Industrial LCD monitor DSP overheating
  • PowerAmpFreak
    • 982
    • Sweden
    Hello
    In front of me I have an industrial LCD monitor, brand is General Touch PL1501.
    It works for a few minutes then starts to make odd colours and behave bad.
    I traced it to the chip "TSU16AK" DSP overheats, if I use freeze-spray on it, the operation will be restored a few minutes until it overheats again.
    I might think of replacing the entire pcb, if I just could locate it.
    I haven't got a clue where to search for this, since it has got no readable numbers on it.
    Replacing the chip only might be a solution, but only locate the chip on E-bay (China).
    Any advice is appreciated!
    Re: Industrial LCD monitor DSP overheating
    Check all nearby voltage regulators for stability.
    It is unusual for such a chip to fail in such a way. Not impossible but very unusual.
    Freeze spraying it may reduce the current it uses, this may affect regulators nearby.
      'Check all nearby voltage regulators for stability.' +1
      Does it get hot if you disconnect the LVDS cabl going to the LCD Panel?
        • 31247
        are you assuming it overheats, or can you burn your finger on it?
        if you can put a finger on it then it may just need a reflow.
        • fzabkar
          • Mar 2009
          • 772
          The SM89516C25J SyncMOS microcontroller runs off +5V, so I expect this would be provided by a switchmode converter consisting of the toroid (L3), U3 and D1.
          The TSU16AK requires a 1.8V core and a 3.3V I/O supply, so I'm guessing these are provided by linear regulators near the crystal.
          You might consider attaching a heatsink to the TSU16AK.
          SM89516C25J, SyncMOS, 8-bit microcontroller with 64KB flash & 1KB RAM, 5V, 25MHz:
          https://cdn.badcaps-static.com/pdfs/...9d89632815.pdf
          TSU16AK, MStar, SXGA LCD Controller with Analog Interface and Dual LVDS Transmitter, 1.8V core, 3.3V I/O:
          https://cdn.badcaps-static.com/pdfs/...4e8c117680.pdf
          • PowerAmpFreak
            • 982
            • Sweden
            Thanks everyone for good advice.
            I don't burn my finger on it though.
            Already tried a heatsink but it does not help much.
            I will focus on the voltage regulators.
            • fzabkar
              • Mar 2009
              • 772
              Apart from a reflow, could a wonky crystal (X2) produce the observed symptoms?
                by momaka
                03-15-2023, 10:17 PM
              • wattage
                AOC AG493UCX 49-inch monitor - Firmware request
                by wattage
                Hello Badcaps Community,
                The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                07-13-2025, 04:41 PM
              • ant3202
                HP 27es - LED monitor - Monitor Flashing On - Off
                by ant3202
                Hi Everyone
                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                https://www.badcaps.net/forum/troubl...lashing-on-off
                The monitor is HP 27es LED Monitor
                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                The monitor will randomly blackout and display no signal and will recover again.
                Sometimes need to power and off again to restore the display but...
                03-20-2025, 07:30 PM
              • Rick_1234
                LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                by Rick_1234
                Good evening, gentlemen.
                I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                https://drive.google.com/file/d/1L6S...ew?usp=sharing
                Things I tried
                - Bought a new AC adapter thinking that was the problem but the problem...
                06-22-2024, 04:44 PM
                Wise Wing F199 19'' LCD monitor - recapped
                by momaka
                Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                When I saw the Craigslist post, I wasn't...
                08-24-2020, 10:58 AM
