LG 42LG3000, T-CON or Screen
  • finntricky
    • Jan 2014
    • 449
    what do we think, i would say TT-CON, as the problem clears up after ten mins
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 42LG3000, T-CON or Screen
    Ahh I have recently fixed one. The tab bond on the top left hand corner is probably at fault a tcon wont cause this issue. I have a youtube video I will upload.
    • Daren87
      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
      by Daren87
      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
      08-13-2023, 03:25 PM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • alltvrepairs
      Lg TCon test pins for screen test
      by alltvrepairs
      i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
      Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
      Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
      Appreciate your help....
      06-13-2025, 06:33 AM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
