37lg7000 sound. No picture but backlight on.
  • Rickig
    • Mar 2015
    • 112
    • England
    As above,
    Any help would be greatly appreciated with diagnosing the problem board.
  • Hamie
    • Apr 2014
    • 1383
    Re: 37lg7000 sound. No picture but backlight on.
    Pictures?
    Include a picture of the t-con.
    Check each end of the pico fuse on the t-con.
    You should have 12v on each end.
    • CapLeaker
      Leaking Member
      • 8222
      If you have an oscilloscope, measure the LVDS out of the main board, while flicking the menu on and off.
      • Rickig
        • Mar 2015
        • 112
        • England
        No scope. I think tcon ok. Blue light comes on when set powered up. Think its main board of screen not sure.
        • Hamie
          • Apr 2014
          • 1383
          Blue light doesn't mean the t-con is working.
          Unplug half the tcon and see if you get an image on either side on the tv.
          We need a photo of the tcon to see test points.
          • CapLeaker
            Leaking Member
            • 8222
            chances are 50/50.
              Originally posted by hamie
              blue light doesn't mean the t-con is working.
              +1.
              • Rickig
                • Mar 2015
                • 112
                • England
                If I unplug half the tcon I get half a white screen on the side I unplug
                • Rickig
                  • Mar 2015
                  • 112
                  • England
                  Tcon
                  • Hamie
                    • Apr 2014
                    • 1383
                    Check voltages on t-con.
                    Vdd
                    Vcom
                    Vgl
                    Vgh
                    Post results.
                    • Rickig
                      • Mar 2015
                      • 112
                      • England
                      Sorry.. Where exactly do I take the reading from?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        if you look at the tcon where the top white connectors are for the ribbon cables just under there on each side there are the test points marked with a gold test point, put the black multi meter probe on the tv metal chassis and try not to let the probe slip and short anything out.
                        • Rickig
                          • Mar 2015
                          • 112
                          • England
                          Vgl 2.5v
                          Think vcom_r 6.3v or 17mv (there's 2 test points under the vcom r writing not sure which is right)
                          Vcom_l is 12.6v
                          Vgh 12mv
                          Vcc 3.3v
                          Vdd 16.9v
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            i think the readings are meant to be took above the white line just to top left if that makes sence
                            • Hamie
                              • Apr 2014
                              • 1383
                              Vcom is here:
                              Can you check vgl and vgh again as they are definitely not right.
                              Vdd is ok.
                              Vgl should give a negative reading. Ie -6v
                              Vgh should be about 15v
                              • Rickig
                                • Mar 2015
                                • 112
                                • England
                                Vcom 6.9v
                                • Hamie
                                  • Apr 2014
                                  • 1383
                                  Vcom is fine.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    did you see my post 14 you may need to check the readings again
                                    • Rickig
                                      • Mar 2015
                                      • 112
                                      • England
                                      Taking readings from here. The dot under each one and readings are as previously stated
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        possible i still think you need to check them above and too the left of the white line as if you count the numbers starting with a v theres just enough gold dots to match under the whie line but above there 4 test points whats hamie opinion?
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • DKWS89
                                          Sony XBR 49x900E - Sound and backlight on but no picture
                                          by DKWS89
                                          Hey Guys,
                                          So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                          All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                          12-14-2023, 04:30 PM
