SONY KDL-32NL140 no power light
  • zogthegreat
    • Nov 2015
    • 18
    Hi everyone!
    I'm a long time lurker on the forum, but this is my first post. A friend gave me a SONY KDL-32NL140 LCD TV that will not power up. The power light does not come on when it is plugged in and it does not turn on when you push the power button.
    I was thinking it might be bad caps, (this has usually been the problem when I have similar problems wit computer LCD's), but the capacitors seem fine, with no bulges or leaks. I tested the ceramic fuse next to the power in and I'm getting 38.2v AC, (red arrow in the picture). Not sure if this is normal or not, (that's why I'm posting here!).
    I checked the back of this and the other 2 boards and I don't see any signs that they are burnt or have anything bad on them.
    Any suggestions?
    zog
    Technology, computers, taking things apart, (sometimes putting them back together)
    Living full time in a 36' RV, traveling across the US and Canada. Currently in Lake Wales, FL.
    US Army veteran, disabled USAF veteran, (yes, I served in both branches)
  • freakaftr8
    • Oct 2012
    • 3743
    Re: SONY KDL-32NL140 no power light
    What are you getting in DC voltage across that big filter cap? Also I'm not sure about how you're testing that fuse but with the TV unplugged doing ohms test on the main fuse and see if its open or not first.
    • zogthegreat
      • Nov 2015
      • 18
      Hi freakaftr8,
      I get .025 DCV on the large round capacitor/filter
      I was measuring it with the TV plugged in. (Not the correct way, I assume? )
      I get 00.8 ohms, I get the same when I cross the leads on my cheap Chinese multimeter. When I test on a 3' piece of solid core copper wire, I get 2.0 oms, (to give you a reference range).
      • freakaftr8
        • Oct 2012
        • 3743
        Ok fuse is good there is however no power on the primary side for some reason.
        • freakaftr8
          • Oct 2012
          • 3743
          Aha! Can you focus in on those 3 blue mylar capacitors to the left of the fuse? Is that bottom one blown to pieces?
          • Gootch46
            • Oct 2015
            • 57
            Great catch there freakaftr8 it sure looks like it to me also.
              Pictures of the bottom side of the power suppl board?
              Those 3 blue X/Y caps looks like they are glued down with black silicone.
              • zogthegreat
                • Nov 2015
                • 18
                LOL, I was just about to post that up!
                I scraped off as as much of the silicon that I could. The capacitors look OK. I don't have an ESR tester, so I will try to get the parts to build a capacitance tester and start testing them.
                Question, do I need to unmount the caps in order to test them or can I test them while they are still on the board?
                  I doubt that they are bad. I need the pictures of the bottom side of the board to see how the AC gets to the rectifier.
                  SJ does not have the picture of the bottom side:
                  http://www.shopjimmy.com/sony-1-474-...wer-supply.htm
                  • zogthegreat
                    • Nov 2015
                    • 18
                    Hi budm,
                    Here you go. I'm sorry about the image quality, my camera just died with a "lens error"! (I guess I'm taking something else apart today!)
                    I labeled the 120v, large cap and 3 small caps to give you some reference points. If you need more, let me know.
                    Thanks!
                      the bridge rectifier is on the top right of the picture. Do you get 120VAC between the two inner legs for the bridge?
                      Please make it better focus.
                      • zogthegreat
                        • Nov 2015
                        • 18
                        I get 116.5 across the 2 inner pins of the bridge rectifier.
                        Is this better? Or should | go borrow a camera? (I'm using my phone until I have time to try fixing my camera).
                          Then you should see DCV between the two outer pins.
                          Thanks for the much better picture.
                          • zogthegreat
                            • Nov 2015
                            • 18
                            I'm not getting anything DCV on the two outer pins. This my bad part?
                            Can I upload a copy of the pic there? It might help someone else in the future.
                              Meter set to DCV, right?
                              Otherwise check the bridge.
                              • zogthegreat
                                • Nov 2015
                                • 18
                                When I have it set to DCV, I get L.0, but when I hit the "range" button, I get 160.0mv
                                I'm using a Vici VC86 multimeter:
                                (Sorry, my son has a degree in electronics, but I'm not as good as he is for this type of stuff [or as knowledgeable]. But you give me an engine to take apart..... )
                                  Take the meter and check your car battery to see what it shows.
                                  • zogthegreat
                                    • Nov 2015
                                    • 18
                                    I get 12.66v off my car battery.
                                      Just curious, put the meter in AC and measure between the two out side pins again.
                                      BTW, did you check the bridge in diode mode to see what it shows?
                                      • zogthegreat
                                        • Nov 2015
                                        • 18
                                        OK, this is what I got:
                                        Diode mode:
                                        Pin 1 = Black
                                        Pin 2 =
                                        Pin 3 =
                                        Pin 4 = Red
                                        reading = .478
                                        Pin 1 = Red
                                        Pin 2 =
                                        Pin 3 =
                                        Pin 4 = Black
                                        reading = 0.L
                                        Pin 1 =
                                        Pin 2 = Black or Red
                                        Pin 3 = Red or Black
                                        Pin 4 =
                                        reading = 0.l
                                        ACV:
                                        Pin 1 = Black
                                        Pin 2 =
                                        Pin 3 =
                                        Pin 4 = Red
                                        reading = 0.58
                                        Pin 1 =
                                        Pin 4 =
                                        reading = 0.L
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • lapfix
                                          HP OMEN NO power no light
                                          by lapfix
                                          HP OMEN : DAG35DMBAD0
                                          NO power ,no short ,no corrusion
                                          Consumption : when charger plg in = 0.004 amp
                                          Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                                          when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                                          No light at power button led
                                          All coils resistances :
                                          Pl 2001 =3v measured with kohm.
                                          pl 2004 = 5v measured with kohm
                                          pl 6001 = 49.7ohm
                                          pl 4012 = vccsa = 24.4 ohm
                                          pl 3001 =...
                                          11-03-2025, 07:48 AM
                                        • noinimod
                                          Sony 55X900E no standby light, no power. Replaced mainboard already
                                          by noinimod
                                          No standby red light, nothing
                                          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                          Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                          At a few pins I can see the power supply providing 19.5V to the main board
                                          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                          12-22-2021, 12:58 AM
                                        • SkishyIshy
                                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                          by SkishyIshy
                                          Hey All,
                                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                          03-17-2021, 11:44 AM
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
