SONY KDL-32NL140 no power light
    Re: SONY KDL-32NL140 no power light
    The readings look bad, especially this one:
    Diode mode
    Pin 1 =
    Pin 2 = Black or Red
    Pin 3 = Red or Black
    Pin 4 =
    reading = 0.l
    That would have caused the main ac fuse to blow since pin 2 and 3 are the AC input pins.
    Please pull the bridge off the board and test it again.
    This one is also wrong:
    Pin 1 = Black
    Pin 2 =
    Pin 3 =
    Pin 4 = Red
    reading = .478
    • zogthegreat
      • Nov 2015
      • 18
      OK, after trying to desolder without desoldering wick , I finally got it off.
      Here are my results, I tested in diode mode on my tester:
      Red lead to pin:
      Pin 1 = .0L
      Pin 2 = .0L
      Pin 3 = .0L
      Pin 4 = .924
      Black lead to pin:
      Pin 1 = .923
      Pin 2 = .0L
      Pin 3 = .0L
      Pin 4 = .0L
      Technology, computers, taking things apart, (sometimes putting them back together)
      Living full time in a 36' RV, traveling across the US and Canada. Currently in Lake Wales, FL.
      US Army veteran, disabled USAF veteran, (yes, I served in both branches)
        Red lead to pin:
        Pin 1 = .0L
        Pin 2 = .0L
        Pin 3 = .0L
        Pin 4 = .924
        Black lead to pin:
        Pin 1 = .923
        Pin 2 = .0L
        Pin 3 = .0L
        Pin 4 = .0L
        I do not understand your readings, it has 4 diodes inside so what you are reporting does not make sense to me.
        • zogthegreat
          • Nov 2015
          • 18
          Sorry, does this make more sense?
          Pin 1 = .0L - Red to pin 1 - Black to pin 4
          Pin 2 = .0L - Red to pin 2 - Black to pin 3
          Pin 3 = .0L - Red to pin 3 - Black to pin 2
          Pin 4 = .924 - Red to pin 4 - Black to pin 1
          The only time I got any reading was when I touch the black lead to pin 4 and the red lead to pin 1. Reversing the leads, (Red to pin 1 - Black to pin 4), I get nothing.
            As shown in my diagram, you can see 4 diodes so you should be able to measure each diode inside the bridge.
            I.E. diode mode
            Testing diode D2: Blk on 1, Red on 2 = 0.6
            Testing diode D1: Blk on 1, Red on 3 = 0.6
            Testing diode D4: Blk on 2, Red on 4 = 0.6
            Testing diode D3: Blk on 3, Red on 4 = 0.6
            • zogthegreat
              • Nov 2015
              • 18
              Hers what I get:
              Testing diode D2: Blk on 1, Red on 2 = 0.502
              Testing diode D1: Blk on 1, Red on 3 = 0.503
              Testing diode D4: Blk on 2, Red on 4 = 0.500
              Testing diode D3: Blk on 3, Red on 4 = 0.497
                They are good. Now measure the two inner pads (pin 2 and pin 3) on the board (diode is still off the board) to see if it still show 0.1
                • zogthegreat
                  • Nov 2015
                  • 18
                  I get .0L off the two inner pins on the board, no matter which way I put the probes.
                    Well, I do not know how you get this reading before then:
                    Diode mode
                    Pin 1 =
                    Pin 4 =
                    reading = 0.l
                    Put the bridge back in place and then measure the DCV between the two legs of the main filter cap again. It should show 160~170VDC.
                    • zogthegreat
                      • Nov 2015
                      • 18
                      When I measure between the filter, (red arrows), I'm still getting 0.25vdc
                      [/QUOTE]
                      Diode mode
                      Pin 1 =
                      Pin 4 =
                      reading = 0.l
                      I not sure either. I'm trying to be as methodological as possible in my measurement. I have test my meter against several batteries and my coach's 12vdc and 120vac systems and it seems to be accurate.
                        There are two diodes that you need to check (I doubt that both of them are bad but check them any way).
                        Then check the resistance between:
                        A & B =
                        A & C =
                        D & F =
                        E & F =
                        G & H =
                        Something is not testing right.
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          I wonder if that diode could be open inline with the one side going to the main filter. I can't read the number but it's definitely a three-digit its right above the filter cap on the right side
                          Lol Budm you beat me to it!
                            There are two of them so both of them (one of them is fed through the PFC Inductor) will have to be bad.
                            • zogthegreat
                              • Nov 2015
                              • 18
                              A & B =
                              A & C =
                              D & F =
                              E & F =
                              G & H =
                              Sorry, but I'm not understanding, which two diodes do I need to check? Is the two marked with the red arrows?
                              Do I check the resistance between the other ones with or with out power?
                              Thanks!
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                The ones he has marked as diodes and red letters B to D and C to E. Test these in diode mode on your meter. You should read almost infinite or O.L. on one side and have a reading on the other
                                  'Do I check the resistance between the other ones with or with out power?;' I am surprised that you ask if the power is needed to be applied or not when making the resistance measurement. Did you do the diode test with power applied too?
                                  And those resistance testing between the points are needed to find out if you do have connections all the way to the filter cap. At this point it looks to be measurement errors to me.
                                  This may explain why you get these readings on post 20:
                                  Pin 1 =
                                  Pin 4 =
                                  reading = 0.l
                                  • zogthegreat
                                    • Nov 2015
                                    • 18
                                    Pin 1 =
                                    Pin 4 =
                                    reading = 0.l
                                    Hi budm,
                                    No, there was no AC power when I did the diode test.
                                    Here are the results from my latest test:
                                    A & B = 00.9
                                    A & C = 00.9
                                    D & F = 00.9
                                    E & F = 00.9
                                    G & H = 00.9
                                    I used the resistance setting on my meter to do the test, no AC power.
                                    Just to clarify, I am a total noob to this. Although my son has a degree in Electronic Technology, and a BA in Computer Engineering, my talents lie elsewhere. Whereas changing a bad cap or two to fix a monitor is relatively simple, this is much more advance for me and I am trying to learn to the best of my abilities. Hence me asking what the best way to perform the test. I just wanted you to know what my level of "expertise" in this area is, i.e. minimal at best. That's why I try to do as many test as possible so that you guys here on the forum will have as much data as possible to work with.
                                      Hi budm,
                                      A & B = 00.9
                                      A & C = 00.9
                                      D & F = 00.9
                                      E & F = 00.9
                                      G & H = 00.9
                                      OK, so you do have continuities on those connections, then you need to test those two diodes in the red circles I have marked.
                                      • zogthegreat
                                        • Nov 2015
                                        • 18
                                        Opps! Sorry, I forgot to give you that info. I get .391 off of both of them. Diode mode, no power.
                                          Well, the whole thing does not make any sense right now since you do have 120VAC feeding the two AC input pins of the bridge rectifier, and you do have two good diodes and good connections all the way to the main filter cap but yet you do not get any DCV on the main cap.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • noinimod
                                            Sony 55X900E no standby light, no power. Replaced mainboard already
                                            by noinimod
                                            No standby red light, nothing
                                            This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                            Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                            At a few pins I can see the power supply providing 19.5V to the main board
                                            Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                            LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                            12-22-2021, 12:58 AM
                                          • SkishyIshy
                                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                            by SkishyIshy
                                            Hey All,
                                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                            03-17-2021, 11:44 AM
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • PopsCaps
                                            Sony Bravia KDL-40V2500 that will not power on
                                            by PopsCaps
                                            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                            I do not hear any sound and I cannot see any backlight.
                                            I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                            03-25-2025, 11:23 AM
