do you have any links to the type of timer I would use? I would like to run all of this off the pumps DC power supply so I'm not having to plug in more than one thing.
      • mscottdoran@gmail.com
        • Feb 2025
        • 13
        An external relay would easily do what you need it to do. You have to find a relay with a coil voltage equal or nearly equal to the voltage going through the switch currently. Take one wire from the switch and land it on the relay coil base, the other side of the coil would be wired to ground if it is a ground referenced DC, or to whatever common the DC is referenced to. Then parallel the power DC wire to one of the relay’s common terminals and take a wire from a normally open relay contact to the power input of the pump. You have now inverted the logic of the float switch. Omron sells some 6 vdc coil relays. Probably can buy them from Mouser, Jameco etc., you will need the relay base also, they most often can be mounted onto din rail.
          • Feb 2025
          • 13
          Correction it would be the normally closed contact, not the normally open to reverse the logic, sorry for the confusion. I’ll make a drawing of what I’m saying and post it here soon.
            • Feb 2025
            • 13
            Here you go:
            As I mentioned above the relay coil voltage needs to match the voltage of the pump power, and the contact rating for the relay you select should be able to carry more current than the pump will draw. Relay contacts will also give a horse power rating which should be more than the horse power of the pump.
            • CuriousJohn
              Burco boiler power problem
              by CuriousJohn
              Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
              Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
              This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
              12-22-2024, 10:25 AM
              Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
              This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              09-06-2024, 05:30 AM
              20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
              I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
              At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
              Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
              04-09-2023, 08:04 PM
            • Natob82
              Micro Momentary Push Switch?
              by Natob82
              Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
              12-21-2022, 05:22 AM
            • grimacelord
              NEC TurboExpress On/Off Power Switch Replacement Help
              by grimacelord
              I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
              I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
              I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
              11-09-2023, 09:49 AM
