Samsung LN37D567F9HXZA wont power on red flashing light
  • crushkittykitty
    • Sep 2015
    • 41
    • usa
    Re: Samsung LN37D567F9HXZA wont power on red flashing light
    is this the correct part?
    TPS54327DDAR =
    54327
    TI 19A
    P2D264
      Yes, it does look like the correct IC the way the pins are connected, good job locating the P/N.
      Remove that burnt out IC and then check the resistance between pad 5 and pad 6 of the board where the IC was to see if it shows low resistance.
      • crushkittykitty
        • Sep 2015
        • 41
        • usa
        lol ebay for the win on the part number well close then just went to ti website a started looking. TI 54327. will pull the chip off in the morning, thanks again for the help.
        • crushkittykitty
          • Sep 2015
          • 41
          • usa
          testing taking off small 4 prong chips, don't have a heat station or a heat gun any more so till I can get 1 or 2 off a board with out hurting the board I am stuck. I can get the old chip off by clipping the chip but then have no way to put the new one on. Will update when I get you the measurements you asked for. Sorry for the time I am taking its a hobby and time is hard to come by.
          • crushkittykitty
            • Sep 2015
            • 41
            • usa
            just an update both the t-con and the main were bad, tried the t-con and the main in another tv. Since I cant find a replacement main I am going to try and hack something together, since it uses a AU screen
            • crushkittykitty
              • Sep 2015
              • 41
              • usa
              #26
              thanks again you are the best
              • crt man
                • Mar 2013
                • 106
                • England
                #27
                Was this on a set of the same model, and board
                numbers plus same LCD panel?
                • crushkittykitty
                  • Sep 2015
                  • 41
                  • usa
                  #28
                  the main came from a Sceptre 32 inch i think along with the t-con
                  If you want I can get all the part numbers that I used, basically it was like this
                  screen = samsung (au something)
                  power supply = samsung powering inverter board and back lights
                  main = Sceptre t320HVN01.2 built in power supply just unplugged the led leads , leds not used
                  on off controls from dynex
                  t-con-Sceptre T315HW07
                  tv was used for a pc adjusted the brightness threw the pc.
                  at first tried to use the leds but they were not enough backlight. So ended up using the tubes inverter
                  here is the boards
                  http://www.shopjimmy.com/catalogsearch/result/?q=X325BV
                  top main and t-con bottom
                  http://www.shopjimmy.com/catalogsear...LN37D567F9HXZA
                  is the hotel tv I started with
                  I compared the t-con boards and went from there No one knew if it would work and almost everyone said no dont do it lol but they were both free
                  screptre had bad tabs :\
                  main was bad in the samsung, possibly the t-con as well,
                  used since last post till 2 days ago when got the new parts
                  I have the boards out now since i got another samsung from the hotel....
                  same model tv with a broken screen swapped out the boards now i have a working tv that is in hotel mode.
                  fixed a laptop and got it along with a sanyo dp42647
                  The sanyo has inverter out powered on for 5 sec then backlight goes out
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • STKR123
                    Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                    by STKR123
                    As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                    I wonder if re-flashing the BIOS might be of any use here.
                    As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                    There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                    11-03-2024, 06:58 AM
                  • lapfix
                    HP OMEN NO power no light
                    by lapfix
                    HP OMEN : DAG35DMBAD0
                    NO power ,no short ,no corrusion
                    Consumption : when charger plg in = 0.004 amp
                    Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                    when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                    No light at power button led
                    All coils resistances :
                    Pl 2001 =3v measured with kohm.
                    pl 2004 = 5v measured with kohm
                    pl 6001 = 49.7ohm
                    pl 4012 = vccsa = 24.4 ohm
                    pl 3001 =...
                    11-03-2025, 07:48 AM
                  • CraigR
                    Hp Spectra x360 Power light flashing, component id
                    by CraigR
                    Working on a hp x360 15-eb1043dx that will not turn on and the power light just flashes. It pulls 700ma when flashing. Under the thermocam I found a component I am unable to id that light up. If someone can help would be appreciated. I put the number that are on it in better test....
                    05-07-2025, 11:06 AM
                  • stephonwhyte
                    un65tu7000fxza - Flashing Red Power Light
                    by stephonwhyte
                    un65tu7000fxza - I am experiencing the flashing red light on the power led. So I purchased the replacement kit for the mainboard and power supply. I still experienced the flash red power light. So I purchased a new ribbon cable, The flashing light stopped for a minute, I could hear sounds on the TV but no picture. I did the 60 second reset and it went back to flashing. What could possibly be the issue now? All the LEDs are lit up from what I can see.
                    Thanks for all responses.
                    11-22-2022, 12:03 PM
