Samsung le37b530 flickering backlight
  • apeter1
    • Nov 2015
    • 21
    • Hungary
    I have le37b530 with flickering backlight. It has only one large 450V electrolytic capacitors. I'm reading 389v on it. I cannot see any badcamps.
    The Powerboard is a BN44-00262A, the main is a BN41-01165B. What should I check?
    Thanks,
    Peter
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung le37b530 flickering backlight
    Unplug the main board.
    Plug In the tv. The backlights should come on automatically.
    Do they still flicker?
    • apeter1
      • Nov 2015
      • 21
      • Hungary
      I unpluged the main board, pluged in the tv. The backlights comes on automatically. It does not flicker.
      At normal usage only the bright colours(white, yellow..etc..) flickering.
      What could be the problem?
      Thanks.
      Peter
      • apeter1
        • Nov 2015
        • 21
        • Hungary
        https://youtu.be/NBhwNTd52bI
        https://youtu.be/oS0HgV7r37c
        • CapLeaker
          Leaking Member
          • 8326
          I am not convinced the problem is on the backlights, as I only see the left side flicker. Reseat the LVDS and Tcon cables.
          • zomi
            • Nov 2011
            • 509
            read here
            https://www.badcaps.net/forum/showthread.php?t=44792
            • apeter1
              • Nov 2015
              • 21
              • Hungary
              I've checked all the cables but it still flickering. Also when I move the cables it does not flicker slower or quicker.
              When I switch on the TV it flickers slowly. After that the flickering accelerates.
              I've read the other topic. Which parts should/can I check without removing from panel?
              Thanks,
              Péter
              • awyatt2
                • Feb 2012
                • 407
                • america
                on the ln series there are four sm resistors on the back of the main board, don't know if your set is similar or not. search ln52c550 flickering backlights and it is the fix for the ln series. I used 2 3m ohm 1/2 watt thru hole resistors to fix mine. there is a jumper you can cut as well but it bypasses the protection circuit.
                  Thanks.
                  Peter
                  So the BACKLIGHTS do not flicker? Then it will not be backlights problem.
                  'At normal usage only the bright colours (white, yellow..etc..) flickering.' bad backlights will not cause particular color to be flickering.
                  • apeter1
                    • Nov 2015
                    • 21
                    • Hungary
                    Yes, the BACKLIGHTS do not flicker. Only bright and vibrant colors flicker.
                    I've linked videos.
                    • zomi
                      • Nov 2011
                      • 509
                      Does this use one of the as15 chips on the tcon..
                      Could be signs of it failing ?
                      • apeter1
                        • Nov 2015
                        • 21
                        • Hungary
                        There is not as15 chips on the tcon.
                        Do you have any idea?
                        Thanks,
                        Peter
                        • apeter1
                          • Nov 2015
                          • 21
                          • Hungary
                          There is AS15-HF chip on the tcon.
                          Could it be fault?
                          Thanks,
                          Péter
                          • apeter1
                            • Nov 2015
                            • 21
                            • Hungary
                            I'm posting pictures...
                            • zomi
                              • Nov 2011
                              • 509
                              How goods your soldering
                              If you able to solder try changing it out.
                              Is it getting quite hot when tv is on ?
                              • CapLeaker
                                Leaking Member
                                • 8326
                                Tough call... Tcon or the panel itself. Post the voltages of the as15...
                                • apeter1
                                  • Nov 2015
                                  • 21
                                  • Hungary
                                  It is very hot when tv is on. How mach chance that the Tcon is bad?
                                  I would repalce the Tcon is not too expensive. The soldering may very difficult for me.
                                  Tcon no.: FT-5537T05C09-9CL-0000NEP-03151-04
                                  Is only this number with Tcon good for this TV?
                                  • CapLeaker
                                    Leaking Member
                                    • 8326
                                    Should be starting with a BN number. Look into shopjimmy, put in your tv and they have one or an alternative.
                                    • apeter1
                                      • Nov 2015
                                      • 21
                                      • Hungary
                                      It starts with FT-....
                                      shopjimmy.com: Access Denied
                                      • cliff_hootarski
                                        • Jul 2006
                                        • 411
                                        use 55.37T05.C09
                                        • sliceypete
                                          Samsung LE52B620 - Flickering backlight
                                          by sliceypete
                                          Hello All,
                                          My Samsung LE52B620 started to have backlight flickering about a year ago, it would only last for about 10 mins and then the backlight would stay on.
                                          about a month ago the backlight flickering is constant and does not stop.
                                          I think it's a problem with the power supply board (BN44-00267b) or maybe the backlight is dying?
                                          I checked and all the caps look to be fine.
                                          I do not believe it is a problem with the mainboard, since I unplugged it from the power supply and the backlight came out but still flickers.
                                          08-04-2021, 05:11 AM
                                          09-07-2024, 05:50 AM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
                                        • howardc64
                                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                          by howardc64
                                          TV was fixed just after removing Samsung's rear snap cover.
                                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                          Maybe PSU->backlight connector didn't have a good contact?...
                                          07-23-2025, 12:34 AM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
