Vizio vt420m sound issue
  • Cyklopz
    • Mar 2015
    • 17
    • Usa
    The above TV will work OK for a while, 10-60mins or so. Eventually, it will develop
    + an issue with sound where the sound seems to get broadcast twice kind of like an echo. The issue will slowly build up worse and worse. At these times I also see a slight flickering of the video but otherwise the video seems fine. I see on this refurbished main board there is some brown discoloring on the audio header (and the plastic looks slightly melted). Any ideas on how to troubleshoot this issue? I've checked the power coming from the power supply board and all lines looked right from there.
    Image attached.
    Thanks.
    Cy
  • Cyklopz
    • Mar 2015
    • 17
    • Usa
    Re: Vizio vt420m sound issue
    Additional tests, tried different sources/inputs with same issue on all.
    Cy
    • CapLeaker
      Leaking Member
      • 8352
      someone had either changed or resoldered U409. I can't see the numbers on it, but looks like it could be the audio IC. That's where the discoloring came from.
      Edit: 402WP = EEprom. So it had a EEprom replacement.
        Which one of these is your main board?
        http://www.shopjimmy.com/catalogsear...q=Vizio+vt420m
        • Cyklopz
          • Mar 2015
          • 17
          • Usa
          My model uses this main board type:
          http://www.shopjimmy.com/vizio-cbpf9...main-board.htm
          CP
            So you already replace the main board, right? What was the original problem with the old board? At this point the power supply will not cause echoing sound problem, that will be something in the sound processor section.
            U602 is the Class-d amplifiers for driving the speakers.
            Pictures provided by SHOPJIMMY.
            • Cyklopz
              • Mar 2015
              • 17
              • Usa
              The original problem with the set was the picture would start to get some artifacts over time and the system would eventually reboot itself. I sent the board in for swap/repair (it was swapped for a rebuilt board). The video seems OK now but the audio is having issues. I noticed the brown smoke mark on the audio header and was of course curious about it. No caps appear bad on the main board or the power board.
              Anything I can try to check with a meter or pics I can take to try to help troubleshoot?
              CP
                That CN403 is not connected to audio circuit.
                Show us the pictures of the whole back side of the TV.
                I think the board you got has problems, i hope it is still under warranty.
                • tipitup
                  • Nov 2015
                  • 4
                  • usa
                  I have always had this same sound problems with my vt420M, mine happens more when I am playing a dvd. About 34 minutes into it it stars with the sound stuff. Now I have no sound but everything else works great. I'll not hijack this tread with that problem, just confirming a similar problem as this guy.
                  • aaronwt6
                    • Apr 2013
                    • 855
                    • US
                    Is u409 the eeprom chip as stated above. I've always thought U405 was the eeprom on these? It's a 48 pin TSOP chip NAND128W3A2BN6. I know it's what typically has the panel manufacturer sticker on it and can be swapped between boards to change what panel they will work with. I wasn't trying to hijack the thread either but if U409 is the eeprom I'd prefer to change that when I get one in that's stuck on the Vizio logo screen. Several models use this board.
                    • benspawn02
                      Anthem MRX500 - no sound. R2A15218FP issue??
                      by benspawn02
                      Dear Electronics Experts:
                      I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
                      08-12-2023, 04:46 AM
                    • ctebke
                      DELL 3501 MB la-k034p Sound issue
                      by ctebke
                      Hello, I have dell 3501 MB la-k034p with Sound issue RED cross. No sound device in device manager. In BIOS diagnostic everything passes but no sound tone either in bios test. AUDIO chip is CS42l42 and 3.3v, 1.8v is present. Someone have any idea ? Thanks.
                      11-21-2025, 08:09 AM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                    • ex250
                      Kenwood SW-505D no sound issue and pops from time to time when it works
                      by ex250
                      Hello mates,
                      I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                      It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                      12-29-2024, 03:27 PM
