Samsung un32eh5000fxza no power
  • junkmale172
    • Nov 2012
    • 41
    • usa
    Have a samsung that will not power up. I get no standby light or nothing. Main caps on ps read 163v, and connector cnm803 I get no readings on any of the pins, need to know where to start looking thanks.
  • junkmale172
    • Nov 2012
    • 41
    • usa
    Re: Samsung un32eh5000fxza no power
    Back side of ps
    • johnboy1313
      • Nov 2012
      • 1959
      This PSU has no PFC booster. 163V is correct at the main cap. I would check the diodes around the main cap.
      • CapLeaker
        Leaking Member
        • 8340
        do you get any standby voltage on that connector on the bottom?
          Did it just die by itself or something happen and then it went out?
            Check the DCV BETWEEN the two legs of the startup cap CM806. You MUST BE REAL CAREFUL since you will be working int he deadly primary side of the circuit so I hope you know what the precaution you MUST take when working in the primary side.
            • junkmale172
              • Nov 2012
              • 41
              • usa
              I am getting 10v to 11vdc on cm806, the person I got the tv from says they just went in one day, and it wasn't working. I get no readings on any of the connectors on the power supply
              • CapLeaker
                Leaking Member
                • 8340
                so problem is in either the feedback or in the primary section. First I would look hard on these square blue caps in the primary. Take them out and measure those.
                  10~11VDC may be too low for the SMPS IC to start. Can you look at the P/N of that 8-pin SMD IC in that section where the cap is?'
                  You can also try heating up that cap to see the STBY power supply will startup, or you can just replace the cap.
                  • junkmale172
                    • Nov 2012
                    • 41
                    • usa
                    Replaced the cap, still getting same readings, also checked blue caps and I get 118v on both. Pn is s3310343 on the 8 pin SMS ic. Everything seems to be fine on hot side, but nothing on the cold side, what connects the two?
                      "Pn is s3310343 on the 8 pin SMS ic" That does not look right. There should be more than one line printed on the top of that IC.
                      • junkmale172
                        • Nov 2012
                        • 41
                        • usa
                        S3310 is on the top then 343 is the second line, if I am looking at the right chip
                          ICM801 is the designator for that SMPS IC.
                          S3310 looks to be the correct P/N.
                          http://nl.aliexpress.com/item/new-or...975209960.html
                          We will have to search for the spec sheet next.
                          • junkmale172
                            • Nov 2012
                            • 41
                            • usa
                            just ordered a power supply from shop jimmy for $30, should be here within a couple of days, maybe Monday at the latest, will update, thanks for all the help
                            • rawan
                              • Oct 2009
                              • 57
                              Hi
                              did u check IC D2011K in power supply, its +5v starting supply.
                              very failure in samsung tv
                              • rawan
                                • Oct 2009
                                • 57
                                Here is some more info.
                                • junkmale172
                                  • Nov 2012
                                  • 41
                                  • usa
                                  update, got a new power supply from shopjimmy, and everything is working fine, thanks everyone
                                  • junkmale172
                                    • Nov 2012
                                    • 41
                                    • usa
                                    got the tv free, paid $33 for the part plus shipping
                                    total investment of $36
                                    • CapLeaker
                                      Leaking Member
                                      • 8340
                                      good to see another tv saved from the bin!
                                      • PantherDave
                                        by PantherDave
                                        Hi all!
                                        05-29-2024, 02:01 PM
                                      • GLISIT
                                        by GLISIT
                                        01-16-2025, 02:29 PM
                                      • mrtek
                                        Samsung UN43NU6950FXZA No power
                                        by mrtek
                                        Hi
                                        Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                        Main fuse = OK
                                        Back light LED = OK. Power them with aux power source
                                        LED output = OK 156V
                                        I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                        Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                        07-20-2025, 08:06 PM
                                      • Journey11
                                        Samsung TV won't turn on ... keeps cycling the power relay on & off
                                        by Journey11
                                        Hi All,
                                        First time posting here ... my name is Kevin but my friends call me Journey.
                                        I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                        After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                        It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                        07-04-2024, 02:44 PM
