lcd sony KDL-46EX645, ...standby light is on....will not power on..no clicks..
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    sony KDL-46EX645, ...standby light is on....will not power on..no clicks..nothing when power button is hit.....caps on ps look ok...
    any help would be appreciated
    Re: lcd sony KDL-46EX645, ...standby light is on....will not power on..no clicks..
    Start with good clear pictures of the whole back side of the TV so we can see all the board, then good pictures of the whole power supply top and bottom sides, then around the connectors so we can see the labels for each pin.
    • shelby5041
      • Feb 2009
      • 1505
      here is a photo of the main board as you can see hdmi port is fried
      i get a standby light but tv willnot power on...
      the ps seems to have good voltages.....is the fried hdmi port the issue?
      if so can i just desolder the hdmi port and see if that works?
      my other ocosmo tv has the same exact issue.....fried hdmi port and standby light but will not power on
      is this a common issue?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        More than likely the hdmi ports were hot with a surge. They dont normally spontaneously blow up lol
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          The surge probably killed the fuses on the mobo and the main processor wouldn't surprise me. Probably best to get a new board as re-soldering hdmi ports and hdmi/cpu processors is very hard.
          • shelby5041
            • Feb 2009
            • 1505
            hi
            update just got replacement board
            bad news....i need help
            i installed and tv nowpowers on fine however all images on the screen is rotated 180 degrees...basically upside down even osd and the image is extremely solarized...looks weird....i have never seen this issue ...
            the original board had a fried hdmi port and tv would not power on at all...it had standby but wouldnt power on
            can anyone help me?
            • vinceroger69
              • Mar 2012
              • 6714
              does the replacement mainboard match your old one ie all sticker numbers etc there maybe in the service menu a setting to flip the screen setting, also to alter lvds setting to stop the solarized picture, but im not 100% sure as never really messed with service menus and not sure how to get into it.
              • freakaftr8
                • Oct 2012
                • 3743
                I don't know if Sony incorporate bitrate and LVDS technology into their service menu four different panels but you can certainly check. The service code to get in should be with the power off. Press display 5 vol up power.
                • shelby5041
                  • Feb 2009
                  • 1505
                  the sony part number and tv model # match exact
                  • shelby5041
                    • Feb 2009
                    • 1505
                    im going to post pics later......i have never seen this.... ......
                    • shelby5041
                      • Feb 2009
                      • 1505
                      thats same service code as sony rear projection tv?
                        Did you get the board form shopjimmy?
                        http://www.shopjimmy.com/catalogsear...ny+KDL-46EX645
                        'Sony 1-895-307-11 MBP Board (MUST UPGRADE SOFTWARE!)'
                        • shelby5041
                          • Feb 2009
                          • 1505
                          no...got it from online retailer nickstvs.com
                          • shelby5041
                            • Feb 2009
                            • 1505
                            and thats ssme part # as my board
                            • shelby5041
                              • Feb 2009
                              • 1505
                              just contacted retailer and he assured me board worked prior to removing from tv...so assuming thats correct....what could cause the solarization issue and display upside down.....
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                Maybe worth trying the software upgrade as budm suggests.
                                • aaronwt6
                                  • Apr 2013
                                  • 855
                                  • US
                                  Agreed. I'm almost certain you've received a main board from a different screen size than yours. Some of the x645s have the t-con at the top of the TV and some have it at the bottom. I've seen both.
                                    FIRMWARE:
                                    http://esupport.sony.com/US/p/swu-do...os_group_id=18
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      thanks.....whats the procedure to upgrade
                                        See the link I provided.
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • Crystaleyes
                                          Samsung BN44-00259A standby question
                                          by Crystaleyes
                                          Hi all.
                                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                          08-11-2023, 05:15 AM
                                        • psssst
                                          Yamaha TSX 120 Standby Problem
                                          by psssst
                                          Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                          03-01-2024, 07:25 AM
                                        • reessi
                                          JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                                          by reessi
                                          I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                                          You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                                          Years ago it had some bulging caps...
                                          04-26-2021, 11:42 AM
