Toshiba 46sl417u main board issue
  • shadetreetrader11
    • Oct 2015
    • 230
    Does anyone know what part generally goes bad on the Toshiba model 46sl417u? Main board is a pe0953a or v28a001251a1. Turn power on no picture, no backlight or sound. No blinking standby lights If I hook the connector from the power supply to the led driver board crooked so the 3.3 vdc isn't hooked up the back light will come on. But as soon as I hook the connector up it shuts off. This board is hard to find and i'm getting a little desperate.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Re: Toshiba 46sl417u main board issue
    Measure the voltages on each pin of the PSU where the main board plugs in and report back with the voltages measured and the corresponding pin out.
    Also send some hi res pics, so we can see it.
    Could be anything from failed eeprom to no power of some sort, a short or blown main IC. Search for your board on ebay... there was one and also a repair service.
    • adgor
      • Feb 2015
      • 16
      Do you mean the 2.9vDim on pin#1 (PJ860 to J1), pin #10 on CN90 (main) ? Is the resistance low on that DIM line with the TV unplugged? Unplug CN90 and check pin #10 on Main. A low resistance = bad main. This model has had power supply problems.... so is the standby voltage low or unstable (CN90 pin #4 = 5vsb on main)? If yes, then you might have power supply problem. Some kits are available.
      PJ860= Power Supply
      Out
      1. <2.9V Dim
      2. <5.2V BL On
      3. Option
      4. Gnd.
      5. Gnd.
      6. Gnd.
      7. <24V
      8. <24V
      9. <24V
      CN90 Main
      1. >3.1V AC Det.
      2. <3.07V Pwr. On
      3. <3.1 TV On
      4. >5V SB***
      5. Gnd.
      6. >24V LNB
      7. Gnd.
      8. Gnd.
      9. <5.2 BL On
      10. <2.9 Dim
      • shadetreetrader11
        • Oct 2015
        • 230
        Ok guys
        PJ860-POWER OFF
        1. 0 545K OHMS
        2. .070 VDC
        THE REST WERE GOOD
        PJ860 POWER ON
        1. 3.01 THEN BACK TO ZERO VOLTS WHEN THE RELAY CLICKS ON THE POWER SUPPLY.
        I USED THE MIN MAX ON METER
        2. 70 MIL AGAIN
        CN91 ON MAIN BOARD
        1. 3.3
        2. 3.26
        3. 3.28
        4.5.14
        5. GND
        6. 24 V THE BACK TO ZERO AFTER RELAY CLICKS
        7.0
        8.0
        9 70 MIL VLT
        10.0
          Really confused readings.
          Can you please report the DCV reading in the same format as used by ADGOR?
          How about the pictures?
          • shadetreetrader11
            • Oct 2015
            • 230
            What would you like me to take a pic off? All the boards or one in particular.
              The whole back side of the TV so we can see how all the boards are connected together, then the pictures of the whole power supply board and the closed up around the connector so we can see the pin labels.
              BTW, do you also have the P/N of the power supply board?
              Is this your power supply board?
              http://www.shopjimmy.com/catalogsear...shiba+46sl417u
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8327
                Ok guys
                PJ860-POWER OFF
                1. 0 545K OHMS
                2. .070 VDC
                THE REST WERE GOOD
                PJ860 POWER ON
                2. 70 MIL AGAIN
                CN91 ON MAIN BOARD
                1. 3.3
                2. 3.26
                3. 3.28
                4.5.14
                5. GND
                7.0
                8.0
                9 70 MIL VLT
                10.0
                You really want us to know where those readings belong without a pinout?
                • shadetreetrader11
                  • Oct 2015
                  • 230
                  Every time I try to get you some pictures it tells me that i have an invalid file.
                  I'll keep trying, Sorry guys
                  • shadetreetrader11
                    • Oct 2015
                    • 230
                    Figured it out, Don't Ask. Let me know if you need more
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8327
                      Right now you don't have BLon (backlights). That signal comes from the main board.
                      • shadetreetrader11
                        • Oct 2015
                        • 230
                        Correct. But if I hook the connector that goes to the driver board up crooked so only the 24v is making a connection with the power supply board. Then the backlight comes on. As soon as I hook it up correctly is faults out.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8327
                          The PSU has probably a pull up resistor, so when you unhook the main board, plug the PSU in, the backlights come on. So your PSU is good. What you could try doing is to take the BLon pin out of the connector, take a 1k resistor and jump 5v into that connector on the PSU. See what happens
                          • shadetreetrader11
                            • Oct 2015
                            • 230
                            I tried that and the backlight comes on for a sec then shuts off again. I checked the voltage coming from the driver board to the psu and there is 3.3v on the BL pin. And as soon as I plug the connector in correctly the 3.3v drops to zero. The only way the back light stays on is if I unhook the BL pin and the PDIM pin at the same time. I checked the resistance from BL pin to ground and it isn't shorted. And the PDIM to ground was the same.
                              That is because as CAP has explain, the Driver board has pull-up resistor but the main board is stuck LO so when you hook up properly the main board pull that line low and not allowing it to go high, it does not mean the line is shorted, it means that the processor is not turning off (when it is supposed to) the switched transistor to allow the line to go HI.
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8327
                                I guess you need a new main board
                                  If he is able to get the backlights to stay on, if other functions of the TV main board are OK, then he should be able to see the pictures and have sound, and everything else working normally, if not the he more that just bad BL-ON and bad DIM control problem on the main board.
                                  • shadetreetrader11
                                    • Oct 2015
                                    • 230
                                    There is no way to track down the faulty part on the main board? I just ordered a eprom for a couple bucks. I thought I would try it just for the heck of it. At this point what could it hurt. I'm willing to try anything you think might be the problem.
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8327
                                      I was thinking about this on one of my earlier posts too.
                                      So when you took the BLon and the DIM pins out of the connector, the backlights stayed on, you said. Did you have picture and sound?
                                      • shadetreetrader11
                                        • Oct 2015
                                        • 230
                                        No sound or video.
                                        • Asraf Atb
                                          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                          by Asraf Atb
                                          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                          01-27-2025, 05:02 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • cheeky2
                                          Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                          by cheeky2
                                          For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                          See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                          01-08-2024, 05:56 AM
