toshiba 50L1350U no backlight
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: toshiba 50L1350U no backlight
I'm not sure about how much they require. I got the TV from a guy($20 bucks) who said sound no picture, so when I got it home and did the flashlight test I figured I would just have to change the led driver, but once opened up notice there wasn't one. Did a quick Google search and the Toshiba website popped up with people with this model having the same issue and the Tech said replace the pwr board, so I found one on ebay cheap so I took that gamble. then after seeing your post on here I tested the L1+ and L2+ and notice the same reading, but It would jump to 122v on start up for that hot second then go to 77v after the backlight flash and went out. pwr board came in popped it in then all was good.
nice, ill see if i can find one that cheap. cheapest i saw was 60something i think.I'm not sure about how much they require. I got the TV from a guy($20 bucks) who said sound no picture, so when I got it home and did the flashlight test I figured I would just have to change the led driver, but once opened up notice there wasn't one. Did a quick Google search and the Toshiba website popped up with people with this model having the same issue and the Tech said replace the pwr board, so I found one on ebay cheap so I took that gamble. then after seeing your post on here I tested the L1+ and L2+ and notice the same reading, but It would jump to 122v on start up for that hot second then go to 77v after the backlight flash and went out. pwr board came in popped it in then all was good.
i didnt notice a flash, ill try again n see. it was still at 77V so thats def a problem. ill check the caps.. have you seen them go bad this fast? the sets not, THAT old.
Wish i could find a service manual. cant find anything on this model.
I tried again and no flashComment
This guy has one for 45 free shipping(1st link)... I hope this fixes ur issue also.. the guy I got mine from had 19 of them all gone now.. But I will give you his link also just in case he gets more (2nd link)
http://www.ebay.com/itm/Toshiba-7503...item4196a750ff
http://www.ebay.com/itm/391102002943...%3AMEBIDX%3AITComment
thanks man i appreciate it.This guy has one for 45 free shipping(1st link)... I hope this fixes ur issue also.. the guy I got mine from had 19 of them all gone now.. But I will give you his link also just in case he gets more (2nd link)
I am still curious about the PWM signal that drops out, not sure it drops out due the some kind of feedback signal from the power supply/LED driver to tell the main board to shut down the PWM due to the problem in the power supply/LED driver board. No service manual to study how this TV function.
The typical symptom of failed LEDs has the same indication that the LED drive output Voltage goes high and then the protection circuit kicks to so the out put Voltage will drop.
So I hope that the new power supply/LED driver board will fix your problem.Never stop learning
so i tested the 4 caps on the left side ( capacitance, not esr)
and i found 2 which were rated at 56uf and tested at 47uf.
also, i tested the main filter cap, rated 470uf and tested 441uf
its not below the 20% line, but do you think it will bring down the back light voltage?Comment
Having the same issue did the flashlight test blacklight is out on mine. I went ahead and purchased a new power supply board, just got it in today. Installed the board....needless to say same issue
, I just purchased a t-con board since I don't have a multi-meter to test. Could this be the issue?
Thanks in AdvanceComment
T-Con has nothing to do with the back lights.. if a new PSU didn't fix it (and you know the new PSU is good), suspect the LEDs themselves. Could also be mainboard though."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
I didn't know the mainboard could also create an issue with the blacklights. Everywhere I have read said either the t-con or power supply. The mainboard does not connect to the LED's. How could it be?
The main board generates the BL-ON signal to turn on the backlights circuit, it also generates PWM Dimming control signal (if the PWM signal is stuck LOW, then you will not have backlights either, both bl-on and the PWM signal have to be present, 10% Pulse width =,min backlights level, 90% pulse width = max backlights level, if it goes below 10% then there will be no backlights).
Some TV will use the signal from the T-CON to control the backlights level based on the Video signal, it is called Dynamic Contrast so they can claim the TV has 100 thousand : 1 which is a fake contrast spec.
Is there a small cables between the T-CON and the backlights circuit?Last edited by budm; 07-30-2015, 10:02 PM.Never stop learning
The mainboard doesn't connect to the LEDs, but it does control the LED drive circuit. If the mainboard is faulty and doesn't tell the LED driver to come on, then the LEDs won't come on either.
The LEDs themselves often go faulty, though.
Oops, didn't know that.Last edited by Agent24; 07-30-2015, 10:53 PM."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
There are 2 ribbon cables that connect to the LED but a thin cable that connects from the power supply to the LED as well hence the reason for replacement.
Is there a small cables between the T-CON and the backlights circuit?Comment
So are you getting the BL-ON and the PWM signals feeding the power supply board or not?Never stop learning
Without having a basic tools to at least testing some Voltages, then all you can do is to keep replacing the boards until the TV starts working again, but if you do have bad LEDs then you will hope you can return the boards back to the sellers.Never stop learning
by pniHi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
by buchmanHi,
I have a Toshiba LED tv model number 40L2400VQ.
I don't receive the correct voltage at the output to the LEDs.
I disassembled the front panel and checked all leds and they are fine. Then I checked the voltage to the leds on the power board and it flactuate in milivolts.
Tested all caps with esr meter and they are fine.
The diodes are fine and the resistors too.
Where should I concentrate on?
Thanks in advance.... -
by hollox123Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
1. Laptop keyboard doesn't work
2. The backlight on the laptop keyboard doesn't work
3. The x2 side LEDs (red) on the laptop don't work
The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
But I am strongly aiming that it is somehow a BIOS-related problem,... -
I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
...11 Photos -
by signal.questI have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...2 Photos
- Loading...
