kdl-37v4000 bad Tcon ?
  • karlpowell
    badcaps.net
    • Feb 2013
    • 104
    • uk
    Picked this set up cheap today, looks Like maybe a Tcon fault ( what do you think ?)
    Tcon looks to be a pain in the ass to source tho
    upload pics
  • zomi
    • Nov 2011
    • 513
    Re: kdl-37v4000 bad Tcon ?
    check the tcon
    bet it has as15 chip
    cheaper to change the chip on the tcon if you can
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      maybe check the t con voltages some good information on how to test etc in this post
      https://www.badcaps.net/forum/showthread.php?t=48282
      • karlpowell
        badcaps.net
        • Feb 2013
        • 104
        • uk
        Thanks for the reply's Guys, it does have the as15 chip I don't have the expertise to change it
        forum image hosting
          Another failed AUOPTO T-CON due to bad GAMMA reference Voltage IC.
          • karlpowell
            badcaps.net
            • Feb 2013
            • 104
            • uk
            OK ive bought A chip for it from ebay , im going to take to someone with better eyes than me and who can solder the IC in place, Ill let you know how i got on.
            http://www.ebay.co.uk/itm/121556694727 this is the IC from ebay .
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              Its still worth taking the voltages of the tcon now with the old chip fitted in my opinion, just incase the new chip is also faulty some ebay chips can be faulty when new.
              • karlpowell
                badcaps.net
                • Feb 2013
                • 104
                • uk
                anyone know where i can source this board if the as15 does not work ... its a 55.37T03.C09
                • satinser
                  • Oct 2012
                  • 214
                  • uk
                  Try Emos TV. They offer a cost effective repair service of AUO Tcon boards. I had a KDL37V5500 in today with exactly the same Tcon fault. They also guarantee their service not worth trying it yourself. Best of luck to you.
                  • kca
                    by kca
                    Hello all ~
                    08-31-2025, 06:38 AM
                  • x_orange90_x
                    TCL 50S535 bad tcon or panel issue?
                    by x_orange90_x
                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                    03-29-2025, 11:02 PM
                  • advant
                    by advant
                    02-03-2020, 12:25 AM
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
                  • netgearnetgear
                    TCL 43S423 TCON OR PANEL FAULTY???
                    by netgearnetgear
                    Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                    08-20-2025, 06:04 PM
