Samsung 65" UE65F6400AF ramdomly power cycles
This topic has been answered.
  • FerociousBC
    • Oct 2025
    • 6
    Hello all,
    Samsung 65" TV that randomly power cycles. It could be a few hours or a few minutes and then I hear a click sound and reboots. I have updated the firmware to the latest. I'm suspecting the power supply might have bad caps (hoping πŸ™...). Inspected the PSU board and none of the caps have any bulging, leaking, or unusual noises that I can hear. Any suggestions? Thanks
    PSU: L65X1Q_DHS / BN44-00627A
    Model: UE65F6400AFXZA
    Ver No: MH01
  • Answer selected by FerociousBC at 10-18-2025, 07:46 AM.
    FerociousBC
    • Oct 2025
    • 6
    Well I dropped off the power supply board at the TV repair center and later received this email.... Guess It's a new TV. πŸ“ΊπŸ˜’ Thanks for the help everyone. πŸ‘
    Click image for larger version  Name:	Screenshot 2025-10-17 210045.png Views:	0 Size:	15.3 KB ID:	3747203
    • Diah
      • Feb 2013
      • 6483
      bulging caps not the only sign of bad one.. ESR measurement the correct way, if you are not able to measure ESR, i would suggest you to replace all caps at the Cold Area, they are not expensive.
      • lotas
        • Jan 2016
        • 4796
        • Russia
        Check the cable and its connectors that connect the motherboard to the power supply (burnt contacts, poor contact), a common problem in this chassis.
        • FerociousBC
          • Oct 2025
          • 6
          lotas Cable seems to be fine.
          Diah I see the COLD area on the lower right. Where does this area extend to?
            • 12306
            • U.S.
            The thick white line, see it right beside where it says cold, marks the hot and cold side, in your picture, cold is on the right side. There's 12 electrolytic caps on that side. Also inspect the underside of board for any obvious issues. Bad solder joints etc, can just do an image search for bad solder joints for examples.
            • Diah
              • Feb 2013
              • 6483
              try use hair dryer to warm up the 2 caps 680uf 25V, then plug it in wall see if it come on straight
              • FerociousBC
                • Oct 2025
                • 6
                nomoresonys Thank you. No burnt marking on other side of board that I can see but did notice this dark spot JP907/JP908 and this thing on the other side.
                Diah I heated those 2 caps for about 2min. Plugged TV in and Powered On with no issues.
Name:	Screenshot 2025-10-16 210052.png
                  • 12306
                  • U.S.
                  When you say powered on with no issues, do you mean the tv worked like it should? If so there's your answer, switch out those 2 caps.
                  • FerociousBC
                    • Oct 2025
                    • 6
                    So the TV powers On every time but after several minutes or an hour it will randomly power cycle.
                    • Diah
                      • Feb 2013
                      • 6483
                      we are confused with yours answer and first post, rework all soldering point on PSU
                      • FerociousBC
                        • Oct 2025
                        • 6
                        Sorry, I thought I explained this in the 1st post... But thanks for the help. I really appreciate it. I found this service.
                        https://www.coppelltvrepair.com/p/20...wer-cycing-etc
                        • FerociousBC
                          • Oct 2025
                          • 6
                          • PantherDave
                            by PantherDave
                            Hi all!
                            I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
                            05-29-2024, 02:01 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                          • mrtek
                            Samsung UN43NU6950FXZA No power
                            by mrtek
                            Hi
                            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                            Main fuse = OK
                            Back light LED = OK. Power them with aux power source
                            LED output = OK 156V
                            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                            07-20-2025, 08:06 PM
                          • hill01
                            Samsung UE75MU7009TXZG Endless Power Cycle
                            by hill01
                            Hi everyone and thanks in advance for any help I might get here
                            My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                            About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                            Since a few days, the TV won't turn...
                            11-17-2021, 02:52 PM
