Samsung LN52A650 Visual Artifacts & Repeatedly Power Cycles
    • 12269
    • U.S.
    Re: Samsung LN52A650 Visual Artifacts & Repeatedly Power Cycles
    So is it 131 or 132 OR are there two different boards??
    • tv_guy6969
      • Sep 2015
      • 3
      • united states
      Originally posted by Shane711
      OK, so I had 2 of these TVs power cycling. I changed out CAP C132 on both main boards and then played a 2 hour movie with each main board and there is no power cycling. Success!
      were can i buy this part ( CAP C132 )
      • tv_guy6969
        • Sep 2015
        • 3
        • united states
        where can i buy this part CAP C132
          See POST 14 if c132 has the same marking as indicated in post 14, otherwise show us good clear pictures of C132.
          • captainKKK
            • Sep 2018
            • 287
            Ok, I am about to try the C102/C131 cap replacement fix. The C132 is shown in the best pic I can make and it is beside the C131 and I would like to know if its replacement is necessary? Last 2 pics are my board numbers.
            • captainKKK
              • Sep 2018
              • 287
              Thanks BudMan, your info fixed my LN52A550P3FXZA perfectly....THANKS
              • coasterghost
                Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                by coasterghost
                For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                System Hardware:
                Processor: AMD Ryzen 7 PRO 5850U
                Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                09-08-2025, 10:46 PM
              • edugimeno
                (old) LG 32lk330 cycles Backlight 3 times and then OFF
                by edugimeno
                Hi!! I have been given this old TV set.
                When I hit the power button, the BL (as you know this is a CFL backlight) turns on, video works fine as I can see the LG logo show off, but the backlight starts going on-off for 3 times, when it gives up and turns completly off
                This set has a inverter board on the top right corner. This inverter (or the tubes, I don't really know) buzzes very loudly during the second that the BL stays ON. I have posted a video, turn your volume UP!
                https://fileport.io/9EdfmD5qtEaw
                I have checked voltages at the PS
                All normal voltages...
                12-11-2023, 01:28 PM
              • N3Star
                Retro 8800 GTX from EVGA artifacts
                by N3Star
                I need help identyfing what is broken on this GPU - GPU core or VRAM. Let's start with what I did and know so far:
                - disassembled, added missing SMD capacitors from same GPU
                -(If anybody knows what Q518 is and would share this information I would be very grateful)
                - artifacts during Windows booting are blue vertical stripes, I can take a photo if that would help
                - artifacts in Windows are yellow-ish horizontal lines
                - in BIOS/ text on black screen text gets extremely garbled
                - GPU-Z doesn't show GPU or VRAM frequency
                - GPU error 43...
                06-14-2022, 03:45 AM
              • MonkeySlug
                Samsung UN65EH6000 - Vertical Lines sometimes, other visual artifacts
                by MonkeySlug
                Background:
                I found this TV by the side of the road saying it needed a new backlight. Thanks to the help of this forum, I was able to repair the backlights and the power board.
                When I put the TV together, I noticed visual artifacts on the right side and a darkening of the center area, mostly on the right. Specifically, on the far right, the screen is very slow to refresh and has a smearing effect. I've taken video and will link that below. The photos show some of the afterimages that persist for a few seconds to a few minutes, again, on the right side mostly.
                11-17-2019, 08:31 AM
              • klugec
                KVA2 RTX 2060 Super 8GB Desktop artifacts
                by klugec
                Hello (sorry for my bad English),
                I have a strange problem with my KVA2 RTX 2060 Super. As soon as Windows 11 is loaded, artifacts appear. Now the crazy thing: When I start Furmark the artifacts are gone and Furmark runs great without crashing. Mats test shows me no errors (PASS). Drivers can also be loaded without any problems.
                Mods shows me the following error:
                Code:
                MODS start: Thu Feb  1 19:16:00 2024
                Command Line : gputest.js -oqa -old_gold -test 94 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -fan_speed 70 -matsinfo
                02-01-2024, 10:58 PM
