MP 42HC56 SINOTEC 42 lcd
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: MP 42HC56 SINOTEC 42 lcd
    That diode provides the dc to give the V_15 (assume 15V) needed for a lot of the other IC's.
    That seems awful low considering N501 requires VCC =12V min but has at least has 10V and if N502 has a 15V output then you would be expecting around 17.5V at it's input. Maybe worth checking C521.
    • SonOfAnarchy ZA
      • 22
      • South Africa
      i replaced the Cap replaced no change in voltage
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        What voltage do you have on pin 3 (Vfb) of N501
        • SonOfAnarchy ZA
          • 22
          • South Africa
          it goes from 0v to 9v then back to 0V and repeat
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Reading the data sheet
            A feedback voltage of 6V triggers overload protection (OLP).
            This would indicate to me that there is a fault elsewhere which is switching off N501.
            • SonOfAnarchy ZA
              • 22
              • South Africa
              #26
              perhaps something else is in short i will have another look thanks
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #27
                Data sheet attached.
                Edit
                Do you have 5V at C539
                • SonOfAnarchy ZA
                  • 22
                  • South Africa
                  #28
                  Edit
                  i see there is no resistor on R502 but doesnt look like there ever was on according to the circuit diagram there should be a 10k according to your data sheet that pin controls peak current limit should i put a 10k in and see if it works?
                  • SonOfAnarchy ZA
                    • 22
                    • South Africa
                    #29
                    that been said i see n503 is also missing but the diagram recons it must be there
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #30
                      The data sheet does say it can be left open so I don't know.
                      This pin adjusts the peak current limit of the Sense FET. The feedback
                      0.9mA current source is diverted to the parallel combination of an internal
                      2.8kΩ resistor and any external resistor to GND on this pin to determine the
                      peak current limit. If this pin is tied to Vcc or left floating, the typical peak current limit will be 0.7A.
                      • SonOfAnarchy ZA
                        • 22
                        • South Africa
                        #31
                        Edit
                        No there is only 1v there
                        • SonOfAnarchy ZA
                          • 22
                          • South Africa
                          #32
                          Edit
                          not sure where that 5v comes from
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            #33
                            I must admit I have absolutely no idea what is wrong and even I am going around in circles on this one.
                            N501 require 12V min to operate. It initially has capacitor C513 charging via R597 & R598 through an internal circuit. These resistors are connected to V_PFC.
                            The V_PFC voltage is generated by N507 but it needs V_15v to supply the IC's working voltage to generate the boosted V_PFC
                            V_15V is generated via T501 which is driven by N501.
                            If you lift one end of D504 will N501 charge C513 to 12V?
                            • SonOfAnarchy ZA
                              • 22
                              • South Africa
                              #34
                              No still 10v
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                #35
                                Have you lifted R597 and R598 and checked they read what they are marked. You said you have already replaced C513, yes?
                                • SonOfAnarchy ZA
                                  • 22
                                  • South Africa
                                  #36
                                  Yes on both counts
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    #37
                                    You have 180V at the Vstr end of the two resistors, what do you have at the other end?
                                    • SonOfAnarchy ZA
                                      • 22
                                      • South Africa
                                      #38
                                      you have 180v at the vstr end of the two resistors, what do you have at the other end?
                                      300vdc
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        #39
                                        It looks like your mains incoming voltage is low. Post #2 also from South Africa indicates 320V dc across C533 which would indicate an ac input voltage of 226V.
                                        Can you check your mains input ac voltage. Is seems low maybe around 212V ac
                                        • SonOfAnarchy ZA
                                          • 22
                                          • South Africa
                                          #40
                                          222VAC according to my multimeter
                                            Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                            This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 05:30 AM
                                          • Natob82
                                            Micro Momentary Push Switch?
                                            by Natob82
                                            Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                            12-21-2022, 05:22 AM
                                          • grimacelord
                                            NEC TurboExpress On/Off Power Switch Replacement Help
                                            by grimacelord
                                            I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                                            I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                                            I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                                            11-09-2023, 09:49 AM
                                          • SluggerB
                                            Help making a switch work the opposite way with a relay
                                            by SluggerB
                                            I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                            I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                            It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                            02-07-2025, 07:57 PM
                                            Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
                                            Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
                                            ( needs more cam circuits for the machine to work correctly again )
                                            https://www.ebay.com/itm/275321870186
                                            To
                                            3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
                                            ( not 4 positions but the right amount of cams circuits )
                                            https://www.ebay.com/itm/274660439950
                                            I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
                                            03-18-2023, 05:12 PM
