Toshiba 46sl417u main board issue
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Re: Toshiba 46sl417u main board issue
    That sux.
    • shadetreetrader11
      • Oct 2015
      • 230
      ya i agree that sucks.
      • mattstolte
        • Dec 2013
        • 612
        • usa
        You wont find that main board anywhere. I had to send it to modus link to get repaired but there closed down now. I got a guy that can repair that main board he is great with them Toshiba's and had a test set. So if he's able to Do it then anyone can its just knowing how to do it which I dont
        • shadetreetrader11
          • Oct 2015
          • 230
          I guess I'm a little confused as to who is working for badcaps.net? Who can I get a quote from for mainboard repair? Am I obligated to pay for the advice I recieved from leaky caps? Or is the idea that I purchase all my parts threw badcaps? I've never done this before, so i need a 101 on the whole concept.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8327
            Well no... there are some real smart members on here that are sharing their experiences and their wealth of knowledge to those that need help for free. However if you like you can donate to badcaps.net to help keep this forum going. Parts you can get wherever you want, that is up to you. Digikey, Mouser, Ali, wherever...
            • fzabkar
              • Mar 2009
              • 772
              I would measure the voltages at the regulators on the main PCB.
              IC273, D2907, L2707, C2738, C2732, C2735 constitute a stepdown DC-DC converter. Measure the output voltage across the capacitors (C2738, C2732, C2735).
              IC290, D2910, L2900, C2907-2910 constitute another stepdown DC-DC converter. Measure the output voltage across the C2109- C2107 capacitors. These are just after the FL285 inductor.
              IC313 appears to be a linear regulator. Measure the voltage at the 100uF smd capacitor just below it.
              There appear to be 3 more stepdown regulators near the CPU. Measure the output voltages at each of the 3 coils.
              There is at least one more stepdown regulator near the tuner. Measure the output voltage across the C2705, C2707, C2708 capacitors, and the voltage on the other side of FL174.
              There could be more regulators (IC327 ?), but I can't see the PCB clearly enough in any of the photos.
                Did you already try heating (hair dryer) and cooling (using canned air duster upside down) the board?
                Try disconnecting the WIFI card?
                Pictures provided by shopjimmy.
                • mattstolte
                  • Dec 2013
                  • 612
                  • usa
                  #28
                  Man that was alot of smart info. Would love to get to that level one day. Still learning
                  • fzabkar
                    • Mar 2009
                    • 772
                    It's not really that complicated.
                    The main board is based around an SoC (System on a Chip). The SoC and its peripheral components (eg SDRAM, EEPROM, flash) run from lower voltages. For example, the SDRAM typically requires 1.8V, the EEPROM/flash requires 1.8/2.5/3.3V, and the SoC requires a Vio voltage (3.3V) and a Vcore (~1V - 2V).
                    These voltages are generated from the main supply by switchmode DC-DC converters or linear regulators. You can identify the switchmode converters simply by looking for coils. In a stepdown converter the output voltage will be present at the coil. A linear regulator typically has 3 pins, Vin, Vout, and Vadjust or Ground.
                    When testing a CPU based board, you first check the onboard supplies. Then you look for the reset signal at the SoC and verify that the oscillator (usually a crystal or crystal oscillator) is functioning.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8327
                      yeah... but at that level you need a hot air soldering station too... I have one, but most don't.
                      • shadetreetrader11
                        • Oct 2015
                        • 230
                        I don't have a schematic for this board I did go around and test a bunch of the sections of the main board and found the voltages you mentioned in your last post. what I am lacking is the 12v on the t-con connector cn652 pins 1-4. how do I check some of the oscillator functions? That might be getting a little deep. I have a scope and hot air soldering station also if that helps.
                        • shadetreetrader11
                          • Oct 2015
                          • 230
                          I tryed heating and cooling, and disconnecting the wifi card with no luck.
                          • fzabkar
                            • Mar 2009
                            • 772
                            Your voltage readings are unhelpful. Sorry, I can't help you.
                            • shadetreetrader11
                              • Oct 2015
                              • 230
                              Well i really need some test points and there required voltages
                              • shadetreetrader11
                                • Oct 2015
                                • 230
                                Can you please tell me how to get ahold of your friend that works on these main boards?
                                • shadetreetrader11
                                  • Oct 2015
                                  • 230
                                  Is there anyway you can give me some test points and voltages so I have a little direction to go hear. If it helps you I can go through all the caps you mentioned and tell you there voltages.
                                  • fzabkar
                                    • Mar 2009
                                    • 772
                                    The capacitors I mentioned are the test points that I would be looking at. So yes, their voltages would be helpful. A close-up photo of the three coils would help too.
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8327
                                      I'd be following that Blon pin backwards towards the main IC.
                                      • fzabkar
                                        • Mar 2009
                                        • 772
                                        The SoC appears to be braindead or stuck in standby mode.
                                        • shadetreetrader11
                                          • Oct 2015
                                          • 230
                                          https://www.badcaps.net/forum/attach...1&d=1446777930
                                          • Asraf Atb
                                            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                                            by Asraf Atb
                                            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                                            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                                            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                                            01-27-2025, 05:02 PM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                          • cheeky2
                                            by cheeky2
                                            05-25-2024, 03:27 AM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • cheeky2
                                            Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                            by cheeky2
                                            For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                            See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                            01-08-2024, 05:56 AM
