So it powers up works fine for 10 mins then the screen goes either lines or static or just goes black, unplugging and plugging it back in seems to cure the problem ive take then tv apart and changed out the capacitors on the psu board but still same problem any ideas? Back light remains on even when screens black and sound hasnt suffered yet
LG 37lc55 turns on few minutes later screen goes out
Re: LG 37lc55 turns on few minutes later screen goes out
To check your voltage on both sides of the fuse you need a voltmeter. Make sure to set it to DC voltage, so the straight line not the wiggly line. Place your black lead on ground, and the red lead on one side of the fuse then the other. You should take this reading after the tv goes dark.Last edited by Nick's Tvs; 06-30-2015, 11:14 AM.Comment
Edited out because I misread the original questionLast edited by Nick's Tvs; 06-30-2015, 11:13 AM.Comment
Hamie, you are correct, sorry Blueeyes, for some reason I thought the entire tv shut down. That is my fault, I didn't read the information properly. Please ignore everything I just said up until now.
Then yes I would definitely do the voltage test on the fuse after the tv goes dark. That should be your first test.Comment
So this is where I'm at turn on TV and fuse reads 12.05top pin 12.03 bottom pin and when picture goes top pin reads 12.08 but bottom pin goes all over the place from 1-12.38 after a few minutes it regulated back to normal 12v area but once HDMI plugs in another few minutes down the road the screen turns to static the sound goes and it rotates between black screen and static removing HDMI fixes this straight away so is it a fuse problem?Last edited by Blueeyes; 07-01-2015, 04:37 AM.Comment
So how do we diagnose the problem on the main board or is it worth just buying a new main board?Comment
yes if only happening on hdmi a mainboard change will probably sort it just make sure all the numbers of any stickers match up.
It maybe worth doing a trying a factory reset in service mode first though although im not sure on a lg how to do one but maybe a more experienced member will advise.Comment
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... -
by frannyjunkSo I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
TIA. -
by Rav_tangleHi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
is this... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by krigehi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
- Loading...
