(old) LG 32lk330 cycles Backlight 3 times and then OFF
  • edugimeno
    • May 2017
    • 581
    • Spain
    Hi!! I have been given this old TV set.
    When I hit the power button, the BL (as you know this is a CFL backlight) turns on, video works fine as I can see the LG logo show off, but the backlight starts going on-off for 3 times, when it gives up and turns completly off
    This set has a inverter board on the top right corner. This inverter (or the tubes, I don't really know) buzzes very loudly during the second that the BL stays ON. I have posted a video, turn your volume UP!
    https://fileport.io/9EdfmD5qtEaw
    I have checked voltages at the PS
    All normal voltages (3.5, 12v, 24v) stay ON correctly during the power cycles
    INV ON pulses HI-LO during the power cycles. ERROR does the same
    If I disconnect the inverter board from the power board, INV_ON stays ON (3.3v) all the time, and ERROR pulses during the power cycles
    If I disconnect the CFL outputs from the inverter I get the same behaviour as above (like CFL conditions does not seem to affect). Also the led in the inverter board pulsus while these power cycling happen
    This TV is probably not worth much repair, but is this something a quick fix sounds feasible?
    Thanks!
  • nomoresonys
    • 12172
    • U.S.
    Maybe check out the inverter, test everything you can on there, hows the fuse F1?, I might try changing out those 2 electrolytic caps, hard to tell if they are bad without a tester but it's something to try.
    • edugimeno
      • May 2017
      • 581
      • Spain
      Thanks! I tried resoldering some points (capacitors, large Q's) etc with no luck., I called the guy and told him that being such an old TV (not even LED BL) it wasn't worth the repair, so he's scraping it.
      Tjank you!
      • nomoresonys
        • 12172
        • U.S.
        Ok, right prolly not worth investing money in, I like those old sets but they are stupidly heavy compared to the newer ones.
        • x_orange90_x
          Vizio E55-E1 bad backlights or bad inverter?
          by x_orange90_x
          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
          I don't know how exactly to test the inverter itself. Is it...
          01-29-2025, 09:24 PM
        • Gentian
          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
          by Gentian
          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
          03-06-2023, 07:07 AM
        • valvashon
          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
          by valvashon
          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
          01-04-2024, 01:44 PM
        • eccerr0r
          A modified sine wave inverter + a grid tie inverter?
          by eccerr0r
          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
          Next thing is trying to charge the batteries using solar power, but that's another issue ...
          08-31-2023, 09:14 PM
        • caseyjay_48
          Sony KDL-46BX450 Inverter Troubleshoot Logic
          by caseyjay_48
          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
          09-23-2022, 08:08 PM
