Industrial LCD monitor DSP overheating
  • PowerAmpFreak
    • 982
    • Sweden
    Hello
    In front of me I have an industrial LCD monitor, brand is General Touch PL1501.
    It works for a few minutes then starts to make odd colours and behave bad.
    I traced it to the chip "TSU16AK" DSP overheats, if I use freeze-spray on it, the operation will be restored a few minutes until it overheats again.
    I might think of replacing the entire pcb, if I just could locate it.
    I haven't got a clue where to search for this, since it has got no readable numbers on it.
    Replacing the chip only might be a solution, but only locate the chip on E-bay (China).
    Any advice is appreciated!
    Re: Industrial LCD monitor DSP overheating
    Check all nearby voltage regulators for stability.
    It is unusual for such a chip to fail in such a way. Not impossible but very unusual.
    Freeze spraying it may reduce the current it uses, this may affect regulators nearby.
      'Check all nearby voltage regulators for stability.' +1
      Does it get hot if you disconnect the LVDS cabl going to the LCD Panel?
        • 31289
        are you assuming it overheats, or can you burn your finger on it?
        if you can put a finger on it then it may just need a reflow.
        • fzabkar
          • Mar 2009
          • 772
          The SM89516C25J SyncMOS microcontroller runs off +5V, so I expect this would be provided by a switchmode converter consisting of the toroid (L3), U3 and D1.
          The TSU16AK requires a 1.8V core and a 3.3V I/O supply, so I'm guessing these are provided by linear regulators near the crystal.
          You might consider attaching a heatsink to the TSU16AK.
          SM89516C25J, SyncMOS, 8-bit microcontroller with 64KB flash & 1KB RAM, 5V, 25MHz:
          https://cdn.badcaps-static.com/pdfs/...9d89632815.pdf
          TSU16AK, MStar, SXGA LCD Controller with Analog Interface and Dual LVDS Transmitter, 1.8V core, 3.3V I/O:
          https://cdn.badcaps-static.com/pdfs/...4e8c117680.pdf
          • PowerAmpFreak
            • 982
            • Sweden
            Thanks everyone for good advice.
            I don't burn my finger on it though.
            Already tried a heatsink but it does not help much.
            I will focus on the voltage regulators.
            • fzabkar
              • Mar 2009
              • 772
              Apart from a reflow, could a wonky crystal (X2) produce the observed symptoms?
                by momaka
                03-15-2023, 10:17 PM
              • keepread
                Dell monitor PSU vs Dell laptop PSU
                by keepread
                Hi there!
                Someone gave me their old monitor, it's Dell S2715ht.
                The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                10-30-2025, 04:45 PM
              • wattage
                AOC AG493UCX 49-inch monitor - Firmware request
                by wattage
                Hello Badcaps Community,
                The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                07-13-2025, 04:41 PM
              • ant3202
                HP 27es - LED monitor - Monitor Flashing On - Off
                by ant3202
                Hi Everyone
                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                https://www.badcaps.net/forum/troubl...lashing-on-off
                The monitor is HP 27es LED Monitor
                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                The monitor will randomly blackout and display no signal and will recover again.
                Sometimes need to power and off again to restore the display but...
                03-20-2025, 07:30 PM
              • Rick_1234
                LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                by Rick_1234
                Good evening, gentlemen.
                I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                https://drive.google.com/file/d/1L6S...ew?usp=sharing
                Things I tried
                - Bought a new AC adapter thinking that was the problem but the problem...
                06-22-2024, 04:44 PM
