lcd sony KDL-46EX645, ...standby light is on....will not power on..no clicks..
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    Re: lcd sony KDL-46EX645, ...standby light is on....will not power on..no clicks..
    ok will do ...thanks
    • shelby5041
      • Feb 2009
      • 1505
      im going to try to post sme pics....as you can see only the graphics are solarized.......the background display is not...its solid color
      and images are upside down
      im hoping this issue can be resolved....i have only seen this on plasma tvs in the past and never on a lcd tv
      • shelby5041
        • Feb 2009
        • 1505
        retailer just informed me the board came out of a 50ex645
        mine is 46ex645
        they both use exact same part # per shop jimmy Sony 1-895-307-11 MBP Board (Main Board)
        can anyone confirm this?
        • vinceroger69
          • Mar 2012
          • 6714
          this site does say its the same
          https://tvrepairtips.org/sony-1-895-307-11-mbp-board
          have you tried the software upgrade yet?
          • shelby5041
            • Feb 2009
            • 1505
            no i havent im at work all night
            • shelby5041
              • Feb 2009
              • 1505
              #26
              yes i know.....the board is for a few model tvs but on shop jimmy it says must do software upgrade when u buy the board from them so not sure what that meaans
              i didnt buy it from shop jimmy though....just making a comment
              • shelby5041
                • Feb 2009
                • 1505
                #27
                did u see the photos i took......
                • shelby5041
                  • Feb 2009
                  • 1505
                  #28
                  i dont feel very confident on the update as it doesnt seem it has anything to do with what my issue is...it just seems like an improved performance upgrade and nothing to do with altering or changing displays etc.....we will see
                  • shelby5041
                    • Feb 2009
                    • 1505
                    #29
                    i think my issue is board related....the board i got is prob defective and the retailer is lying about it.......i think its a video processing issue and not lcd panel issue like he says it is...since the lcd panel worked fine prior to hdmi port frying
                    • shelby5041
                      • Feb 2009
                      • 1505
                      #30
                      hi this is what the retailer nickstv shop said
                      "The solarization issue is coming from either a bad panel, or a bad T-con board. There is a chip on your T-con called an AS15 chip which more than likely is where the fault is coming from. Main boards can not cause solarization problems due to how the data and signals are processed between the main, the T-con, and the panel. There is a small possibility that running an update could fix the solarization issue as well.
                      If you will run that update for me, and then get back to me with the results, that would be appreciated.
                      Thank you. "
                      is the tcon a possible issue causing the solarization or could the panel be bad from the hdmi port getting fried?
                        'images are upside down' that is not due to the T-CON board.
                        There are some threads in BADCAPS with solarization due to wrong setting in the service menu.
                        https://www.badcaps.net/forum/showth...t=LVDS+setting
                        Is this your T-CON baord?
                        http://assets.shopjimmy.com/media/ca...24765d-top.jpg
                        http://www.shopjimmy.com/samsung-lj9...-con-board.htm
                        It does not use AS15 GAMMA chip.
                        • shelby5041
                          • Feb 2009
                          • 1505
                          #32
                          hi bud m..i was just quoting what the nickstv.com owner said ...thats where i bought the part from
                          and i dont know what my tcon board looks like im not home...im at work till 530a,,,
                          im really just concerned about the solarization...is it due to a defective board the nickstv sold me or some other issue....like i said prior to the hdmi port frying there was no picture issue
                          could the fried hdmi port caused this issue??.....i guess im asking what could be the root cause of the solarization....bad lcd panel? bad or uncompatible main board? bad tcon? or as simple as a service men setting adjustment? or maybe a power supply issue not putting out enough volts?
                          any ideas?
                          • shelby5041
                            • Feb 2009
                            • 1505
                            #33
                            bud m
                            the solarization issue looks so much like a common issue with plasma tvs.....
                            ive never seen it on a lcd tv
                            • machomachomarco
                              • Oct 2011
                              #34
                              Hi I'm new to posting comments but here goes, I've seen a video from norcal715 where he fixes a solarization, issue from the service menu and also I read somewhere from a book that a 180 degree picture flip can be fixed from service menu from a setting called hv flip hope it helps as youtube also has videos of similar issues so hope you can get your set fixed, thanks for your time.
                              • shelby5041
                                • Feb 2009
                                • 1505
                                #35
                                update.....software update not needed as tv is already updated per running update...so thats a dead end solution
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #36
                                  can you get into the service menu? if you can take some pictures of whats on each screen as there maybe a setting you can alter.
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    [QUOTE=shelby5041;604583]update.....software update not needed as tv is already updated per running update...so thats a dead end solution[/QUOTE
                                    Actually its not. It costs nothing to try and depending on how its done (ie. internal "sematics"), it may solve your problem.
                                    • aaronwt6
                                      • Apr 2013
                                      • 855
                                      • US
                                      #38
                                      Just thought I'd chime in here again since I have some parts from both the 46ex645 as well as the 50ex645. Both of the problems you are experiencing are definitely related to the board mis-match. If you can get the firmware changed to the 46" and/or adjust it in the service menu I'm confident it will fix your issue. If I'm not mistaken and you can confirm for me, the 46" has a Samsung LCD panel. I have a T-con here for the 50" and it's a CMO t-con in that one. The panel mismatch is the issue with both the menu being upside down as well as the color problem.
                                        'Both of the problems you are experiencing are definitely related to the board mis-match.' +1. The EEPROM on the T-CON tells the main board what the T-CON setup is (I read that in the SONY training manual, need to find that again).
                                        You can ask the seller as to why the picture is upside down, I would trust shojimmy since they deal with lot of boards and problems more than other smaller seller.
                                        BTW, what firmware name/version is on the replacement board?
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #40
                                          Service Menu Code For Sony TV:
                                          First power off your TV using the remote, then press following buttons quickly on your TV remote:
                                          Display (or i+) + 5 + Volume Up + Power
                                          It'll show the hidden service menu on your TV screen
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • Crystaleyes
                                            Samsung BN44-00259A standby question
                                            by Crystaleyes
                                            Hi all.
                                            I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                            SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                            Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                            The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                            08-11-2023, 05:15 AM
                                          • psssst
                                            Yamaha TSX 120 Standby Problem
                                            by psssst
                                            Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                            03-01-2024, 07:25 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
