LG 50PH660V Clicking
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Hi guys got an LG 50PH660V Plasma Tv here when plugged in it just starts clicking like hell... i have unplugged boards going to the psu appart from the mainboard. the PSU is EAX64906001 Rev 1.1 but i cant find any info online about these tvs with any common faults.. i will test voltages if i get any and will post results but has anyone had any dealings with this tv or the PSU ?
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Re: LG 50PH660V Clicking
    ok tried to test voltages, i was getting numbers just bouncing up and down as it clicks on and off every second so cant test voltages, after i unplugged tv it continued to click alot slower for 20 seconds or so. what can i do to test further ?
    • sordids999
      • May 2013
      • 2158
      Pictures ??
      • Mikeyboy2007
        • Mar 2013
        • 745
        • Scotland
        hope these help.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          With sustian boards unpluged does it still click like mad ?
          • Mikeyboy2007
            • Mar 2013
            • 745
            • Scotland
            yeah mate as pictured i disconnected those boards and it still goes mental.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Have you started taking voltages ? Check the Vs and Va also check the lower voltage rails going to the Mainboard they will be listed what pin should have what voltage in a little chart near the connector. Let us know what you find.
              • Mikeyboy2007
                • Mar 2013
                • 745
                • Scotland
                will i be able to test the voltages though with the PSU not staying on or even giving me long enough to read them ?
                • chth96
                  How Can I test PWM DM0365R?
                  by chth96
                  Hello
                  I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                  So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                  I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                  I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                  06-18-2025, 04:14 PM
                • khelane
                  test active pfc power with lamp test
                  by khelane
                  Hello
                  I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                  Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                  Is there a way...
                  06-03-2025, 01:00 AM
                • chronic519
                  Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                  by chronic519
                  Hello.
                  GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                  Found issue with a RAM block
                  Replaced, green lines gone.
                  Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                  Used a good card to test and same results low errors 32+.
                  I am just search for some form of command to do a full test on the GPU.
                  I just ran the mats command with my good GPU and passed after roughly 40 min.
                  The repaired one, ran...
                  05-20-2025, 07:56 PM
                • B0r1s
                  Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                  by B0r1s
                  PSU - BN44-00878A
                  Symptoms:
                  The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                  A weak clicking sound was coming from the transformer.
                  Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                  Progress:
                  After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                  01-17-2023, 04:58 PM
                • alltvrepairs
                  Lg TCon test pins for screen test
                  by alltvrepairs
                  i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                  Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                  Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                  Appreciate your help....
                  06-13-2025, 06:33 AM
